Snobrdrkid's WJ Build Thread - Page 75 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
Forever Wave Flags at JeepHutRubicon Express lift kits w/shocks are on sale!ORS4x4: New Product!
Unread 08-05-2011, 08:20 AM   #1111
snobrdrkid07
snobrdrkid07's Avatar
Originally Posted by 1stblack97ZJ
you change how far up and down the piston goes. Which means you get more displacement. AND you bore it out.
Okay that is what I thought but had to x2 check that one.
Originally Posted by Scibbyz99WJ
stroking a 4.0 uses an amc 4.2L crankshaft with a 99mm throw. the stock 4.0 crank has an 87mm throw. so the term "stroker" comes from increasing the distance of the combustion "stroke"
now boring is associated with making the cylinders themselves larger allowing for a bigger piston, which increases the volume of the chamber.
How did you do your motor? Stroked, bored, new pistions, new crank... was there a lot of stuff and money to stroke it?
Will give that a read! Thanks!
Originally Posted by SnowLeopard
IMHO Jeep should've refined the I6's design by building a stock 4.7 setup with fine tuning for performance and efficiency. It'd have rocked. Diesel-like torque without the headaches, and dependability of a straight 6 motor. Oh but to dream.
That would have been too cool
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 08-05-2011, 10:42 AM   #1112
Scibbyz99WJ
I purchased my kit from rpm machine. It was essentially a 4.0 rebuild kit with a few exceptions. Forged and 0 balanced 12 weight 4.2l crankshaft, 4.2l forged rods, and high compression pistons along with some moly rings. Everything else is identical to a 4.0
'99 stroked 4.5L WJ 2" BDS lift
2008 Fire Red F150 XLT 4X4 3V 5.4LV8
Closed minds should go hand in hand with closed mouths
Scibbyz99WJ is offline   Reply With Quote Quick reply to this message
Unread 08-05-2011, 11:15 AM   #1113
snobrdrkid07
So you did not bore anything out?
-Michael-
Unread 08-05-2011, 11:21 AM   #1114
Scibbyz99WJ
Nope. I left the standard bore. I would've gone .020 over had I known it was as easy as telling the shop to do it when I purchased the kit a month before the block went in for machining.
Unread 08-05-2011, 11:36 AM   #1115
snobrdrkid07
Ah ok thanks for all of the info. So just that kit got you tons of power over stock?
How hard was install and build?
-Michael-
Unread 08-05-2011, 11:52 AM   #1116
Scibbyz99WJ
It is no harder than rebuilding an engine any other way. All it requires is that you space the girdle so the longer throw crank doesn't hit it. Then you must shave it to clear the oil pan.
I did other things to increase the power. Bigger throttle body, bored out intake manifold, ported and polished head. The more volume pushed through the cylinders needs somewhere to go.
Unread 08-05-2011, 11:52 AM   #1117
zerocool1221
2003 WJ
Love your WJ man....looks good!!
zerocool1221 is offline   Reply With Quote Quick reply to this message
Unread 08-05-2011, 11:55 AM   #1118
snobrdrkid07
I figured it still was an entire rebuild. Which is for the time being out of my league. I would need a shop to do it or see if my mechanic would be able to do it. haha
Have you blown your trans yet?
-Michael-
Unread 08-05-2011, 11:56 AM   #1119
snobrdrkid07
Thank you! It had been a really fun process building it up! I hope the same goes for you and your Jeep!
-Michael-
Unread 08-05-2011, 11:57 AM   #1120
Scibbyz99WJ
Engine was rebuilt at 147k trans went at 158k
Oh FYI. I spent about $1800 in parts alone
The hot tank, magnaflux, port job, freeze plugs, block sleeve, and cylinder hone cost $425
Unread 08-05-2011, 11:59 AM   #1121
snobrdrkid07
Oh that sounds like fun. What did you do to your trans... did you build that up some?
-Michael-
Unread 08-05-2011, 12:01 PM   #1122
Scibbyz99WJ
I didn't have the money at the time so I bought a used trans out of a recently wrecked jeep. It's holding up so far. But I'm saving up for a nv3550 swap when it does go. The 42re can barely handle a 4.0 much less a 4.5
Unread 08-05-2011, 12:05 PM   #1123
snobrdrkid07
haha a manual swap would be so much fun haha. would the six speed manual from the rubicons fit in the WJ's? thatd be cool too!
I wish the 545re would fit up to the 4.0 or the future 4.5+ liter engine!
-Michael-
Unread 08-05-2011, 12:53 PM   #1124
Scibbyz99WJ
I hope I'm not wrong but I believe that any 4.0 wrangler trans will adapt to fit a WJ. The 6 spd would be pretty awesome but its $4k new!!! I can find a used nv3550 and rebuild it for a quarter of that
Unread 08-05-2011, 01:06 PM   #1125
snobrdrkid07
Yea that would be good. I do not see why that 6 speed from the Rubicon wouldn't fit. haha. Had no idea that it was that expensive either!? Why is it so much more?!?!
Will the 545re fit the 4.0?
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
