Snobrdrkid's WJ Build Thread - Page 66 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 06-16-2011, 03:50 PM   #976
XJ57
yea mine sits a little lower on the driver side even when im not in it and i dont weigh much to begin with lol.
My Jeep won the war, your Honda mowed my lawn.
XJ57 is offline   Reply With Quote Quick reply to this message
Unread 06-17-2011, 10:26 AM   #977
snobrdrkid07
snobrdrkid07's Avatar
Yea it is fine, I am currently sitting at these heights from center of hub to fender:
FL: 18.2
FR: 18.0
RL: 19.3
RR: 19.15
(Now I just need to find someone on jeepfourm selling from 3/4 spacers
Officially a Grassfield High School Graduate!
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 06-18-2011, 11:27 PM   #978
snobrdrkid07
Well thankfully I was able to get some Grad money
-Michael-
Unread 06-21-2011, 11:27 PM   #979
snobrdrkid07
Jeep on the sand
-Michael-
Unread 06-22-2011, 09:46 AM   #980
snobrdrkid07
Corolla.
-Michael-
Unread 06-22-2011, 10:24 AM   #981
sherker55
Corolla? as in, its sits as low as a toyota corolla?
did you put those spacers on yet?
Originally Posted by HaViiK View Post
Send me the number, she can take a ride in a real jeep
Originally Posted by WillMcD View Post
She said call her when your over 4"
sherker55 is offline   Reply With Quote Quick reply to this message
Unread 06-22-2011, 12:34 PM   #982
snobrdrkid07
Yea. The rear spacers are on.
-Michael-
Unread 06-23-2011, 03:48 PM   #983
Jeep32
Looks great dude, you should try finding some of the cross rails for the roof rack. I picked mine up at a JY for 15 bucks.
the '04s have the best looking front end I have ever seen. I could only wish
"so i did a full tune up soup to nutts."
4.7 213k+
Jeep32 is offline   Reply With Quote Quick reply to this message
Unread 06-23-2011, 07:04 PM   #984
straty1987
$15 at a junk year is pretty good. i see most on ebay hit $65+shipping.
i bought mine new and now i picked up used set for a light bar but don't know if i will ever get around to it.
straty1987 is offline   Reply With Quote Quick reply to this message
Unread 06-23-2011, 07:08 PM   #985
JerzeyBoyWJ
2003 WJ
mines a 03 ..with an 04 grille ..you dont need to wish
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline   Reply With Quote Quick reply to this message
Unread 06-23-2011, 08:55 PM   #986
snobrdrkid07
Thanks! I have been looking for cross bars for some time now. That had to have been a great deal! Lucky!
You have an extra set??
Haha. Nice swap!
Side note. Saw a 04 WJ Columbia ed with a 2.5 rusty coil lift and 17 rubi rims. I was jelly. And I was explaining why when he gets stuck and only one wheel spins in full time 4x4
-Michael-
Unread 06-23-2011, 10:23 PM   #987
snobrdrkid07
Looking at adding an external transmission cooler. Is the transmission cooler already tied in with the engine coolant radiator? I'm lost on the cooling system for this jeep. Does the mechanical fan have a "higher" gear so it can spin faster when needed? I have the electronic fans too. Do those have different speeds?
-Michael-
Unread 06-26-2011, 09:15 AM   #988
snobrdrkid07
Some shots from the beach and out in the wild!
Jeep turned 94000 miles old!
-Michael-
Unread 06-26-2011, 12:15 PM   #989
WJHype
Did you wire in your under dash lights with the pink/yellow wires attached to the bulb socket for the factory bulb that's already under the dash? I just got my SMD light strips and I'm trying to figure out how to wire them in so they come on with the interior lights.
WJHype is offline   Reply With Quote Quick reply to this message
Unread 06-26-2011, 12:22 PM   #990
snobrdrkid07
I tapped right into the under dash light bulb wires, I am sorry to say that I do not remember which was positive and which was negative at the moment... a volt meter will tell you that.
But yes, wiring to that under dash light it the route i took and seems to be the easiest. and since its leds, they dont use that much power at all and should be fine!
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
