Snobrdrkid's WJ Build Thread - Page 64 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 06-06-2011, 08:19 PM   #946
snobrdrkid07
snobrdrkid07's Avatar
Originally Posted by Apollo21 View Post
Mine is 800w peak (it can hold it for just under an hour) and 400w for forever. 400w is enough to run an Xbox and TV comfortably. While charging a phone and iPod.
Did you mention your final setup/parts list in your write-up? I think that I over read past it...
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 06-06-2011, 08:23 PM   #947
Apollo21
Inverter, regular hand tools, jigsaw, drill, kill switch, 80A in line fuse, lots of wire and crimps.
Midshipmen Patrick 1/C USMMA DD: 2004 Golf GLS TDI 43mpg and 2002 Overland: Zone 4in, 32in Treadwright MTRs, IRO upper CAs, lift gate light mod, Alpine/Polk speakers, and power inverter with USB in dash mod, CB, custom rear swing out tire carrier Build thread [url]http://www.jeepforum.com/forum/f22/apollo21-build-thread-902929/[/url] SOLD
Apollo21 is offline   Reply With Quote Quick reply to this message
Unread 06-06-2011, 08:26 PM   #948
snobrdrkid07
Gotcha! Thanks! did you go for a 4 or 8 gauge wire? How'd you get a relay that big for the on/off switch?
-Michael-
Unread 06-06-2011, 08:29 PM   #949
Apollo21
8, and i didn't use a relay. I ended up using a kill switch. (KISS Method)
Unread 06-06-2011, 08:32 PM   #950
snobrdrkid07
KISS = "Keep it simple, Stupid!" (Had to google tha, haha)
Kill switch as in just a switch between the fuse and the inverter?
-Michael-
Unread 06-06-2011, 08:40 PM   #951
Apollo21
yep, it's nice and hidden under the dash. Keeps the battery from draining.
Unread 06-06-2011, 08:47 PM   #952
snobrdrkid07
Oh cool. Can you link me to what the kill switch is please? Or a picture
-Michael-
Unread 06-06-2011, 10:27 PM   #953
Apollo21
Just a regular switch. It's a manual disconnect of the pos/neg so that there is no way power can go to the inverter.
Unread 06-07-2011, 08:25 PM   #954
snobrdrkid07
Got the power inverter installed. Used 4 gauge power cord and a 80 amp inline fuse. Went in well. Not to bad of an install.
Edit: Want to add http://www.amazon.com/Power-Relay-Single-Double-Throw/dp/B001PNMBE4 to the setup for the inverter and run it to something that only runs when the key is in, i.e. the radio
-Michael-
Unread 06-08-2011, 07:57 PM   #955
snobrdrkid07
Added some 134a refrigerant to the Jeep today... it was on the low side according to the gauge... its at where it is supposed to be now according to the gauge and the ambient temp chart... seems to be blowing a bit cooler!
Still waiting on the spacers to come in.... =/
-Michael-
Unread 06-09-2011, 03:15 PM   #956
snobrdrkid07
Finally came in! Now I just to get them installed!
Install order... jeep body, spacer (the way the right one is sitting) isolator spring! Yes!
-Michael-
Unread 06-14-2011, 05:37 PM   #957
snobrdrkid07
Ordered a Superchips Jeep Flashpack today from Kolak! He is having an AMAZING sale! Unbelievable! Could not resist!
-Michael-
Unread 06-14-2011, 06:11 PM   #958
JerzeyBoyWJ
2003 WJ
why didnt you just get a 2 inch lift?
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline   Reply With Quote Quick reply to this message
Unread 06-14-2011, 06:35 PM   #959
snobrdrkid07
You should have heard the bull **** I got for getting the 3/4 spacers man. =\
Have three codes now.
P0157 - O2 sensors circuit voltage too low. Bank 2 sensor 2
P0158 - same as above but voltage too high.
P0837 - this was confusing, four wheel drive switch circuit range/performance something something. Idk. Help on this one?
EDIT: P0837
Four Wheel Drive (4WD) Switch Circuit Range/Performance
Four wheel drive (4WD) muxed switch input detected in invalid or irrational switch state (switch status provided to engine module from transfer case module during 4WD low gear engagements)
-Michael-
Unread 06-14-2011, 07:33 PM   #960
straty1987
can you pm me how much Kolak sale is for?
been thinking about one
straty1987 is offline   Reply With Quote Quick reply to this message
ome hd , OME lift kit , snobrdrkid , wj
