Snobrdrkid's WJ Build Thread - Page 62 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
PANDEMIC-USA 50" Double row LED LIGHT BAR!! These thiANOTHER Rockridge4wd Creation!! Spare Tire Carrier Delete The Jeep Forum Discount is ON!
Unread 06-02-2011, 09:41 PM   #916
snobrdrkid07
Mr. WJ
snobrdrkid07's Avatar
Originally Posted by straty1987 View Post
rent a coil compressor at autozone for free.
good info here http://www.nagca.com/grandtech/wjteraflex2lift.htm
my gosh I should have just got a 2 inch BB haha
~ 04 WJ 4.0 | Selec-Trac 242 | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Custom Front D.S. | Stillen Rotors/Metal Matrix Pads | Tow Package w/ 3.73's | Projectors w/ 55w HID H1 5000K Lows | Sylvania Ultra 9005 Fogs | Moog HD Steering | Kenwood eXcelon Radio | Memphis Speakers | Alpine Amps | Alpine Subs | Moog STB SS | Superchips Flashpaq | Auxiliary Transmission Cooler | Rock Lights | Light Bars ~
~ Snobrdrkid's "Build" Thread ~ YouTube Channel ~ Fuelly ~WJ 4.0 Transmission Cooler Info ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | 2" Spacer Lift | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
For Sale:
Front XJ/TJ 2" Budget Boost. PM for details.
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 06-02-2011, 09:48 PM   #917
straty1987
don't need new shock with 3/4"
straty1987 is offline   Reply With Quote Quick reply to this message
Unread 06-02-2011, 09:49 PM   #918
snobrdrkid07
Mr. WJ
This is true. however the skyjackers suck.
This is all i need, Just to get the rear end back to stock and actually about a 1/4 inch over stock hehehehehe
-Michael-
For Sale:
Unread 06-02-2011, 10:01 PM   #919
Scibbyz99WJ
coil compressor shouldnt be needed. disconnect the shocks and sway bar. jack up one side of the axle and the coil will fall out.
'99 stroked 4.5L WJ 2" BDS lift
2008 Fire Red F150 XLT 4X4 3V 5.4LV8
Closed minds should go hand in hand with closed mouths
Scibbyz99WJ is offline   Reply With Quote Quick reply to this message
Unread 06-02-2011, 10:03 PM   #920
snobrdrkid07
Mr. WJ
do you think if i jack it up on the differential and then put jack stands up on the frame about where the LCA meet... should that give me enough height to drop the axle enough?
-Michael-
For Sale:
Unread 06-02-2011, 10:05 PM   #921
1stblack97ZJ
Id also like to know this...
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
1stblack97ZJ is offline   Reply With Quote Quick reply to this message
Unread 06-02-2011, 10:19 PM   #922
Scibbyz99WJ
yes, that should give you enough room.
Unread 06-02-2011, 11:28 PM   #923
Akrobatiks
Just remember that when you put the spring back in with the spacer in, your going to need an extra 3/4inch then you do to get it out... when wjwheelin and I put my rear spacers in, we could get the springs out, but the only way we could get them back in was with a coil compressor...
2001 WJ Limited 4.7L Black on Black --- [B]Interior Modifications...[/B] Alpine INA-w900 navigation unit, 2 9-inch headrest LCD's, Alpine PDX-F4 125w x 4 Multi-channel Digital amplifier, Alpine Type - X Component Interior Speakers, Alpine PDX-M12 1200w x 1 Digital Mono Sub Amplifier, 2 MTX - 9510's, Custom built subwoofer enclosure, Sirrius Satellite Radio, Backup Camera, Viper 5901 Remote start/alarm, Passport Escort 9500ci Radar Detector/Laser Shifter, Optima Yellow Top Battery, Cobra 29 LTD BT CB Radio --- [B]Exterior Modifications...[/B] 6" Clayton Long arms, Bilstein 5100's, Addco Front and Rear Sway bars, IRO extended rear sway bar links, JKS Trackbar, JKS quicker front disconnects, IRO front upper and lower coil retainers, Rough Country Dual Steering Stabilizers, 17" Fuel Hostage Wheels, 285/70 Goodyear Wrangler Duratracs, Westin Safari bar, PIAA 525 dual beam off road lights, CCFL Halo Projector Headlights w/ Super Vision 6000k HID bulb kit, 100w PIAA 4000k halogen high beams, LED 360 Amber LED signal bulbs, LED Tail Lights, Jet Accu-Speed Computer chip, Flashpaq jeep power programmer, AVS rain gaurds, Yakima 4 Snowboard rack, Curt tow strap receiver mount, Hornblasters Shocker 240 Train Horn Kit, Rigid E-Series 40" LED light bar, Mean Green H.O. Alternator, JCR Stage 3 Sliders, Blue Torch d30/d44a diff covers, KOR Steath rear tire carrier/bumper. LSR winch mount front bumper, Warn xd9000, KOR under Belly skid...
[CENTER][URL="http://www.jeepforum.com/forum/f197/akros-2001-wj-build-1132013/"][B]Akrobatiks Build Thread[/B][/URL][/CENTER]
[CENTER][SIZE="4"][B][URL="www.jamielinkphotography.com"]www.jamielinkphotography.com[/URL][/B][/SIZE][/CENTER]
Akrobatiks is offline   Reply With Quote Quick reply to this message
Unread 06-03-2011, 05:29 AM   #924
snobrdrkid07
Mr. WJ
Thanks guys! Hoping that they will be small enough to squeeze in there! Were you at stock Akro when you installed the 3/4 inch spacers?
-Michael-
For Sale:
Unread 06-03-2011, 06:59 AM   #925
sherker55
You should have plenty of room if you disco the sway and shocks, and then just teeter-totter the axle from one side to the other.
Rear iso's shouldn't be more than $50 shipped for all four t&b
Originally Posted by HaViiK View Post
Send me the number, she can take a ride in a real jeep
Originally Posted by WillMcD View Post
She said call her when your over 4"
sherker55 is offline   Reply With Quote Quick reply to this message
Unread 06-03-2011, 08:39 AM   #926
snobrdrkid07
Mr. WJ
That was what I was thinking. To be able to lift one side a bit to drop the other side down.
Will look into the isolators. Checking rock auto.
-Michael-
For Sale:
Unread 06-03-2011, 08:42 AM   #927
Akrobatiks
No, it was with my 4" RC kit... I'm sure you will be ok, but just wanted to throw ot out there so your at least aware it could.be an issue... I have learned there are always unforeseen issues when you are modifing jeeps, no matter how small the project is, your going to run into something, so its good to have as much info as possible going into it... just my .02
Unread 06-03-2011, 09:57 AM   #928
snobrdrkid07
Mr. WJ
Haha. I hear you man. Thank you!
-Michael-
For Sale:
Unread 06-03-2011, 03:04 PM   #929
Scibbyz99WJ
oh and double check everything! torque all bolts back to spec. a loose rear shock is extremely annoying (trust me i know) it will make noise even on flat roads. and i swear you can hear it over the radio even with subs.
Unread 06-03-2011, 03:30 PM   #930
snobrdrkid07
Mr. WJ
Yea the shocks are annoying as hell already. Need to invest in a torque wrench
-Michael-
For Sale:
ome hd , OME lift kit , snobrdrkid , wj
