Snobrdrkid's WJ Build Thread - Page 61 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
Count Down to KOH Sale!The Original 3/8" Ruffstuff Diff Cover!Steering and more from Ruffstuff!
Unread 06-01-2011, 05:43 PM   #901
straty1987
Originally Posted by snobrdrkid07 View Post
Rear because of the weight of the subs and the towing I do. The rear sits at about 18.4 inches. Spacers will help put it back up. Front sits normal.
And I am getting them from a jeepforum member
Edit: Correct me if I am wrong here, but factory non-UC is 18 front and 19 rear from center of wheel to fender?
oh i know what add your talking about.
look at these http://www.cyberjeep.com/wj/pr/coil-...ar-75-lift-red
non upcountry should be 18 front and 19 rear from center of wheel to fender.
your coils isolators sound shot. replace the bottoms and see if they help, or do both top and bottom. but its around $100 for rock auto. or the link i posted is cheaper for both sets lol and can keep stock springs
what your front measurements?
straty1987 is offline   Reply With Quote Quick reply to this message
Unread 06-01-2011, 05:52 PM   #902
snobrdrkid07
Mr. WJ
snobrdrkid07's Avatar
18.1-18.2 front. And about 18.4-18.5 rear
~ 04 WJ 4.0 | Selec-Trac 242 | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Custom Front D.S. | Stillen Rotors/Metal Matrix Pads | Tow Package w/ 3.73's | Projectors w/ 55w HID H1 5000K Lows | Sylvania Ultra 9005 Fogs | Moog HD Steering | Kenwood eXcelon Radio | Memphis Speakers | Alpine Amps | Alpine Subs | Moog STB SS | Superchips Flashpaq | Auxiliary Transmission Cooler | Rock Lights | Light Bars ~
~ Snobrdrkid's "Build" Thread ~ YouTube Channel ~ Fuelly ~WJ 4.0 Transmission Cooler Info ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | 2" Spacer Lift | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
For Sale:
Front XJ/TJ 2" Budget Boost. PM for details.
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 06-01-2011, 08:02 PM   #903
straty1987
if you can check you coil isolators to see if there worn.
i might be off on the number but i thought it was 18 front and 19 rear from center of wheel to fender since people get 20 front and 21 rear from center of wheel to fender with a 2 inch lift.
Unread 06-01-2011, 08:28 PM   #904
snobrdrkid07
Mr. WJ
I am pretty sure that the 18 19 front and rear respectively. And I know its not sagging. It only went down when I put the subs and all the other crap in there.
-Michael-
For Sale:
Unread 06-01-2011, 09:17 PM   #905
straty1987
oh i ok i got you. this might be better for you. people use it if they load up the jeep heavy and put things on teh itch to help keep the back end up. http://store.fatbobsgarage.com/rear-...kit-p9359.aspx
i can load up the back of the jeep and takes allot to get it to sag. only have notice it with a 30x50lbs sandbags or the back seats and cargo fill with can goods for my cousins eagle award project
Unread 06-01-2011, 09:20 PM   #906
snobrdrkid07
Mr. WJ
Yes I got those for the rear from a Jeepforum member!
Oh I like that air bags. That is really cool! do you have those?
-Michael-
For Sale:
Unread 06-01-2011, 10:16 PM   #907
straty1987
i don't have the air bags yet. its on the list but since i don't haul anything with my hitch i don't need it yet. i know another WJ that has it and lover it. since he halls his motorcycle on the back of his jeep and says it helps get the rear back up to the right height.
Unread 06-02-2011, 06:22 AM   #908
snobrdrkid07
Mr. WJ
Oh okay. That is pretty cool though! The WJ actually handles weight pretty well. When I was towing 4000 pounds it did decently.
-Michael-
For Sale:
Unread 06-02-2011, 09:31 PM   #909
sherker55
Guys, those ^ are not for WJ's...I hope you got the right spacers. Also, replace the isolaters, while you are back there to add the spacers, you might as well replace the iso's too...its logical. and I bet you need to anyway
Originally Posted by HaViiK View Post
Send me the number, she can take a ride in a real jeep
Originally Posted by WillMcD View Post
She said call her when your over 4"
sherker55 is offline   Reply With Quote Quick reply to this message
Unread 06-02-2011, 09:33 PM   #910
snobrdrkid07
Mr. WJ
I got my 3/4 spacers from a Jeep forum member who had them on his WJ. I dont know if I need them at the moment. I was at 19.1 inches before the subs and my junk went in the trunk....
-Michael-
For Sale:
Unread 06-02-2011, 09:48 PM   #911
sherker55
well if you are going to keep your sub box, junk, and continue to tow, then do it!
Unread 06-02-2011, 09:49 PM   #912
snobrdrkid07
Mr. WJ
How much are isolators for the rear? I should do them... I still need to figure out how I am going to shove the 3/4 spacers in! haha
-Michael-
For Sale:
Unread 06-02-2011, 10:20 PM   #913
straty1987
put the isolator in like a BB.
put a lien across the top coils isolator and coils so you can line them up later
get the spring to come out or compress it.
take out to coil isolator.
place 3/4 puck on isolator, and isolator on coil.
and reinstall springs
go over to rocauto and take a look at prices. or can star running number on eBay and Google for cheapest prices
Upper Front: Mopar: 52088 257AB, Moog: K160040, Raybestos Professional: 5771-704
Lower Front: Mopar: 5208 8401, Moog: K160041, Raybestos Professional: 5771-705
Upper Rear: Mopar: 5208 8346, Moog: K160061, Raybestos Professional: 5771-716
Lower Rear: Mopar: 52088 402AB, Moog: K160042, Raybestos Professional: 5771-706
info via http://www.jeepforum.com/forum/f310/...hread-1154164/
Unread 06-02-2011, 10:21 PM   #914
snobrdrkid07
Mr. WJ
Oh okay! thanks! that should not be too hard! going to need a floor jack and some jack stands!
-Michael-
For Sale:
Unread 06-02-2011, 10:39 PM   #915
straty1987
rent a coil compressor at autozone for free.
good info here http://www.nagca.com/grandtech/wjteraflex2lift.htm
ome hd , OME lift kit , snobrdrkid , wj
