Snobrdrkid's WJ Build Thread - Page 46 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINERô UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 05-02-2011, 07:48 AM   #676
snobrdrkid07
snobrdrkid07's Avatar
Originally Posted by Bama_WJ
I ran my stock track bar for a good while with the 2.5" BB and old UC springs. I got the track bar to diagnose a DW issue (which turned out to be TREs). But yea, it was recommended to me to have an aftermarket track bar right when the alignment shop first saw my Jeep. So, I guess it's not absolutely needed but it's recommended.
That is my biggest worry.
Got of the phone with father... he was mad....
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is online now   Reply With Quote Quick reply to this message
Unread 05-02-2011, 10:39 AM   #677
SnowLeopard
He doesn't want you lifting the Jeep?
Yes, it snows in Texas.
SnowLeopard is offline   Reply With Quote Quick reply to this message
Unread 05-02-2011, 11:08 AM   #678
snobrdrkid07
Quote from father "you do not need to spend money on springs when you need to be paying for gas"
-Michael-
Unread 05-02-2011, 12:38 PM   #679
straty1987
well that's true, can fill up the jeep at least one time with lift money and its only going up.
straty1987 is offline   Reply With Quote Quick reply to this message
Unread 05-02-2011, 12:50 PM   #680
1stblack97ZJ
your 18, and its your money.
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
1stblack97ZJ is offline   Reply With Quote Quick reply to this message
Unread 05-02-2011, 01:23 PM   #681
SnowLeopard
He also lives with his parents and lives on their dime. Thus 'discretionary' money is at their discretion.
Unread 05-02-2011, 03:01 PM   #682
Akrobatiks
Yup...! Gotta respect what the p's want...! Even though it may suck right now, your time will come bro! just be patient and keep working on them, they will slide eventually!
2001 WJ Limited 4.7L Black on Black --- [B]Interior Modifications...[/B] Alpine INA-w900 navigation unit, 2 9-inch headrest LCD's, Alpine PDX-F4 125w x 4 Multi-channel Digital amplifier, Alpine Type - X Component Interior Speakers, Alpine PDX-M12 1200w x 1 Digital Mono Sub Amplifier, 2 MTX - 9510's, Custom built subwoofer enclosure, Sirrius Satellite Radio, Backup Camera, Viper 5901 Remote start/alarm, Passport Escort 9500ci Radar Detector/Laser Shifter, Optima Yellow Top Battery, Cobra 29 LTD BT CB Radio --- [B]Exterior Modifications...[/B] 6" Clayton Long arms, Bilstein 5100's, Addco Front and Rear Sway bars, IRO extended rear sway bar links, JKS Trackbar, JKS quicker front disconnects, IRO front upper and lower coil retainers, Rough Country Dual Steering Stabilizers, 17" Fuel Hostage Wheels, 285/70 Goodyear Wrangler Duratracs, Westin Safari bar, PIAA 525 dual beam off road lights, CCFL Halo Projector Headlights w/ Super Vision 6000k HID bulb kit, 100w PIAA 4000k halogen high beams, LED 360 Amber LED signal bulbs, LED Tail Lights, Jet Accu-Speed Computer chip, Flashpaq jeep power programmer, AVS rain gaurds, Yakima 4 Snowboard rack, Curt tow strap receiver mount, Hornblasters Shocker 240 Train Horn Kit, Rigid E-Series 40" LED light bar, Mean Green H.O. Alternator, JCR Stage 3 Sliders, Blue Torch d30/d44a diff covers, KOR Steath rear tire carrier/bumper. LSR winch mount front bumper, Warn xd9000, KOR under Belly skid...
[CENTER][URL="http://www.jeepforum.com/forum/f197/akros-2001-wj-build-1132013/"][B]Akrobatiks Build Thread[/B][/URL][/CENTER]
[CENTER][SIZE="4"][B][URL="www.jamielinkphotography.com"]www.jamielinkphotography.com[/URL][/B][/SIZE][/CENTER]
Akrobatiks is offline   Reply With Quote Quick reply to this message
Unread 05-02-2011, 03:01 PM   #683
snobrdrkid07
Maybe I just need to find someone who is giving out some Up Cntry springs and ill get some 3/4 trim spacers for cheap.
This is true... however that below is also true.
I guess all in good time.
-Michael-
Unread 05-02-2011, 03:03 PM   #684
snobrdrkid07
Yea I do, sadly.
So here is the stipulation... To lift the Jeep it has to cost me $0.00. Challenge ACCEPTED!
-Michael-
Unread 05-02-2011, 03:17 PM   #685
straty1987
$35 a pair
a bit under $90 for front and rear shipped. so kind of a wast compared to get 2" bb for a bit over $100
http://www.cyberjeep.com/wj/pr/coil-...ar-75-lift-red
just save your money up and don't tell them. then a month or 2 later show them how much you have saved on the side. make the point again and see what happens.
cna get the jeep stuck and show that you need a 2" lift to keep it form happening again but might damaged something.
i fell for you man. every time i get something for the jeep my father says something. so i try to keep it stockist without going nuts since he drives it now and then as well as my sister. one of the big reason i cant go allot over 2" is that so many people get in and out that it will be to high.
Unread 05-02-2011, 04:52 PM   #686
snobrdrkid07
$35 a pair
I will save up some more. I just for some reason can't bit the bullet and order a BB out of spite cause i am so worried that I am gonna mess stuff up. (I don't remember If I told everyone about the rubicon nightmare)
I will keep an eye out for someone who wants to help a child out with some extra parts too.
-Michael-
Unread 05-02-2011, 04:57 PM   #687
SnowLeopard
Rubicon nightmare? Well, keep an eye out on JF classifieds. I wouldn't trust CL that much these days. There are a lot of scams, and all you need is to get scammed while trying to get Jeep parts you're not even supposed to be getting in the first place. I'd definitely not go ahead with anything without the parents' consent.
Unread 05-02-2011, 05:03 PM   #688
snobrdrkid07
I sadly agree with not doing anything against parent's will.
Rubicon + 1.5" BB = FAILLLLL
Okay, so we order some aluminum spacers (mind you with 15K on the jeep). Put em on... successes. didn't get an alignment. Month later... DEATH WOBBLE INSANITY. Blew the shocks and the SS. Got new aftermarket shocks and a bigger aftermarket SS. (which I know now is a band-aid fix) Alignment. That kinda helped. DW was still there. Got a JKS ADJ TB and got new Goodyear Kevlar MT/R tires. Alignment by and Off-road shop. That pretty much fixed the insane DW. We still have terrible bump steer and major 45-65 mph vibes like crazy... Basically a 100 dollar boost turned into 2200 dollar nightmare... with services, alignments, tires, parts, shocks, PIA'ness.
Ideas to fix vibes and bump steer please help me out.
-Michael-
Unread 05-02-2011, 05:24 PM   #689
straty1987
that might be the reason why your dads saying no lift.
i like the look wheel spacers give but they but so much stress on the axial
and this can happen Attachment 224829
Unread 05-02-2011, 05:43 PM   #690
SnowLeopard
Is it an Unlimited(4-door)? I'd imagine a lot of geometry is changed with even 2 inches of lift on a 2 door, shorter wheel-base Wrangler. They have driveshaft angles, transfer case angle, swaybar links, etc. to consider. I'd think somewhere along the line you have something off, but I'm not close to an expert here.
ome hd , OME lift kit , snobrdrkid , wj
