Snobrdrkid's WJ Build Thread - Page 442 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
KrawlOff-Road.com Sale EventFS: Jeep Fog Light LED Bulbs! Several Brightness Options! *STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light Ba
Unread 07-09-2014, 11:53 AM   #6616
snobrdrkid07
snobrdrkid07's Avatar
I believe it looks like this pictured below, I am getting it for free and actually haven't seen a picture of it!
I probably need a new high pressure line as well, starting to get wet and possibly a drip or two.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 07-09-2014, 12:02 PM   #6617
Thomahawk
Thomahawk's Avatar
^^^Thats the one, from my old green WJ, 2000 model, it should mount up easy, you should have it in about a week i believe.
Buildthread http://www.jeepforum.com/forum/f197/...grade-1813490/
Thomahawk is offline   Reply With Quote Quick reply to this message
Unread 07-09-2014, 12:32 PM   #6618
snobrdrkid07
Nice man! There are so many radiator setups over the 5 years and 6 and 8 Cylinder engines. It'll be nice to toss it in there!
This is all that I think is right.
I6's:
99-03: Had a Radiator and Trans Cooler in one and then a the AC condenser. E-Fan only unless it has the tow package which included the mechanical fan.
2004: Has a "Coolant Only" main radiator and the AC condenser is split between the Trans fluid and the Refrigerant. E-Fan only unless it has the tow package which included the mechanical fan.
V8's:
99-01: Radiator with Trans cooler in one, AC condenser up front. Mechanical Fan, E-Fan, or Both?? Tow packaged added the small power steering cooler on the driver's side.
02-04: Radiator with Trans cooler in one, AC condenser up front. Hydraulic Fan with the large power steering cooler on the passenger side with metal lines. Tow package added??
-Michael-
Unread 07-17-2014, 11:53 PM   #6619
snobrdrkid07
Got the power steering cooler from Thomahawk today, it is in great shape.
I've got some OEM Chrome tow hooks coming soon too. Once I get everything here, I'll pull the front bumper and fascia and do all that at once. I'd like to try and reroute the ATF cooler lines if I can find space.
-Michael-
Unread 07-27-2014, 12:04 PM   #6620
Cirruslydakota
Following in my footsteps I see Although there are differences since I'm a 99 and you're an 04.
Made my own "4.0 Class V towing package" by adding the 99 V8 power steering cooler and adapting the 2000 V8 power steering/hydraulic fan cooler as a aux transmission cooler. Its a tight space to work in but all the lines run through the same area. Works well and keeps temps cool during heavy towing or mountain climbing.
Bear - 1999 Jeep Grand Cherokee Laredo
Apollo - 2008 Mazdaspeed3
Vivienne - 2015 Chrysler 200S
Cirruslydakota is offline   Reply With Quote Quick reply to this message
Unread 07-27-2014, 12:44 PM   #6621
snobrdrkid07
Ha, I sure am following down that way! Only difference is my transmission fluid runs through the AC condenser and the radiator is 100% coolant. Do you have any insight or pictures on how you hooked up the power steering cooler?
-Michael-
Unread 07-27-2014, 12:59 PM   #6622
Cirruslydakota
Its been a few years since I did it but these pictures from the FSM should help for now. Ill take some pictures for you when I go out later.
Those are from my 99 service manual so itll probably be different depending on how the transmission lines for your cooler run on yours. Remember, mine has the cooler in the radiator so the lines are tucked close to the radiator out of the way.
Unread 07-27-2014, 01:22 PM   #6623
snobrdrkid07
Thanks for that, I also found this picture. Which I am going to try and follow. I bought a new piece of line with a fitting on it and about 12" of hose. Thinking of running the new hose to the cooler and using old hose from the cooler back to the reservoir.
-Michael-
Unread 07-27-2014, 03:14 PM   #6624
Cirruslydakota
These should help since they show the original hose routing when it was an option on the 4.0.
Unread 07-28-2014, 11:13 AM   #6625
snobrdrkid07
I bought this to go from the steering box to the cooler. However I am thinking of taking the line of the reservoir and putting that on the cooler and getting more PS line and running it from the cooler to the reservoir.
-Michael-
Unread 07-30-2014, 06:10 PM   #6626
snobrdrkid07
Finally topped off the coolant reservoir with some Zerex G-05 HOAT, only been a little low for a year. Added about a half gallon to bring it up to the "Full".
Got some sweet factory chrome tow hooks from a good friend, 04Overland47. Going to replace the junk hooks that are on there, harbor freight special.
Hopefully I can get the power steering cooler in this weekend too.
-Michael-
Unread 08-03-2014, 01:11 PM   #6627
snobrdrkid07
Things accomplished Saturday
1. The new oem tow hooks on, old ones were bad and rusted nor were they factory.
2. New Mopar serpentine belt. The dealer was the closest. Easy to do, it was the original belt with 124k on it
3. Air box is actually fasten down now. Lost a nut prior and it had be squeaking.
4. Added more rubber wrap around the trans cooler lines. Peace of mind there
5. Power steering cooler. Hmmm, with the way my factory transmission lines run to the air con condenser I don't think the metal hard lines will fit. So no power steering cooler as of now.
6. Dad scratched the grille by dragging it across the garage floor on accident. Ughhhh
7. Glued some of the header panel back together that had been cracked, minor.
8. Cleaned air filter with air compressor. Been using the wix paper air filter and it's been good.
9. Tried moving the SS bracket closer in. Couldn't bend it enough for the larger diameter of the tie rod and the bolt was hitting the rod. Will have to source another clamp.
Productive weekend.
-Michael-
Unread 08-03-2014, 02:11 PM   #6628
ChrisHager
ChrisHager's Avatar
Sounds like a busy weekend!
I wouldn't sweat it. I have to watch scratching the J-10 with my belt buckle and clipped on pocket knife. The worst is my cowboy boots clipping the rocker panel when I get in. It is chipped up quite a bit. Oh, country lifestyle...
Heat is worth its weight in gold...
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
His: 2009 Expedition
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline   Reply With Quote Quick reply to this message
Unread 08-03-2014, 02:19 PM   #6629
snobrdrkid07
It was, but it was good.
I'm going to try some rubbing compounds or something to try and buff it out. Not the end of the world just wasn't ideal.
Clarifying, I was able to bend it enough to remove it from the tie rod. The issue was the holes weren't low enough for the bolt to pass through. The bolt was bottoming on the tie rod bar. Tried drilling the clamp holes but wasn't enough without taking off a lot of material. I can draw a crude picture later. And I'll post pictures this evening as well.
-Michael-
Unread 08-03-2014, 03:26 PM   #6630
snobrdrkid07
No, I don't know how the radiator support got bent! Lol
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
