Snobrdrkid's WJ Build Thread - Page 438 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!
Unread 03-20-2014, 11:43 PM   #6556
SnowLeopard
That is a long list, but to be honest, those prices aren't that bad. I've seen a lot worse come from dealerships.
Yes, it snows in Texas.
SnowLeopard is offline   Reply With Quote Quick reply to this message
Unread 03-24-2014, 10:37 AM   #6557
snobrdrkid07
Mr. WJ
snobrdrkid07's Avatar
Black Ground wire and Orange/White wire broke in the driver's boot... I am angry, it's been fixed once already.
~ 04 WJ 4.0 | Selec-Trac 242 | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Custom Front D.S. | Stillen Rotors/Metal Matrix Pads | Tow Package w/ 3.73's | Projectors w/ 55w HID H1 5000K Lows | Sylvania Ultra 9005 Fogs | Moog HD Steering | Kenwood eXcelon Radio | Memphis Speakers | Alpine Amps | Alpine Subs | Moog STB SS | Superchips Flashpaq | Auxiliary Transmission Cooler | Rock Lights | Light Bars ~
~ Snobrdrkid's "Build" Thread ~ YouTube Channel ~ Fuelly ~WJ 4.0 Transmission Cooler Info ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | 2" Spacer Lift | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
For Sale:
Front XJ/TJ 2" Budget Boost. PM for details.
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 03-24-2014, 10:39 AM   #6558
ChrisHager
ChrisHager's Avatar
Fix it again! Haha. That happens. It's a thick wire and bending thick wires isn't good... Sucks though.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
ChrisHager is online now   Reply With Quote Quick reply to this message
Unread 03-24-2014, 10:43 AM   #6559
snobrdrkid07
Mr. WJ
I'm running out of wire to work with. I am doing a crimp in the door and running new wire all the way inside to another crimp connector. Hopefully this wire I am splicing will last longer...
-Michael-
For Sale:
Unread 03-24-2014, 10:58 AM   #6560
ChrisHager
ChrisHager's Avatar
Try soldering? It's a pain but that's what I did and so far, so good...
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 03-25-2014, 07:39 AM   #6561
snobrdrkid07
Mr. WJ
Don't have my soldering gun here at school. I made a connection in the boot and then ran new wire all the way into the body where I made the second connection. Hopefully that will help.
-Michael-
For Sale:
Unread 03-25-2014, 07:59 AM   #6562
ChrisHager
ChrisHager's Avatar
That might do it for ya!
Does the Torque app actually tell you when the fan kicks on or do you literally just stand aside and wait until it turns on? I was going to check it for you this morning but I couldn't find a widget dealy in the app that would notify me when the fan kicked on.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 03-25-2014, 08:00 AM   #6563
snobrdrkid07
Mr. WJ
The wire was so brittle and sun damaged too!
Oh, going to have to just wait for it to kick on and then look at the temp reading.
-Michael-
For Sale:
Unread 03-25-2014, 08:13 AM   #6564
ChrisHager
ChrisHager's Avatar
Roger that!
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 03-25-2014, 04:36 PM   #6565
snobrdrkid07
Mr. WJ
Thanks man!
You jinxed me with the Power Steering, Chris. I am leaking a bit of fluid around the high pressure line fitting.
-Michael-
For Sale:
Unread 03-25-2014, 08:35 PM   #6566
ChrisHager
ChrisHager's Avatar
Oh no!!! I looked mine over and I think it may be a leaky line too...
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 04-11-2014, 04:04 PM   #6567
Thomahawk
How is things going with you and your Jeep Michael? Long time, no update,,,?
Buildthread [url]http://www.jeepforum.com/forum/f197/jeep-norway-2th-buildt-overland-upgrade-1813490/[/url]
Thomahawk is offline   Reply With Quote Quick reply to this message
Unread 04-12-2014, 02:10 AM   #6568
snobrdrkid07
Mr. WJ
It's been running good recently, I still have some slight lifter tick on the cold morning until it warms up and pumps up. I just figured I am going to let that go, warmer weather has helped stifle that issue. I've had IRO UCA's sitting on my floor since December and a RC-X steering stabilizer on the floor too. My Moog SS bushing kinda blew out and are soft. I've just been driving it and putting gas in it, kinda nice to just enjoy it recently. Took that road trip in the end of February and that was fun.
Now that warmer weather is happening, I'll be more likely to tool around.
-Michael-
For Sale:
Unread 04-16-2014, 09:55 AM   #6569
snobrdrkid07
Mr. WJ
Eating my words with everything being good, although i knew this was going to eventually happen. I'm getting a clunk feeling through the floorboard on the drivers side where the left foot rest pad is. I've checked the jam nuts on the LCA's. I've never ever done anything with the front uppers... I'm wondering if the upper frame side bushings took its last beating. I notice it on bumpy roads where I'd assume it'd be doing the most work, also sometimes when on the brakes hard I'll feel it. Ohhhh fun.
-Michael-
For Sale:
Unread 04-16-2014, 06:16 PM   #6570
snobrdrkid07
Mr. WJ
Finally got a wrench out for the WJ. Checked all the LCA bolts, the Driver's side, frame side bolt, was "loose". Well I had my wrench set at 140 lb-ft and I was able to turn before it clicked a few times. For comparison, none of the other 3 bolts were able to turn before clicking. Didn't test drive after that but will post back later.
Went on a cruise
-Michael-
For Sale:
ome hd , OME lift kit , snobrdrkid , wj
