Snobrdrkid's WJ Build Thread - Page 435 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
KrawlOff-Road.com Sale EventFS: Jeep Fog Light LED Bulbs! Several Brightness Options! *STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light Ba
Unread 02-16-2014, 12:50 PM   #6511
Thomahawk
Thomahawk's Avatar
Thats excactly why i love my QD FULTIME
Its a winner in snow, just saying,
FULLTIME! HA HA
Buildthread http://www.jeepforum.com/forum/f197/...grade-1813490/
Thomahawk is offline   Reply With Quote Quick reply to this message
Unread 02-16-2014, 02:40 PM   #6512
snobrdrkid07
snobrdrkid07's Avatar
I wish I had the Quadra-Drive system with a 242 in place of the 247
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 02-16-2014, 02:56 PM   #6513
Thomahawk
Thomahawk's Avatar
^^^Yeah, That would be the ultimate upgrade combo.
I actually have a 242 from a ZJ just laying around, idk if that would Work though.
Got to love the LSD diff in snow, best there is
Unread 02-16-2014, 03:01 PM   #6514
snobrdrkid07
Even the open/open combo in my WJ did great in the snow while the TJ and LJ were getting stuck! Only thing that was concerning was that when the front dug and tried to grab it'd sometimes "hop" and create a hell of a banging/rattling. Only when the front tire(s) were hopping. This was when I was in 4 Part-Time or 4 Full Time, in the snow. What was happening was the front was trying to grab so it was loading the tire, then it'd break the snow pack and drop down and then bind/load up again. Then doing that on repeat. I was able to grab the front output yoke on the t-case and shake that thing around... up and down movement. I *don't* think it is supposed to have that kind of slop in it.
-Michael-
Unread 02-16-2014, 03:16 PM   #6515
Thomahawk
Thomahawk's Avatar
Nah, That slop should be there, any highway vibs?
Unread 02-16-2014, 03:17 PM   #6516
snobrdrkid07
Above ~70-75 mph i'll get slight vibes...
-Michael-
Unread 02-16-2014, 03:36 PM   #6517
Thomahawk
Thomahawk's Avatar
^^^Time for a 247 upgrade, or if lucky only yoke or smaller parts, didnt you Get a new rebuildt front DS when you did the lift?
Unread 02-16-2014, 10:00 PM   #6518
SnowLeopard
I agree with Thomahawk regarding the 247 being superior to the 242. Even if he is perhaps having fun with you here. Though I like being able to lock in 4wd-high, the LSD function is superior to the open diff of the 242. Running a torsen diff in the 4Runner I'm currently driving I've come to appreciate not having an open diff in the middle. It's as much night and day better than having an open diff in an axle. Still, the 242 is a great option. I'd just not prefer one over the 247 knowing what I know now.
The downside is waiting for it to respond to slippage where as the 242 is always splitting torque when engaged in full-time. That and the 247 requires a lot more upkeep. Of course, your 242 is not without its associated issues, as you are seeing.
Yes, it snows in Texas.
SnowLeopard is offline   Reply With Quote Quick reply to this message
Unread 02-17-2014, 03:13 PM   #6519
snobrdrkid07
I've been getting better with it the past couple days too. Learning how to finesse it in and out of 2wd/4wd with improvement. I do like having the Full Time option so I can not worry about binding on the road while the conditions aren't "bad" enough to warrant Part Time. Also part time doesn't like to steer, being it locked in the center.
-Michael-
Unread 02-17-2014, 04:06 PM   #6520
Thomahawk
Thomahawk's Avatar
Thats the Nice thing with the QD center, it doesnt look up and goes straight forward when throttled in curves, the locked ones keeps to "push" the front wheels straight forward.
When the QD seems to push out the rear so the front wheels goes into the curve not out. My old S10 Blazer was like locked, the QD behavious in a whole different matter, like you Are able to stear the rear end with the Throttle, like drifting cars.
Unread 02-17-2014, 06:12 PM   #6521
SnowLeopard
Without binding as in full lock a lsd center diff will allow your vehicle to actually pull you through a turn, steering, yet allowing differential movement so you don't understeer as you would with full lock. I'm not sure if this is how QD works, but I know torsen diffs do this. Getting used to the idea of pushing through a turn instead of laying off the gas takes a little getting used to.
Unread 02-17-2014, 06:38 PM   #6522
Thomahawk
Thomahawk's Avatar
^^^Yes that would be how the QD works, kinda like a torsion diff, right.
It pulls you in rather than push you out, hard for me to explain in my poor english.
Unread 02-21-2014, 02:35 PM   #6523
snobrdrkid07
Slathered some grease all over the double cardon joint. Hopefully that shuts it up.
Update, killed the sound for now. Splattered everywhere. Hah.
Update 2. Changed the oil again to start fresh. Going to see if that OPDA was the source of the metal.
-Michael-
Unread 02-25-2014, 05:11 PM   #6524
snobrdrkid07
Passenger side ground wire broke inside the boot as they all do. Spliced in some new wire and called it a day, easy fix.
Changing the oil has seemed to make the WJ unhappy. Since changing, 3 cold (20-40*) start ups have resulted in, assuming valvetrain, noise. Takes a minute or two now for it to stop. Was suggested that oil filter could have a bad back flow valve? Who knows. 1 step forward two steps back.
Secondly, I've mentioned this before but, my oil gets pitch black very quickly. The oil I took out had less than 900 miles and looked like it was 9000 miles old. Suggested to inspect the PCV system for leaks/clogs.
-Michael-
Unread 02-25-2014, 05:18 PM   #6525
Thomahawk
Thomahawk's Avatar
Seafoam the shhh out of it!!!
ome hd , OME lift kit , snobrdrkid , wj
