Snobrdrkid's WJ Build Thread - Page 433 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
Income tax season is upon us. We got what u needRough Country Lift Kits and Parts!Ruffstuff 10 year sale
Unread 02-03-2014, 04:38 PM   #6481
Thomahawk
Thomahawk's Avatar
Glad to hear that, Thumbsup
Buildthread http://www.jeepforum.com/forum/f197/...grade-1813490/
Thomahawk is offline   Reply With Quote Quick reply to this message
Unread 02-04-2014, 11:16 AM   #6482
Cirruslydakota
Too bad you couldnt ask for the old one back. Id love to take it apart and see what caused the failure considering the OPDA seems to fail in a similar fashion.
Bear - 1999 Jeep Grand Cherokee Laredo
Apollo - 2008 Mazdaspeed3
Vivienne - 2015 Chrysler 200S
Cirruslydakota is offline   Reply With Quote Quick reply to this message
Unread 02-04-2014, 11:29 AM   #6483
snobrdrkid07
snobrdrkid07's Avatar
I got another call from the dealer today. They told me the OPDA is hitting the cam sensor itself. So they're replacing the OPDA for about $450, which is the part cost and the new sensor. I swear if they put that horrid assembly on it like the 05/06 TJ's have I'm going to flip out. The 04 and prior OPDA haven't really had these issues.
I'll ask them to keep the old part. If I can get a hold of it, I'll send it your way.
Edit: Called them and requested the keep the old OPDA.
Edit 2: Also called them to make sure they replace the part with the original sensor (Top) and not the craptastic stuff that the 05/06 TJ's have. (Bottom)
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 02-04-2014, 05:40 PM   #6484
Cirruslydakota
If it was hitting the sensor then thats bearing failure. Hmm, I haven't heard of our opda's failing like the wrangler ones especially at the relatively low mileage you have (compared to mine anyway).
Unread 02-04-2014, 06:13 PM   #6485
snobrdrkid07
That is what the dealer said, the OPDA had a bearing failure. This one went at 119k and the Rubicon we have, failed at 42k. Again I requested to keep the old assembly, we'll see if they follow through.
-Michael-
Unread 02-04-2014, 08:00 PM   #6486
Cirruslydakota
They should since theres no core charge on it. This is the first failure of our type of opda that Ive heard of.
Unread 02-04-2014, 08:02 PM   #6487
snobrdrkid07
Just my luck! First I've heard of it in the WJ.
I wonder if this bearing failure in the drive was causing excess metal wear to show up in my oil??
-Michael-
Unread 02-05-2014, 04:13 PM   #6488
snobrdrkid07
Got the Jeep back just now, so nice to have a car again, missed it a lot!
Parts:
OPDA, which was different from the 04 WJ parts list PDF that I have. 53010615AB
Thankfully they replaced with the original one and not the crap from the 05/06 TJ's.
**I asked about the old OPDA, they "lost it" : Sorry man.
-Michael-
Unread 02-05-2014, 05:51 PM   #6489
Cirruslydakota
No problem, not a big deal.
They lost it...haha, suuuuure...
Also that p/n is correct. The old one was superceded. Probably a design change (due to bearing failures perhaps?).
Unread 02-05-2014, 05:53 PM   #6490
snobrdrkid07
Yeah, no kidding, disappeared into thin air.
Thankfully, no more awful sounds coming from the engine.
-Michael-
Unread 02-05-2014, 05:56 PM   #6491
Cirruslydakota
Sometimes we lose stuff in my shop but with everything big and yellow its hard to misplace things.
Unread 02-05-2014, 05:58 PM   #6492
snobrdrkid07
True, who knows. Guess I am ground zero for the WJ OPDA to fail. I still haven't found anyone else yet, albeit didn't search that hard.
-Michael-
Unread 02-05-2014, 07:06 PM   #6493
Cirruslydakota
You're the first ive heard of it. Usually its the cmp sensor going bad.
Unread 02-09-2014, 08:33 PM   #6494
snobrdrkid07
Haha, I feel special.
My double cardon joint is squeaking, can I squirt some grease on, in or around the centering ball?
-Michael-
Unread 02-09-2014, 09:17 PM   #6495
ChrisHager
ChrisHager's Avatar
I dont know why you couldn't...
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
His: 2009 Expedition
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline   Reply With Quote Quick reply to this message
ome hd , OME lift kit , snobrdrkid , wj
