Snobrdrkid's WJ Build Thread - Page 432 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 01-28-2014, 12:36 PM   #6466
snobrdrkid07
snobrdrkid07's Avatar
I've been running the high(er) dollar Mobil 1 10w-30 Full Synthetic High-Mileage for the added ZDDP content in it. However, it has been brought to light that they have changed their formula for the oil. Sadly, lessening the ZDDP content which is no good for us with the 4.0's. I've heard of people running Rotella T6 10w-30, which I think is synthetic. Does the T6 have a lot of ZDDP and a HDEO? Maybe I will make the switch over to that. My last oil analysis had 900 whereas a year ago it was over 1000. Think I should look into switching to Rotella?
Edit 2: Mobil 1 says that the High Mileage, Synth, 10w-30 should still have 1100 ZDDP PPM whereas my last oil sheet said 900. pdf sheet link
The 05/06 TJ/LJ OPDA was an insane problem, never really knew about it. Untils the OPDA on the 05 LJ busted with 42,000 miles on the odometer. (This happened a few months ago in October). Because of the tools needed to do it properly, scanners, etc. I'll just have the big Jeep dealer up by school deal with it.
Edit: 10 Best Engines of the Last 20 Years. Looks what came in 8th place! haha
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 01-28-2014, 03:02 PM   #6467
snobrdrkid07
Let's add this into the mix. Leaving school, I noticed the squeak/tap was intermittent a few seconds after start up and then become steady. Started driving home, came to a stoplight and the Jeep started to bog down at idle, around 250 rpms if I had to guess and was running rough and "chugging" and then died. Fortunately I was able to start it back up and make it a few more miles back home.
Read all the codes and this is what it came up with:
I think that sounds has to be that camshaft position sensor, it fits what is going on, IMO.
-Michael-
Unread 01-28-2014, 03:18 PM   #6468
ChrisHager
ChrisHager's Avatar
If I had to guess, I'd agree with your hypothesis. If I hadn't just taught class last night and therefore was not still in 'instructor mode', I'd have said something along the lines of 'Yup, slap a new one of those spinny timing dealies on there and see if she fires up!'.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
His: 2009 Expedition
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is online now   Reply With Quote Quick reply to this message
Unread 01-28-2014, 03:52 PM   #6469
snobrdrkid07
Lets hope I am right this time around.
Booked an appointed the Dealership for Monday, oh joy.
-Michael-
Unread 01-28-2014, 06:18 PM   #6470
Cirruslydakota
T6 only comes in 5w-40 flavor (full synthetic). T5 is a semi synthetic and comes in 10w-30/10w-40 flavors. Its up to you what to run (personally I run T5 10w-30 but with you being up north I'd run T6 especially in this weather).
The problem I have with the OPDA is Chrysler already had the system we use in the Grand Cherokee but didn't use it in the wrangler. Why?
Bear - 1999 Jeep Grand Cherokee Laredo
Apollo - 2008 Mazdaspeed3
Vivienne - 2015 Chrysler 200S
Cirruslydakota is offline   Reply With Quote Quick reply to this message
Unread 01-28-2014, 06:59 PM   #6471
snobrdrkid07
Why is T6 only in 5w-40? I like synthetic though, don't know why. Is that too thin? (Need to refresh my self on the oil weight nomenclature)
I wonder why they switched either, doesn't make sense.
-Michael-
Unread 01-28-2014, 07:09 PM   #6472
Cirruslydakota
Because these oils (Rotella) are primarily diesel engine oils. T3 is their regular 15w-40 and T6 is their synthetic line.
First number is the cold weight 5 and the second number, 40 is the hot weight. The WJ 4.0 calls for a 10 weight cold oil down to 0 if I'm remembering correctly and below 0 it calls for a 5 weight. Running either a 10 or 5 won't hurt anything (5 will pump faster) and the 30/40 won't hurt either although a 40 weight may cause your gas mileage to suffer a bit due to pumping losses with the heavier oil. If you have valvetrain noise and want those lifters quieter drop in a 40 weight oil.
Also, no Rotella is marked with the "energy conserving" label. I can't remember if Mobil 1 is or not so you may notice slightly worse gas mileage.
Unread 01-28-2014, 10:37 PM   #6473
snobrdrkid07
Thank you for the information, I'll consider pouring in some T6 for the next oil change.
-Michael-
Unread 01-29-2014, 09:56 AM   #6474
Cirruslydakota
My 4.0 seems to like it. Every engine is different though.
Unread 01-29-2014, 10:18 AM   #6475
snobrdrkid07
Rust Prevention Step 1: Cover Jeep in Salt. Lol
http://s1220.photobucket.com/user/sn...4_960.jpg.html
Died on me again today, probably shouldn't be driving it.
-Michael-
Unread 01-29-2014, 10:26 AM   #6476
ChrisHager
ChrisHager's Avatar
Probably not...
Mine is covered almost up to the windows. It's a sad sight...
Click Free:
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 01-29-2014, 10:28 AM   #6477
snobrdrkid07
Oops, copied the wrong link. Thanks!
I'll bum a ride to class the next few days. Lol
-Michael-
Unread 01-31-2014, 12:11 PM   #6478
snobrdrkid07
Drove to class this morning, started fine. Went to leave and it would crank but not catch. It's done.
Called for a tow truck and they got it out of the parking spot, in the parking garage. Front tires of the ground and real wheels still on the ground. Well I forgot to put the transfer case in neutral. Tow truck driver, while pretty nice, didn't seem to think that was an issue and I didn't think much of it. Well too little to late, reading around, turns out that wasn't the best.
So the Jeep will get looked at Monday and they'll do a diagnostic thing and go from there. Already $200 in for the tow in the diagnostics. Hopefully they won't have to add a transmission into that repair list.
Couldn't get a loaner car because I'm not 21, nice and pissed there. I asked if I could buy a new Grand Cherokee for a week.
-Michael-
Unread 01-31-2014, 05:14 PM   #6479
Thomahawk
Thomahawk's Avatar
Drove to class this morning, started fine. Went to leave and it would crank but not catch. It's done. Called for a tow truck and they got it out of the parking spot, in the parking garage. Front tires of the ground and real wheels still on the ground. Well I forgot to put the transfer case in neutral. Tow truck driver, while pretty nice, didn't seem to think that was an issue and I didn't think much of it. Well too little to late, reading around, turns out that wasn't the best. So the Jeep will get looked at Monday and they'll do a diagnostic thing and go from there. Already $200 in for the tow in the diagnostics. Hopefully they won't have to add a transmission into that repair list. Couldn't get a loaner car because I'm not 21, nice and pissed there. I asked if I could buy a new Grand Cherokee for a week.
Good luck man, hope its an easy fix and not to expensive
Buildthread http://www.jeepforum.com/forum/f197/...grade-1813490/
Thomahawk is offline   Reply With Quote Quick reply to this message
Unread 02-03-2014, 04:18 PM   #6480
snobrdrkid07
Got a call back from the dealership, fortunately, I was right. Bad cam sensor, causing the knocking/squeaking sound, and the no-start conditions. Along with the rest of the codes. Damage was only $250 all said in done. (Plus $85 for towing, but the insurance covered that.)
Fingers crossed this does it, and the transmission isn't messed up from towing.
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
