Snobrdrkid's WJ Build Thread - Page 431 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINERô UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 01-27-2014, 07:32 PM   #6451
billzcat1
Chicken in a Turkey Suit
2003 WJ
Get a mechanic's stethoscope. They are about $10 and will help you track down the noise much much better. Invaluable tool IMO.
TBH though it sounds like a lifter/cam lobe got chomped up, 4.0 style.
billzcat1 is offline   Reply With Quote Quick reply to this message
Unread 01-27-2014, 09:35 PM   #6452
snobrdrkid07
snobrdrkid07's Avatar
I'll see if my same friend has one, probably does. It was dark, cold, and were short on time, I just wanted him to look at it quickly. But will see if I can do that this weekend.
How does these stout 4.0's go like this, I'm a bit more disappointed that even well taken care of it is shatting a brick.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 01-27-2014, 11:17 PM   #6453
Cirruslydakota
When i pulled my lifters out they had gone from being convex to concave but not worn through. Can lobes looked pretty good along with everything else. I know the TJ guys have opda problems but our distributor drives seem to hold up well. As far as im aware mines the original one. If you pull it out you'll have to re sync your injectors.
Bear - 1999 Jeep Grand Cherokee Laredo
Apollo - 2008 Mazdaspeed3
Vivienne - 2015 Chrysler 200S
Cirruslydakota is offline   Reply With Quote Quick reply to this message
Unread 01-27-2014, 11:36 PM   #6454
snobrdrkid07
We had our ODPA fail on the trail in the 05 LJ. Looks like Chrysler replaced it with the same POS part that'll fail again. I've been reading about that whole ODPA thing since you posted about it.
Read through a lot of this http://www.jeepforum.com/forum/f9/20...ilure-1144202/
Now that I've read some more, and watched these videos, my noise seems similar?
What do you all think?
How complicated is it to do that? I thought you needed the DRBIII tool to do it?
-Michael-
Unread 01-28-2014, 07:04 AM   #6455
ChrisHager
ChrisHager's Avatar
Removal and installation only takes 15 minutes. Syncing it requires the DRBIII tool. If you install it correctly, you'll have no issue driving it to the dealer for the sync.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
His: 2009 Expedition
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline   Reply With Quote Quick reply to this message
Unread 01-28-2014, 09:25 AM   #6456
snobrdrkid07
Well, at that rate. I might consider just having them deal with it. Removing and replacing.
-Michael-
Unread 01-28-2014, 11:08 AM   #6457
billzcat1
2003 WJ
They aren't as bulletproof as everyone thinks. Time spent on this forum should reinforce that.
Unread 01-28-2014, 11:25 AM   #6458
Thomahawk
Thomahawk's Avatar
^^^X2, maintainance is a preventive move, not a security for that nothing will ever brake down.
Both 4.7 and 4.0's have their problems, i realize that now after i have been around for awhile.
Still around
Anyway, worst case scenario,,, an engine swap down the Road aint to much to worry about,
The 4.0 is easy to pull, weekend project
Buildthread http://www.jeepforum.com/forum/f197/...grade-1813490/
Thomahawk is online now   Reply With Quote Quick reply to this message
Unread 01-28-2014, 11:37 AM   #6459
snobrdrkid07
Well you're right on that one. Granted the majority of 4.0 problems were the 99-01 cracked heads. But in its defense, my other Jeep likely has over 330k miles on the 4.0 and its still going, somehow.
Did you take a look at the recent two videos I posted? I swear, it sounds like its squeaking more than tapping.
-Michael-
Unread 01-28-2014, 11:41 AM   #6460
ChrisHager
ChrisHager's Avatar
Agreed. Remember my lifter incident after 87k? The PO had regular oil changes done by the dealer. Ironically, I later found out the dealer changed a lifter (not plural) for the PO at 66k (and a 242 at 80k??). Most likely, they didn't pull the camshaft and inspect the lobes. My 87k failure was probably due to Jeep's cheap fix (thanks, Jeep ).
That being said, why the failure at 66k? I have heard a time or two about these 4.0s eating lifters which negates 'bulletproof', especially considering the work involved requires removing the head.
I'm not trying to dog these things and I love mine but as said, they aren't indestructible, just as the 4.7 can drop valve seats if overheated. Both are great and neither are perfect!
Anyway, camera wasn't being kind that day but you get the point.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 01-28-2014, 11:55 AM   #6461
snobrdrkid07
Thomas, I guess all you can do is maintenance and get lucky from there on. I would have never thought my Jeep would eat a lifter (*presumably*) with 120k and strict maintenance. I've been following your thread about your new 4.7 HO having issues too.
Chris, I didn't know that a lifter had been previously replaced before you had to do the tear down. Well, I don't even have words to say for that one. Shoot, how the heck did the blow the transfer case, I don't know if someone was abusing it or the dealership was ripping said person off.
The motors are great, but nothing is perfect. Actually my check engine light went away for the IAC and the Cam Position Sensor/Crank Position Sensor. Is the camshaft or lifter iron? Wonder if that was the source of the high metal?
I've got a few options, in order of likelihood:
1. Drive it, try to determine lifter or Cam Pos Sensor, then ignore it
2. Drive it and replace the Cam Position Sensor Assembly
3. Rebuild the motor, along with the trans
4. New motor, stroked
-Michael-
Unread 01-28-2014, 12:15 PM   #6462
ChrisHager
ChrisHager's Avatar
With that squeak and the code, I'd guess CPS over lifter but that's all speculation without actually diving in. I wouldn't ignore it though as that second video showing the noise in sync with the engine rpm sounds crappy...
Edit: The only thing I can think of with my transfer case is the PO possibly thought Part Time was for on road and Full Time was for off road. Ultimately, the vehicle was in great shape when I bought it - nice enough that I guessed it was soccer mom driven and garaged parked.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 01-28-2014, 12:21 PM   #6463
snobrdrkid07
Yeah, I am going to call the dealership today or tomorrow. Gonna have them put in a new Cam Sensor Assembly.
-Michael-
Unread 01-28-2014, 12:25 PM   #6464
Cirruslydakota
Due to oil being changed so much in the last 10-15 years id say anyone with a flat tappet motor needs to pay close attention to the oil they use. In the case of our 4.0's running a HDEO is the best thing to do (Nothing special either like synthetic). The 4.7 guys dont have to worry with the same issue so any 5-30/10-30 works for them. As far as the OPDA issue goes I havent seen or heard many problems with our type of drive causing issues like what the TJ guys haveto deal with. Not saying its not possible but pulling it out and checking it wouldnt be a bad idea by any means. Only downside is seting the sync perfect but if you punch mark the drive base and the block then you should be able to get it back in almost exact. I recently aquired a Snap-on solus ultra and it does fuel sync but its $2,600 so its not pratical unless youre a mechanic (I am.)
Unread 01-28-2014, 12:32 PM   #6465
ChrisHager
ChrisHager's Avatar
Rotella T-5 10W-30
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
ome hd , OME lift kit , snobrdrkid , wj
