Snobrdrkid's WJ Build Thread - Page 430 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 01-07-2014, 03:49 PM   #6436
Thomahawk
Thomahawk's Avatar
Originally Posted by snobrdrkid07
Everyone knows how cold it is around the US right now. Started the WJ up in the single digits temps. I don't know what was clanking, shot a video of it. Likely nothing I can do about it but it sounded like hell so I thought I would share. http://www.youtube.com/watch?v=gPfgf-HCjwM Actually started right up too.
Shhh, sounds almost like my engine tick, mine is just not That bad, but sounds the same just yours louder i believe.
Buildthread http://www.jeepforum.com/forum/f197/...grade-1813490/
Thomahawk is offline   Reply With Quote Quick reply to this message
Unread 01-07-2014, 06:39 PM   #6437
snobrdrkid07
snobrdrkid07's Avatar
Sounds terrible but at least it goes away. My first guess is the exhaust leak, then second would be some sort of valve train noise.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is online now   Reply With Quote Quick reply to this message
Unread 01-09-2014, 07:29 PM   #6438
Thomahawk
Thomahawk's Avatar
Something like this?
Unread 01-09-2014, 07:34 PM   #6439
snobrdrkid07
The 4.7's have an exhaust manifold that breaks of some sort. That can cause the noises that you are hearing. Check that bolt in the back and do some more research on that. BUT, that just doesn't sound like an exhaust leak, I'd pull the cover man, sounds like something internal is going on. Is yours constantly doing that? Does it go away?
Mine has not made any nasty noises since I posted that video, it is really hit and miss!
-Michael-
Unread 01-09-2014, 09:23 PM   #6440
compcrasher86
You guys sure thats coming from the engine? Sounds a lot like the Evap purge solenoid to me, exact same frequency. Worth checking at least, get a mechanic's stethoscope and poke around. Or if it changes when you give it a little bit of gas then its not the solenoid like I thought.
Matt
compcrasher86 is offline   Reply With Quote Quick reply to this message
Unread 01-10-2014, 02:16 AM   #6441
Thomahawk
Thomahawk's Avatar
Min is Deff not purge solenoid, That is ruled out, 2 guys with stetoscop have listened, coming from valve cover.
Unread 01-10-2014, 10:03 PM   #6442
snobrdrkid07
Time to pull the valve cover then. Keep us posted.
-Michael-
Unread 01-16-2014, 05:19 PM   #6443
snobrdrkid07
Oil
I give up.... geshhh!
-Michael-
Unread 01-21-2014, 01:11 PM   #6444
snobrdrkid07
Got some snow around VT.
New tires are great!
-Michael-
Unread 01-26-2014, 02:31 PM   #6445
snobrdrkid07
This sounds like fun....
http://www.youtube.com/watch?v=WU-xNf9ilC8
-Michael-
Unread 01-26-2014, 02:48 PM   #6446
Thomahawk
Thomahawk's Avatar
And familiar, havent got any parts yet to try to cure my tick
Sound like valve tick, have you got around to locate it with a stetoscop?
Is it consistent or only at cold start ups?
Unread 01-26-2014, 03:27 PM   #6447
snobrdrkid07
Sometimes I'll have an exhaust leak sound on cold starts, that *will* go away when it warms up. I drove around and this sound, that is different, didn't go away when it warmed up. Upon further investigation, it sounds like the CPS is making this noise. I was able to put my finger on it while running, I could feel a scrape/vibration as it spun, which coincided with the squeaking/tapping sound it was making in the video.
Anyone know what is making the whistling sound in the video? Can't figure that out.
-Michael-
Unread 01-27-2014, 08:10 AM   #6448
snobrdrkid07
Okay, so my theory of the CPS making the tapping/squeaking sound, may not be that far off. I got a code this morning for P1391. (Also have a P0505, which has popped up and gone away a few times now)
P1391 (M)
Intermittent Loss of CMP or CKP
Loss of the Cam Position Sensor or Crank Position sensor has occurred.
Maybe the CPS is having a bad time? Oh, I am not sure if I am confusing the terminology but I am referring to what I am feeling/hearing making noise is the sensor thing about the Oil filter, which I think is the Cam Position Sensor. Thoughts?
-Michael-
Unread 01-27-2014, 07:00 PM   #6449
snobrdrkid07
Here is another video:
Had a good friend listen to it, in person, and he suggested the same. Could be the Cam/valve train of possibly the Cam Position Sensor once he was able to physically touch it. But, also said that the lifter could be transmitting vibration up through the Cam Pos Sensor as well. So I am going to look into replacing the Cam Sensor first and then go from there. Really isn't a great time to have to tear down a motor.
-Michael-
Unread 01-27-2014, 07:04 PM   #6450
Thomahawk
Thomahawk's Avatar
Replace cam sensor first,,,
This along with the CPS , sets the ingnition timing, if this aint correct you might Get valve noises,,,,,
ome hd , OME lift kit , snobrdrkid , wj
