Snobrdrkid's WJ Build Thread - Page 429 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 01-01-2014, 05:12 PM   #6421
billzcat1
Chicken in a Turkey Suit
2003 WJ
Bump steer usually comes about as a result of the track bar and drag link being "unparallel". I know you had about a zillion things gon through - but did you consider that the worm gear in the steering box may be worn? I pulled off the steering linkage and found some slightly play in my steering box that was independent of any of the downstream links or joints. Another thought is that your front axle may be off-center and track bar needs readjustment.
Pretty much everything you have is new, and to be honest at >3" lift you shouldn't have to experiment with various combinations of parts to make it work right. At this point the list of things that haven't been replaced already is pretty small. I'd suspect either one of those few items or something fundamental like poor alignment. How about ball joints? I don't recall if you had those replaced yet.
billzcat1 is offline   Reply With Quote Quick reply to this message
Unread 01-01-2014, 05:42 PM   #6422
snobrdrkid07
snobrdrkid07's Avatar
I had *thought* it would still be parallel still, even with a hair off center? But I guess I may be wrong, so if the track bar is a hair to short or long that can bring up some bump steer. I took ChrisHager's amount of threads exposed from his JKS bar and based mine from there. It's lined up well and has only taken a slight pull to line up the final bolt. I am willing to bet still that its *pretty close* to center. What is the best way to measure? Can I reference off of the fenders? I've read where people unbolt the track bar and just wiggle the Jeep around and where it settles, is "center".
If the steering box is f'd, so am I. I actually have very little play in the steering with everything being as new as it. If I had to guess, a few degrees of the wheel now translates to the road.
When I did the LCA's to increase caster, I think I did wrong. I could go balls to the wall down the highway at 75+ and not have any major shimmy on all 4 stock control arms at 4.4. But when I added LCA's and got caster settled to ~6.7-6.8 it'll now shimmy on the highway at that speed, sometimes nasty. I am not sure if I ever mentioned that observation. This was on the JKS bar, same bushings, same tires, same pressure, and the only difference was the caster angle.
*Edit* - and no, the ball joints are still stock. I checked them again last week and couldn't get movement with a pry bar.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600s | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100s | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 01-01-2014, 06:21 PM   #6423
Thomahawk
Thomahawk's Avatar
^^^X2, check balljoints by push/pull wheel at 12 an 6 o'clock, when its off ground. Axle off center or bad aligment Are my best guess, Get those checked out.
Buildthread http://www.jeepforum.com/forum/f197/...grade-1813490/
Thomahawk is offline   Reply With Quote Quick reply to this message
Unread 01-01-2014, 06:36 PM   #6424
snobrdrkid07
I've checked them, multiple times, recently even. I'm going to take it for an alignment check tomorrow or the day after, and I'll post what I get.
-Michael-
Unread 01-01-2014, 08:00 PM   #6425
snobrdrkid07
Here are some more pictures for fun.
Also spent New Years Eve and Day in the Outer Banks, Corolla, NC
-Michael-
Unread 01-02-2014, 11:15 PM   #6426
snobrdrkid07
Did my transfer case fluid today. Bought new drain and fill plugs from the local stealership, mine were wrecked. Alignment "check" is scheduled for tomorrow.
-Michael-
Unread 01-03-2014, 09:38 AM   #6427
snobrdrkid07
Alignment Jan 3rd 2014
Well this is what I got. (It is clickable to zoom in more if need to)
Toe is out. Cross Caster was more than I thought it last was?
-Michael-
Unread 01-04-2014, 09:30 PM   #6428
Cirruslydakota
Remeber that old sunroof switch to roof rack light switch idea I had a while back? Well I should have it all up and working by the end of this weekend hopefully. Just thought id give you an update.
Bear - 1999 Jeep Grand Cherokee Laredo
Apollo - 2008 Mazdaspeed3
Vivienne - 2015 Chrysler 200S
Cirruslydakota is offline   Reply With Quote Quick reply to this message
Unread 01-04-2014, 11:57 PM   #6429
snobrdrkid07
10-4 I remember talking about this. Pretty interested to see how it all turns out!
Picking up some thick tubing to put over my Aux Trans cooler lines, there is some slight chafing occurring over the steering box and another spot by the coolant hose. Better safe then sorry, been on my to-do list for a year.
-Michael-
Unread 01-06-2014, 09:15 PM   #6430
Cirruslydakota
Partys over here!
http://www.jeepforum.com/forum/f310/...88/index5.html
Unread 01-07-2014, 08:24 AM   #6431
snobrdrkid07
Everyone knows how cold it is around the US right now. Started the WJ up in the single digits temps. I don't know what was clanking, shot a video of it. Likely nothing I can do about it but it sounded like hell so I thought I would share.
http://www.youtube.com/watch?v=gPfgf-HCjwM
Actually started right up too.
-Michael-
Unread 01-07-2014, 08:27 AM   #6432
ChrisHager
ChrisHager's Avatar
Is it consistent or does it go away after a minute?
8F - That's warm!
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
His: 2009 Expedition
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline   Reply With Quote Quick reply to this message
Unread 01-07-2014, 08:31 AM   #6433
snobrdrkid07
Depending on how cold, it'll do it until it warms up to about the 1/4 mark on the temp gauge. If I had to guess, a couple of minutes. I believe the oil is just cold and thick and not going to all the places it should be. When I go to Chickfila, ate and then came back out and started again, started no problem and no knocking sound at all. Just the "normal" 4.0 noise. So when the engine and oil are warm it's fine. *Long explanation short, it does go away.
No, 8F, is not as cold as other parts of the country! But, it's below are average temps.
-Michael-
Unread 01-07-2014, 08:37 AM   #6434
ChrisHager
ChrisHager's Avatar
Mine sounds AWFUL when I first start it but it only lasts ~5 seconds until the lifters pump up. Yours sounds a bit different though. Being that it does go away and it's new with this cold weather, I'd chalk it up the that unless it continues.
It hit -13 here yesterday. The high for the day was in the negatives. Unfortunately, I was outside for much of the day.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 01-07-2014, 08:43 AM   #6435
snobrdrkid07
Some neighbors even looked over and wondering what was making that terrible sound, I was embarrassed. It has done this before in the very cold temperatures, where it takes a couple minutes for this awful knocking sound to go away.
Other times throughout the year, on a "cold start" it "tap" or "knock" for ~3-5 seconds and immediately go away, even in the summer. It will do this randomly too, really no rhyme or reason.
Well, if it decides to drops a cylinder, it is out of my hands. All I *can* do is just baby the engine as much as I can while it's trying to warm up.
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
