Snobrdrkid's WJ Build Thread - Page 424 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 10-18-2013, 09:55 AM   #6346
billzcat1
Chicken in a Turkey Suit
2003 WJ
4526lbs.
billzcat1 is offline   Reply With Quote Quick reply to this message
Unread 10-18-2013, 10:03 AM   #6347
ChrisHager
ChrisHager's Avatar
If this is like the PIR, I'm going to guess 4527. Haha! :-)
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
His: 2009 Expedition
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline   Reply With Quote Quick reply to this message
Unread 10-18-2013, 10:24 AM   #6348
billzcat1
2003 WJ
Unread 10-18-2013, 10:30 AM   #6349
snobrdrkid07
snobrdrkid07's Avatar
Haha! ^
Hint, still too low.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is online now   Reply With Quote Quick reply to this message
Unread 10-18-2013, 10:40 AM   #6350
billzcat1
2003 WJ
Last time I weighed mine it was 4560 curb weight - empty but full of all fluids and fuel. So add 2 people and a bag of tools we're at about 5000.
Now theoretically the base curb weight for an I6 Laredo is about 400 lbs lighter than an Overland, hence where I got my estimate from. But maybe those figures for curb weight are wrong...oh plus you have a system in there.
4680.
Unread 10-18-2013, 10:47 AM   #6351
snobrdrkid07
Definitely on the right track, still a little low. Actually, the numbers in your last guess are correct, just in the wrong order. The scale rounds to the whole 10's place.
-Michael-
Unread 10-18-2013, 11:16 AM   #6352
ChrisHager
ChrisHager's Avatar
Haha I got a kick out of that, Richard!
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 10-18-2013, 01:07 PM   #6353
billzcat1
2003 WJ
4860?!
Unread 10-18-2013, 01:10 PM   #6354
snobrdrkid07
Originally Posted by billzcat1 View Post
4860?!
Yup, tipped the scales at 4860 pounds haha. That's pretty much my daily driving weight. Loaded down I don't even want to know haha.
-Michael-
Unread 10-18-2013, 04:14 PM   #6355
billzcat1
2003 WJ
So that's still more than 4400 curb. Why so heavy? Sounds like a real workout for the 4.0.
Unread 10-18-2013, 04:38 PM   #6356
snobrdrkid07
This is the first time that I have ever put in on a scale to get a real number. I was expecting it to be heavy but, not quite this much.
Here are my best guesses:
3970 = Base Laredo 4.0, 4wd, curb is weight according to WJJeeps.com.
124 = 19 gallons x 6.5 pounds/gal
350 = Passenger Weight
65 = 15x2 subs + box + 2 amps
50~ pounds of tools, compressor, junk, etc
4559 = Total
Where the added weight comes in, no clue. Sunroof, tow package, upgraded seats? No idea.
Probably a decent factor in poor(er) than most city fuel econ. Lots of weight to lug with a heavy foot.
-Michael-
Unread 10-24-2013, 10:19 AM   #6357
snobrdrkid07
P0505 - IAC Motor Code popped up today. Don't know why, everything is running fine. Only difference was, on the usual start up it will rev to 1500 rpms and immediately drop down to normal idle. This time it just jumped to 1000 or so on start up and threw a code. Went to start it a few more times today and was normal. Probably just going to clear the code and not worry about it.
-Michael-
Unread 10-24-2013, 10:50 AM   #6358
ChrisHager
ChrisHager's Avatar
You could pop it off and clean it up a bit. It may be sticking on some gunk...
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 10-24-2013, 11:46 AM   #6359
snobrdrkid07
Possible, although its only like 2 years old. When I broke my original IAC by cleaning it, I replaced it with an AutoZone IAC. That is likely getting ready to hit the fan. I'll get a Mopar Sensor if this one fails.
-Michael-
Unread 10-30-2013, 03:18 PM   #6360
snobrdrkid07
Replaced the stock hardware that the Moog Tie Rod clamps came with. Replaced with Grade 8 bolts, washers, and nylock nuts. Wish I would have went a size bigger though. At Least now the washers are keeping the nuts from burrowing into the clamps.
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
