Snobrdrkid's WJ Build Thread - Page 422 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectRIGID LED Light Blowout Sale - All Sizes, All Series, all Toxic Brakes - 3000 PSI Braided Stainless Steel Brake Line
Unread 09-30-2013, 09:06 AM   #6316
snobrdrkid07
Mr. WJ
snobrdrkid07's Avatar
Those seems to be a general consensus thus far. Maybe I'll hear something from the dealer today.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600s | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100s | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 09-30-2013, 09:18 AM   #6317
billzcat1
Chicken in a Turkey Suit
2003 WJ
A bad CPS would cause more of a no-start condition. I'd say coil rail is also a likely suspect.
billzcat1 is offline   Reply With Quote Quick reply to this message
Unread 09-30-2013, 09:33 AM   #6318
ChrisHager
ChrisHager's Avatar
True. I was thinking more of if the fuel sync when out. I don't know if that can even happen though on a whim like that.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
Originally Posted by alfaitalia View Post
"Wind them in until you strip the thread....then back a quarter turn!"
ChrisHager is offline   Reply With Quote Quick reply to this message
Unread 09-30-2013, 09:52 AM   #6319
billzcat1
2003 WJ
Cars ran great for 100 years without synchronized/sequential fuel injection. Turns out it doesn't really matter, it just affects the top 5% of power and of course EMISSIONS.
Unread 09-30-2013, 09:56 AM   #6320
ChrisHager
ChrisHager's Avatar
I see what you're saying. I think the reason CPS popped into mind was when mine was out of sync (probably 30 off), it would start/run but ran so rich the cats turned red. Once I realized my mistake, I fixed it up and shazam, all was well! I then had it synced afterwards but you're right - it ran fine before having the dealer sync it. That being said, the only way the CPS could have turned causing it to run rich is if the hold down clamp worked loose. Even then, if for some reason that actually happened, both cats would turn red, not 1.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 10-01-2013, 02:58 PM   #6321
snobrdrkid07
Mr. WJ
Still no word on the Rubicon...
However I have been putting my WJ in Full Time about once a week to keep things from seizing etc. I've noticed its easier to shift from 4hi back to 2wd. But man do I get a lot of nasty noises when accelerating. Lol
-Michael-
Unread 10-01-2013, 03:05 PM   #6322
ChrisHager
ChrisHager's Avatar
Oh?
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 10-01-2013, 03:20 PM   #6323
snobrdrkid07
Mr. WJ
Originally Posted by ChrisHager View Post
Oh?
Vibrations, whining, and groaning. Haha. Probably the pinion and d.s. angle at the axle. Really don't know any way of remedying
-Michael-
Unread 10-02-2013, 02:23 PM   #6324
GraKee99
Rapist Wit
GraKee99's Avatar
That doesn't make sense why it would make noise when 4 wheel drive is engaged since you front driveshaft is spinning all the time anyways since you don't have manual hubs.
Brian
WJ, WK, CJ5
GraKee99 is offline   Reply With Quote Quick reply to this message
Unread 10-02-2013, 02:31 PM   #6325
snobrdrkid07
Mr. WJ
Don't know man, just telling it how it is. That's why it has me confused as well.
Update on the Rubicon, coil rail failed, plugs fouled as a result. Also the cam position sensor failed. So new coils, new spark plugs, and a new cam position sensor. First ever "breakdown" in the Rubicon.
-Michael-
Unread 10-02-2013, 03:56 PM   #6326
gcjeeping
gcjeeping's Avatar
Maybe because the its under a load when in 4wd vs not.
__________________________________________________ _________
-GCJEEPING's build/mod thread-IT'S A GREEN THING...
gcjeeping is offline   Reply With Quote Quick reply to this message
Unread 10-02-2013, 03:59 PM   #6327
snobrdrkid07
Mr. WJ
That is when it is the worst... under load.
-Michael-
Unread 10-03-2013, 07:01 PM   #6328
snobrdrkid07
Mr. WJ
Checked more on the electric fan. Found another thread where the e-fan on the 04's is controlled only by a hi and low relay in the PDC box. Jumped the fan and it kicked on. Wonder if both relays just blew, as unlikely as that sounds. Going to order some new relays tonight.
Also "fixed" the brakes, did a few very hard stops and heated them up big time and then let them cool. Made a noticeable difference in reducing the vibrations. Almost completely gone.
Here are some new "chirps" haha
-Michael-
Unread 10-04-2013, 07:14 AM   #6329
ChrisHager
ChrisHager's Avatar
Check your front driveshaft U-joints.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 10-04-2013, 07:55 AM   #6330
snobrdrkid07
Mr. WJ
Better not be that, front d.s. has maybe a few thousand miles on it. :/
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
