Snobrdrkid's WJ Build Thread - Page 421 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
Warn, Smitybilt, Engo, Rugged Ridge Winches at CCORRIGID LED Light Blowout Sale - All Sizes, All Series, all USA Standard Chromoly Front Axle Shaft Kits with Dana 30 4
Unread 09-12-2013, 08:42 AM   #6301
snobrdrkid07
Mr. WJ
snobrdrkid07's Avatar
Lol oh gosh. How'd that turn out? My rotors came drilled.
~ 04 WJ 4.0 | Selec-Trac 242 | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Custom Front D.S. | Stillen Rotors/Metal Matrix Pads | Tow Package w/ 3.73's | Projectors w/ 55w HID H1 5000K Lows | Sylvania Ultra 9005 Fogs | Moog HD Steering | Kenwood eXcelon Radio | Memphis Speakers | Alpine Amps | Alpine Subs | Moog STB SS | Superchips Flashpaq | Auxiliary Transmission Cooler | Rock Lights | Light Bars ~
~ Snobrdrkid's "Build" Thread ~ YouTube Channel ~ Fuelly ~WJ 4.0 Transmission Cooler Info ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | 2" Spacer Lift | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
For Sale:
Front XJ/TJ 2" Budget Boost. PM for details.
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 09-12-2013, 08:44 AM   #6302
ChrisHager
ChrisHager's Avatar
Haha I think you misunderstood. I had drilled rotors. They warped so I had them turned.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
Originally Posted by alfaitalia View Post
"Wind them in until you strip the thread....then back a quarter turn!"
ChrisHager is online now   Reply With Quote Quick reply to this message
Unread 09-12-2013, 08:47 AM   #6303
snobrdrkid07
Mr. WJ
Oh wow how did I completely fail at that. Guess between lecture, JeepForum, and solitaire... to much multi tasking.
But I was under the impression you could not turn drilled rotors.
-Michael-
For Sale:
Unread 09-12-2013, 08:59 AM   #6304
ChrisHager
ChrisHager's Avatar
That may be the case. I was a little less informed when I was younger. You gotta' start somewhere though!
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 09-12-2013, 09:40 AM   #6305
Thomahawk
Ha ha, i didnt try to say it was a problem, and ofcourse the front ones make more effect.
I know the brake split is about 70/30 for a motorcycle,
I would believe its lower for a car, maybe about 60/40.
Idk about if they can be turned though.
I am just a stupid electrician, lol
Buildthread [url]http://www.jeepforum.com/forum/f197/jeep-norway-2th-buildt-overland-upgrade-1813490/[/url]
Thomahawk is offline   Reply With Quote Quick reply to this message
Unread 09-13-2013, 05:43 PM   #6306
snobrdrkid07
Mr. WJ
Yeah not too sure on the brake split!
Picked up 6 Quarts of Mobil 1 10w-30 Full Syn High Mileage at Wal-Mart for $33, not too bad. I've got my Mopar Filter as well. Oil change... woo-hoo so exciting. Will be sending off another oil sample for testing.
-Michael-
For Sale:
Unread 09-16-2013, 11:57 AM   #6307
snobrdrkid07
Mr. WJ
Uh ohhh! Bought another Jeep! --> http://www.jeepforum.com/forum/f177/...build-1591745/
-Michael-
For Sale:
Unread 09-16-2013, 12:32 PM   #6308
Thomahawk
Originally Posted by snobrdrkid07
Congrats man
Unread 09-18-2013, 04:07 PM   #6309
snobrdrkid07
Mr. WJ
Thanks Thomas!
Back to the WJ... I noticed that my E-Fan is AGAIN NOT WORKING!!! (had the hood up and jumper cables on and somehow managed to see it not spinning, anyways). So I check the fuse by the battery and it was blown, replace the fuse and still nothing. Even when I put the AC on the E-Fan won't kick on. The Jeep was definitely warm, it has been idling for probably 30 minutes or more.
Although I have no idea how long the E-Fan hasn't been working. The Jeep stayed at 195* all summer and never had an overheat issue, thanks to the Mechanical Fan.
I do not know if the relay for the E-Fan is under the pass headlight in the 04's still or what. I noticed a Hi and Low Relay in the box by the battery so maybe one of those controls the fan?
-Michael-
For Sale:
Unread 09-19-2013, 08:54 AM   #6310
compcrasher86
Thanks Thomas! Back to the WJ... I noticed that my E-Fan is AGAIN NOT WORKING!!! (had the hood up and jumper cables on and somehow managed to see it not spinning, anyways). So I check the fuse by the battery and it was blown, replace the fuse and still nothing. Even when I put the AC on the E-Fan won't kick on. The Jeep was definitely warm, it has been idling for probably 30 minutes or more. Although I have no idea how long the E-Fan hasn't been working. The Jeep stayed at 195* all summer and never had an overheat issue, thanks to the Mechanical Fan. I do not know if the relay for the E-Fan is under the pass headlight in the 04's still or what. I noticed a Hi and Low Relay in the box by the battery so maybe one of those controls the fan?
Blew a fuse? The motors probably locked up or worn out to a point where its got more drag than its supposed to and now its drawing more current than its supposed to, if it'll even turn on. Recommend new fan and new relay at the same time if you have the relay under the headlight there.
Matt
compcrasher86 is offline   Reply With Quote Quick reply to this message
Unread 09-19-2013, 09:14 AM   #6311
snobrdrkid07
Mr. WJ
It is a brand new fan assembly, less than a year old, like 8 months. Better not be shot...
-Michael-
For Sale:
Unread 09-19-2013, 09:59 AM   #6312
compcrasher86
Mopar?
Matt
Unread 09-19-2013, 10:05 AM   #6313
snobrdrkid07
Mr. WJ
Mopar?
Maybe. Not sure.
Turns out in the 2004's the fan relay is infect in the PDC and not under the headlight. +1 for the 2004s
Maybe I need to check/test/replace those hi and low relays.
-Michael-
For Sale:
Unread 09-29-2013, 10:05 PM   #6314
snobrdrkid07
Mr. WJ
Well, finally had an opportunity to take the Rubicon off-roading. Didn't turn out so well at all. Started out on the trail, got about 30 minutes in to wheeling, then shut it off for a broken rig a few ahead of us.
Everything was running perfect before that, nothing was out of the ordinary. We come back to start it after it had been sitting for ~20 minutes, then sh** hit the fan. Started up, kinda, idling at ~300 rpms very very rough, sputtering, and coughing from the intake. Giving it some gas did nothing to help. Upon inspection, nothing was out of ordinary, visually loose, etc. Fluids were all fine. Only thing that was out of the ordinary visually was the pre cat for Cylinders 1-3 was glowing red hot. Then it also smelled like a "cold morning start up".
Long and crappy day short. We strapped it out of trail, thankfully we didn't make it any big obstacles. Then flatbed towed about 2 hours to a local dealership around where I am at. They'll have it until its fixed I guess. No idea what is wrong with it. I've gotten suggestions as far as a clogged cat and a failed coil. Other than that, no idea. Sucks, but what can you do. Will post when I find out more.
-Michael-
For Sale:
Unread 09-30-2013, 06:12 AM   #6315
ChrisHager
ChrisHager's Avatar
That sucks. My thoughts are clogged cat or bad coil rail as well. I thought perhaps bad CPS but if it were causing it to run too rich, both cats would be glowing red.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
ome hd , OME lift kit , snobrdrkid , wj
