Snobrdrkid's WJ Build Thread - Page 419 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 08-18-2013, 08:28 PM   #6271
snobrdrkid07
snobrdrkid07's Avatar
For Merc
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is online now   Reply With Quote Quick reply to this message
Unread 08-25-2013, 12:33 PM   #6272
snobrdrkid07
Trip update from Thursday, 8/22. Did about 300 miles from home to VT and the Jeep actually did great. I only have a few times where it shimmied a little bit, which were not bad at all. I don't what magically changed but everything went well on a nice any easy drive up. Did about 60-65 for the majority of the trip. Averaged about 19 MPG and the Jeep was LOADED down, stuffed to the top! haha.
Just a little picture from the beginning of the loading.
-Michael-
Unread 09-03-2013, 11:49 PM   #6273
snobrdrkid07
Bought some more switches and accessories from OTTATTW. Still my go to place for really nice rocker switches. I bought another switch for the Light bar, terminal blocks to hold the individual wires, and a bezel/bracket for the switches.
-Michael-
Unread 09-04-2013, 04:45 PM   #6274
Thomahawk
Thomahawk's Avatar
Pics pls,
Buildthread http://www.jeepforum.com/forum/f197/...grade-1813490/
Thomahawk is online now   Reply With Quote Quick reply to this message
Unread 09-04-2013, 11:03 PM   #6275
snobrdrkid07
I'll get pics for you as soon as they come in! I am pretty excited haha. Been meaning to clean up my dash for awhile now too.
-Michael-
Unread 09-06-2013, 11:54 PM   #6276
snobrdrkid07
Here is the almost finished switches. I forgot to order the fancy trim pieces Although I'll probably leave it at it sits.
-Michael-
Unread 09-11-2013, 02:47 PM   #6277
snobrdrkid07
So I have been having this weird thing going on while braking. It happens regardless if I am in D or N. So when I am coming to a stop from like ~30 mph to stop, I get this pulsing feeling in the Jeep, like half the rotor is grabbing while the other half is grabbing less. So, as speed decreases, the frequency of the "pulsing" decreases as well. If that makes sense? I do not have any shimmy in the steering wheel from it, and I might feel it in the pedal, not really sure there. Don't really notice anything at highway speeds either. I think it is the rear brakes to be honest. Not sure why it's doing this, "lurching / pulsing" feeling. Ideas?
Edit: Rear rotors are pretty worn.
-Michael-
Unread 09-11-2013, 03:15 PM   #6278
Thomahawk
Thomahawk's Avatar
Hmmm, didnt you do the Stillen upgrade not long ago?
Unread 09-11-2013, 03:16 PM   #6279
billzcat1
Chicken in a Turkey Suit
2003 WJ
Glazed pads+rotors will do that. You can have the rotors turned and then sand the pad face just to break the glaze, then re-bed them in.
billzcat1 is offline   Reply With Quote Quick reply to this message
Unread 09-11-2013, 03:24 PM   #6280
snobrdrkid07
Yeah I did the Stillen's last summer, like June 2012.
Think it could be the rears? Because I don't feel any type of shimmy in the steering... or does glazing not cause shimmies? And how do rotors/pads become glazed?
Thanks
-Michael-
Unread 09-11-2013, 03:32 PM   #6281
Thomahawk
Thomahawk's Avatar
Thanks
How many miles have you been putting on them since new?
My old rotors lasted 3 years and about 60K km,
Idk about the glazing Michael,
Why does this happen?
Unread 09-11-2013, 03:33 PM   #6282
billzcat1
2003 WJ
The worse kind of glazing happens when you get the brakes good and hot and then come to a stop. The pad will transfer a little extra material to the rotor when you've stopped. Since there's no warp, there's no pulse in the pedal, just pulse in the amount of braking provided.
Unread 09-11-2013, 03:34 PM   #6283
Thomahawk
Thomahawk's Avatar
Like my really hard brake down That ended in the rear end thinghy?
Unread 09-11-2013, 03:37 PM   #6284
snobrdrkid07
Pretty much exactly 11k miles on the front Stillen Rotors and Pads
116k Miles on the rear rotors and probably 40k miles on rear pads
Oh... wonderful, that is all I do. Usually around town the lights will change, fast. I'll have to slam the brakes at times.
-Michael-
Unread 09-11-2013, 03:40 PM   #6285
Thomahawk
Thomahawk's Avatar
So you didnt upgrade it all around 4 corners at the same time,,,
But i got to say Those rears lasted very long.
ome hd , OME lift kit , snobrdrkid , wj
