Snobrdrkid's WJ Build Thread - Page 418 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 08-12-2013, 01:30 AM   #6256
Thomahawk
Thomahawk's Avatar
Cool, i bet you got That heated seat up'n working before i Fix mine, lol
Buildthread http://www.jeepforum.com/forum/f197/...grade-1813490/
Thomahawk is online now   Reply With Quote Quick reply to this message
Unread 08-14-2013, 08:34 PM   #6257
snobrdrkid07
snobrdrkid07's Avatar
Yeah hopefully. If I give up, I'll go aftermarket heated seats and just switch out the heating pads.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 08-15-2013, 09:48 AM   #6258
snobrdrkid07
I've noticed a rear end clunk over speed bumps at very reasonable and slow speed. I was thinking that there was no way I blew out the new a arm in under 10k mikes, especially being because it is a Mopar a arm.
I know the sway links squeak but don't clunk
Its not the shocks
Maybe its the lower control arms? I know the axle side bushings aren't stellar... could that make it clunk?
-Michael-
Unread 08-15-2013, 09:54 AM   #6259
Thomahawk
Thomahawk's Avatar
Its not the shocks
My endlinks clunkled to tell me they where shot,
And check swaybar to axle bushing, my energy/Addco upgraded bushing didnt last long before needed replaced, just saying.
Unread 08-15-2013, 09:55 AM   #6260
JerzeyBoyWJ
2003 WJ
Its not the shocks
Check the output shaft on the t-case ...my t-case needs a rebuild and when ever I hit a bump the output shaft clunks
Sent from my iPhone5 using JeepForum
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline   Reply With Quote Quick reply to this message
Unread 08-15-2013, 11:07 AM   #6261
snobrdrkid07
Yeah I've had the "clunk stop" on the Jeep where the slip yoke on the t-case would make noise
Maybe I'll check for up and down play on the slip yoke too.
Thomas, I don't think it is the end links, they're fairly new.
The Jeep is also so obnoxious going from P to R or D to R. So clunky too.
-Michael-
Unread 08-15-2013, 12:25 PM   #6262
compcrasher86
Well that's pretty normal between the gears the D35s have a bit of diff slop in them you can't avoid.
Matt
compcrasher86 is offline   Reply With Quote Quick reply to this message
Unread 08-15-2013, 03:10 PM   #6263
ChrisHager
ChrisHager's Avatar
Mine does it too. U-Joints look solid. I've heard it's a normal thing.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
His: 2009 Expedition
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline   Reply With Quote Quick reply to this message
Unread 08-15-2013, 03:22 PM   #6264
snobrdrkid07
I guess the slop is normal, that is pretty sad.
I'll see if I can get a video of the LCA bushing play in the rear. Otherwise just going to have to deal!
-Michael-
Unread 08-15-2013, 03:33 PM   #6265
Thomahawk
Thomahawk's Avatar
The new Girly Jeep have this to coming to a stop, seemed to Get better after TC fluid change from ATF>Magic 247 fluid,
mine have this alitte but not so often, and just when put into D, i might suspect TC case and or yokes Are worn.
For you snobrdkid, it might be yokes or worn transfer case chain thinghy, or just the sloppyniess off the D35
Ok, if nothing Ells shows up bad, i might settle with this as a explanation, but idk about the D35.
Oh, phu thx, good to hear
Unread 08-15-2013, 04:09 PM   #6266
snobrdrkid07
Got this little thing in the mail today.
-Michael-
Unread 08-15-2013, 05:24 PM   #6267
Thomahawk
Thomahawk's Avatar
Might That be a heated seat switch harness with plug???
Unread 08-15-2013, 05:29 PM   #6268
snobrdrkid07
That'd be exactly what that is!
-Michael-
Unread 08-15-2013, 05:34 PM   #6269
Thomahawk
Thomahawk's Avatar
Very Nice indeed, whats next?
Unread 08-15-2013, 06:08 PM   #6270
snobrdrkid07
Upcoming stuff...
I've got measure my front lowers for a member who got IRO lowers.
I want to check out my rear lower bushings.
Grease my sway links and stuff behind there.
Check my t-case output shaft.
Maybe look into the heated seat thing. Still iffy on running wires.
Thinking about moving my amps to underneath the rear seats.
Oil change eventually.
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
