Snobrdrkid's WJ Build Thread - Page 415 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 06-25-2013, 10:43 AM   #6211
compcrasher86
Originally Posted by snobrdrkid07
When I was letting off the gas after cruising at speed, it would kinda clunk and the RPM's would drop and it would feel like it's applying brakes. Is there supposed to be that much of a drop in RPMs?
Clunk: slop in drivetrain and you're unloading the power suddenly and switching to coasting
RPMS dropping: letting off gas and torque converter unlocking
Feel like its applying brakes: aerodynamics of a Jeep at highway speeds while not applying any power.
Matt
compcrasher86 is offline   Reply With Quote Quick reply to this message
Unread 06-25-2013, 10:51 AM   #6212
snobrdrkid07
snobrdrkid07's Avatar
So its Jeep being Jeep. Figures. Thanks guys.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 06-25-2013, 10:57 AM   #6213
snobrdrkid07
Finally fixed the driver's side power seat with a new motor off eBay and some pins from TSC haha
Yeah I cleaned all that up too ^^^ haha
-Michael-
Unread 06-25-2013, 11:01 AM   #6214
ChrisHager
ChrisHager's Avatar
You should see the inside of the WJ and the TJ, especially after hitting that 'mud puddle'.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
His: 2009 Expedition
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline   Reply With Quote Quick reply to this message
Unread 06-25-2013, 11:03 AM   #6215
snobrdrkid07
Yeah I would rather not!
-Michael-
Unread 06-30-2013, 09:31 AM   #6216
snobrdrkid07
Even thought I just fixed my power seat up front. I just got a full set of leather seats!
Taupe, 10 way power, heated, memory all for $100. In great condition too.
-Michael-
Unread 06-30-2013, 09:42 AM   #6217
compcrasher86
$100 WOW what a steal michael
Matt
Unread 06-30-2013, 11:30 AM   #6218
04Overland47
04Overland47's Avatar
Sweet deal! Go home Michael you're
2004 WJ Overland 4.7HO Graphite 127k miles / Powerstick Muffler / Superchips / Bilstein HD's / Addco Rear Bar / SOLD!
1998 ZJ Limited 5.9 SOLD!
2010 WK Laredo 5.7
Youtube Channel
WJ Thread
04Overland47 is offline   Reply With Quote Quick reply to this message
Unread 06-30-2013, 07:20 PM   #6219
snobrdrkid07
Here we go! Won't be able to get the memory to work. But would like to get the heated seat option going somehow!
They look great and are really comfy!
-Michael-
Unread 06-30-2013, 10:58 PM   #6220
SnowLeopard
They look good. Really. If I recall, the heated seat module is under the driver's seat, and this goes under the carpet to the passenger seat. There's an in-dash button/switch that turns it on. It looks to be some form of transformer under the driver seat. I'm not sure how it all works. I never could figure it out, so when I transplanted leather WJ seats into my ZJ, I just lived without the heating function. I hope you're able to find a way to make them work. It might be easier as you're putting them into another Dub.
Yes, it snows in Texas.
SnowLeopard is offline   Reply With Quote Quick reply to this message
Unread 06-30-2013, 11:03 PM   #6221
snobrdrkid07
WJJeeps is my hero lol. I'll keep an eye on eBay. Should have snagged that whole WJ. He wanted a Grand and it was mine. There was much money to be made.
For 1999-2004 Grand Cherokees that came without heated seats the wiring is a little more involved as the heat function is controlled via the PCI Bus and you will be hooking up two seats. Two heated seat switches will have to be purchased and installed in the center bezel. Some center bezels have the holes pre-cut with blank plates installed while others may have to be trimmed out with a dremel type tool. Some owners elect to just purchase a new center console bezel assembly as there are several choices available (with and without ashtray for example). See Interior Trim for a list of part numbers for center bezels.
NOTE: A factory pre-wired harness for the heated seat switches is located behind the center lower bezel in most if not all models that did not have this feature. All you have to do is plug the two harness plugs into the two heated seat switches.
-Michael-
Unread 07-01-2013, 02:42 PM   #6222
snobrdrkid07
Well I saw something I didn't really like yesterday from the Jeep. Saw a puff of blue smoke from the exhaust on start up. Just a little bit and stopped. (my friend was moving the Jeep and I saw it). So I was told that this was the valve seals leaking a little oil into the exhaust. I guess it is something to keep an eye on and check the oil levels more frequently. I'm going to be curious with the next oil analysis if they find any excessive iron or metal.
-Michael-
Unread 07-19-2013, 11:27 PM   #6223
snobrdrkid07
I put in the other heated mirror for the passenger side today. While I had the door panel I remembered that the Keyless Entry antenna was in the passenger door panel. I read around a while ago on here that people had luck extending the range by adding some more wire to the antenna wire. So, I added about 3 feet of similar gauge wire to it and taped it to the door panel. Put it back together and BAM I now have about 20-30 foot range compared to 2-3 feet of range! Simple and easy!
-Michael-
Unread 07-20-2013, 03:26 AM   #6224
compcrasher86
Bam!
Matt
Unread 07-20-2013, 12:52 PM   #6225
Merc1973
Awesome thread and WJ!
I'm still on page 388 and need to catch up.
I was wondering if you could possibly measure your IRO LCA's length so I can get my caster close to yours.
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline   Reply With Quote Quick reply to this message
ome hd , OME lift kit , snobrdrkid , wj
