Snobrdrkid's WJ Build Thread - Page 411 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
KrawlOff-Road.com Sale EventFS: Jeep Fog Light LED Bulbs! Several Brightness Options! *STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light Ba
Unread 04-30-2013, 07:55 PM   #6151
snobrdrkid07
snobrdrkid07's Avatar
I guess the grease finally dried up. I need some thick and sticky grease. Which it seems like that is what the energy suspension grease is like.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 05-02-2013, 07:26 PM   #6152
snobrdrkid07
I guess this is why the 2" bump stops were a little too long...
-Michael-
Unread 05-02-2013, 10:40 PM   #6153
billzcat1
Chicken in a Turkey Suit
2003 WJ
Put em in sideways!
billzcat1 is offline   Reply With Quote Quick reply to this message
Unread 05-02-2013, 10:43 PM   #6154
snobrdrkid07
That could work if I drill holes in it. Wonder how the track bar bolt would fair with this there...
I guess if I ever get the other bolt in there I could have the nut facing the rear instead of the front.
-Michael-
Unread 05-03-2013, 04:47 PM   #6155
snobrdrkid07
Greased the outer face of the bushings... didn't help. Still makes the same crunch, pop, squeak, lame. Maybe I need to grease the outside of the sleeve. :/ What rotates if the sleeve is stationary? The bushings supposed to rotate on the sleeve?
-Michael-
Unread 05-08-2013, 12:54 AM   #6156
snobrdrkid07
Track bar is still acting up bad after a few minutes of driving. Weird that is is fine for a little bit but, I guess as it warms up, it starts to squeak. My guess is the bushing is trying to rotate on the sleeve and just failing miserably. I would think the sleeve would be stationary...
Thinking of finding an "easy" way of adding a temp gauge to the transmission... Yeah the word easy... hah.
-Michael-
Unread 05-08-2013, 08:07 AM   #6157
compcrasher86
To get a rough idea you can put a sender inline at the cooler input hose upfront but that may not be all that accurate the best way is to have a pan-mounted sender.
Matt
compcrasher86 is offline   Reply With Quote Quick reply to this message
Unread 05-11-2013, 12:07 AM   #6158
snobrdrkid07
Left the sunroof flipped up during a heavy storm. Awesome, soaked the headliner, seats, and carpet. Stained the seats too, going to have to find a way to clean them. While I was inside towelling stuff off, I had the AC on full blast and on recirculate and it helped dehumidify the cabin and dry it out. What a mess.
-Michael-
Unread 05-11-2013, 12:08 AM   #6159
snobrdrkid07
I was wondering if there was any way I could add a sensor to the pan. I guess when I did the fluid/filter drain/replace.
-Michael-
Unread 05-11-2013, 02:49 AM   #6160
Thomahawk
Thomahawk's Avatar
Auch thats shhh, hope you got it sorted out.
Buildthread http://www.jeepforum.com/forum/f197/...grade-1813490/
Thomahawk is offline   Reply With Quote Quick reply to this message
Unread 05-11-2013, 05:50 PM   #6161
snobrdrkid07
It seems like the headliner will be okay. I was going to leave the windows open to vent it out, but it has been raining off and on. So it has been hot and the Jeep was a sauna inside haha.
Did get a chance to work on the seats but I should be able to stain remove them.
Took a 40 mile cruise to nowhere today with the AC running and on Recirculate, It got cold in there! But, it helped dry it out more.
I'll tell you guys, I love how the Jeep rides on the highway and around town. Those damn bumps though!? Haha, the DAY I get home I am swapping the Overland rims and tires on and going to go from there. Everyone says I need to do ball joints but there is just no play in them... I do need to do axle side uppers, thats on the list. Would really hate to un-lift the damn thing.
-Michael-
Unread 05-13-2013, 11:47 AM   #6162
ChrisHager
ChrisHager's Avatar
Now that you've had your Transmission Cooler for a while, how has it been treating you? How was the fitment, etc.? I'm going to place an order for one today and wondered: If you could do it again, would you go with the same one (Derale D13503) or would you get something different?
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
His: 2009 Expedition
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline   Reply With Quote Quick reply to this message
Unread 05-13-2013, 01:43 PM   #6163
snobrdrkid07
I have been very happy with it thus far. Fitment was a little tight as it is a "Class III" Cooler and rather large. But, got it in there nonetheless. I did not mount it on the AC condesnor as shown in the thread/pictures here It kinda sits on the two bars that hold the hood latch and I have not had an issue with it there. I've had to tighten a hose clamp once on the Jeep side metal to rubber hose connection but nothing major. I went to the auto store and purchases like 6-8 feet of large ID TRANSMISSION fluid rated hose and just used that to keep it symmetrical. They provide you with some hose but, for my install it was not enough.
I oriented it sideways with the flow coming from the transmission to the bottom and from the top back to the transmission. (I need to double check this however, I do recall something like this so it would not all drain back and have to be pumped up every time.)
As you may know, I went from the trans, through the factory cooler, and then to the aux cooler and back to the transmission. I've had no negative effects that I can say with this setup in the way of "overcooling". I've been able to go out start up the Jeep in 0 degree weather and after a minute down the street it will lock up the torque converter. Basically I've never in the life of the Jeep had the torque converter *not* lock up because it was too cold. I've been meaning to get a temperature sensor in there sometime. I wish Jeep has a real trans temp monitor and real oil pressure gauge (in the 02-04's)
*Update* From a Derale Rep on the orientation... (Went *way* back in the emails...(3/9/12))
Me - "Hello, I have just bought a Series 8000 Oil Cooler, stock number 13503 and I was wondering what way you should orient the cooler. As in, where the barbs should be pointing to connect the rubber hoses? Downwards or on the side? Thank you."
Derale Rep - "In the best case you would want the fittings to be pointing towards the sky. Second you would want them to either side. Last is facing down."
Me -"... Now, does it matter how the fluid flows through the cooler? From the looks of it, I did not see any indications that said one barb over the other. But, I was thinking to route the lines for the fluid to flow "up" through the radiator for the way of backflow prevention... "
Derale Rep - "Yes, for the most effective routing you will want the flow of the fluid to move up through the cooler."
I hope that clears up the orientation and fluid flow. Reason I did not point them upwards is there was not enough room or I did not have enough hose, I can not remember. But, it has been fine on its side.
Summary: Yes, I would do it again over and over. Best investment towards the 42re to keep it happy. I was able to do it my College's parking lot with basic tools, relatively easy. What was a huge pain was finding out all that information prior to! I would get the same one, I do not think it is too big or too small.
-Michael-
Unread 05-13-2013, 01:54 PM   #6164
ChrisHager
ChrisHager's Avatar
Excellent! I'll order it this afternoon. Thanks!
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 05-13-2013, 02:25 PM   #6165
ChrisHager
ChrisHager's Avatar
Are you sure you purchased D13503? 503 is Class III. 504 is Class IV.
Edit: I see on the picture I re-posted of yours, you did get D13503.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
ome hd , OME lift kit , snobrdrkid , wj
