Snobrdrkid's WJ Build Thread - Page 410 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
ROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep Grand Cherokee Tie Rods & Adjusting Sleeves
Unread 04-19-2013, 03:06 PM   #6136
compcrasher86
Yes yes and yes. And if they're the stock size Bridgestone ATs (not sure if those were just on the Saharas) they will fit but they'll rub bumper edges. MTs good luck to ya lol! Wrangler SR-A's are really piss poor tires buddy had them on his TJ and they were really bad... But you're saying these aren't going to be yours? I'm confused. Just testing?
Matt
compcrasher86 is offline   Reply With Quote Quick reply to this message
Unread 04-19-2013, 03:31 PM   #6137
snobrdrkid07
Mr. WJ
snobrdrkid07's Avatar
Yeah I am pretty sure that they are the Wrangler SRA's. I am not buying them, my friend is purchasing them. It is a great deal and he wants them but, will not be able to run them immediately. So, in the meantime he said I could run them on the WJ for sizing purposes and see how the Jeep drives in lieu of the crap Yokohama's.
~ 04 WJ 4.0 | Selec-Trac 242 | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Custom Front D.S. | Stillen Rotors/Metal Matrix Pads | Tow Package w/ 3.73's | Projectors w/ 55w HID H1 5000K Lows | Sylvania Ultra 9005 Fogs | Moog HD Steering | Kenwood eXcelon Radio | Memphis Speakers | Alpine Amps | Alpine Subs | Moog STB SS | Superchips Flashpaq | Auxiliary Transmission Cooler | Rock Lights | Light Bars ~
~ Snobrdrkid's "Build" Thread ~ YouTube Channel ~ Fuelly ~WJ 4.0 Transmission Cooler Info ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | 2" Spacer Lift | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
For Sale:
Front XJ/TJ 2" Budget Boost. PM for details.
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 04-20-2013, 12:35 AM   #6138
compcrasher86
This isn't your buddy with the TJ right? TJ wheels won't bolt up to WJs.
Matt
Unread 04-20-2013, 01:09 AM   #6139
snobrdrkid07
Mr. WJ
Nah it is another one, there are like a dozen people that are regular in the club. They are JK take off's.
-Michael-
For Sale:
Unread 04-21-2013, 12:27 PM   #6140
snobrdrkid07
Mr. WJ
FINALLY was able to put the front control arms in the right place. Switched the bolts that were in the wrong spot and lastly we switched the frame side washers to the correct spot. So all good to go there. Then torqued to 125 foot pounds.
Got the uppers out too, axle bushings are soft. The bushings in the arms themselves are pretty solid, would replace them though. (IRO uppers)
Had a cool extension to torque the upper frame side.
-Michael-
For Sale:
Unread 04-22-2013, 04:52 PM   #6141
snobrdrkid07
Mr. WJ
Picked up some 2" front bump stop extensions for <$20 today. Sweet.
-Michael-
For Sale:
Unread 04-26-2013, 05:20 PM   #6142
snobrdrkid07
Mr. WJ
Bump stops are a bust, about an inch too long. With the spacer and just the rubber "jounce" it only gave me about 3/4" before hitting the axle. No dice.
-Michael-
For Sale:
Unread 04-26-2013, 05:40 PM   #6143
billzcat1
Chicken in a Turkey Suit
2003 WJ
I put 2" extensions in mine and they appeared to be "too much" but they haven't been a limitation at all.
That is fully stuffed on the bump stops. There's more travel in the shock but as I said, it hasn't been any limitation for what I've been doing with the Jeep.
billzcat1 is offline   Reply With Quote Quick reply to this message
Unread 04-26-2013, 05:56 PM   #6144
snobrdrkid07
Mr. WJ
I may need to actually measure, they could be longer than 2". I wonder if it wouldn't be enough up travel though. I couldn't even fit the bump stop into the holder with the extension in.
-Michael-
For Sale:
Unread 04-26-2013, 05:57 PM   #6145
billzcat1
2003 WJ
I should add that this is where I was with no extensions...
Unread 04-26-2013, 10:10 PM   #6146
snobrdrkid07
Mr. WJ
Hmm, it really does not look like it affected it *too* much. Did you have any problem stuffing the bump stop back in the holder or did you have to raise the Jeep to get it in there? Lastly, do you estimate for distance between the axle and bottom of the bump stop, for comparison.
-Michael-
For Sale:
Unread 04-28-2013, 10:25 PM   #6147
snobrdrkid07
Mr. WJ
Car show this weekend at Tech was awesome, got to be a part of it! Jeep still cleans up pretty well!
-Michael-
For Sale:
Unread 04-30-2013, 12:02 PM   #6148
snobrdrkid07
Mr. WJ
Been lazy and have not ordered Grease yet for the Poly TB... I guess this is what I get for that.
-Michael-
For Sale:
Unread 04-30-2013, 05:46 PM   #6149
snobrdrkid07
Mr. WJ
I have been searching around the interwebs for a substitute poly grease. This is what I came up with as a *safe* substitute for the KOR grease at a much lower cost. http://www.energysuspensionparts.com...p?prod=9.11110
-Michael-
For Sale:
Unread 04-30-2013, 06:42 PM   #6150
04Overland47
04Overland47's Avatar
Hmm energy suspension does have some good stuff, so I would trust them. Maybe I'll buy some for the Addco bushings, rather than use brake grease. I'd like to hear other's input as well!
2004 WJ Overland 4.7HO Graphite ~122k miles / Powerstick Muffler / Superchips / Bilstein HD's / Addco Rear Bar / 17" Moabs
1998 ZJ Limited 5.9 SOLD!
2010 WK Laredo 5.7
Youtube Channel
WJ Thread
04Overland47 is offline   Reply With Quote Quick reply to this message
ome hd , OME lift kit , snobrdrkid , wj
