Snobrdrkid's WJ Build Thread - Page 409 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
Spartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREEYukon Ultimate 35 axle kit for c/clip axles with Yukon ZipNitro Gear Packages Now Available at Rockridge 4wd
Unread 04-17-2013, 03:34 PM   #6121
ChrisHager
ChrisHager's Avatar
Hmmm... Interesting point. I don't think mine is pre-wired, though I wish it was. I guess I haven't really poked around too much under the dash so maybe there's a wire tucked up in there somewhere.
Michael - did you have a trailer prep package or anything like that?
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
ChrisHager is offline   Reply With Quote Quick reply to this message
Unread 04-17-2013, 03:38 PM   #6122
snobrdrkid07
Mr. WJ
snobrdrkid07's Avatar
Apparently all the Jeeps came with that blue wire, with the tow package. The 2001's only, came with the direct plug and play harness, ready to go. The rest, 99-00 and 02-04, you have to do the impossible task of connecting three additional wires. +12, ground, and brake switch.
I do have the full factory tow package, not just the prep-package.
http://www.wjjeeps.com/trailer.htm#CONTROLLER
http://www.wjjeeps.com/electric_brake_inst.jpg
The 2001's apparently just had this tucked away and you could just plug and play. --> http://www.wjjeeps.com/trailer_6.jpg
~ 04 WJ 4.0 | Selec-Trac 242 | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Custom Front D.S. | Stillen Rotors/Metal Matrix Pads | Tow Package w/ 3.73's | Projectors w/ 55w HID H1 5000K Lows | Sylvania Ultra 9005 Fogs | Moog HD Steering | Kenwood eXcelon Radio | Memphis Speakers | Alpine Amps | Alpine Subs | Moog STB SS | Superchips Flashpaq | Auxiliary Transmission Cooler | Rock Lights | Light Bars ~
~ Snobrdrkid's "Build" Thread ~ YouTube Channel ~ Fuelly ~WJ 4.0 Transmission Cooler Info ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | 2" Spacer Lift | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
For Sale:
Front XJ/TJ 2" Budget Boost. PM for details.
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 04-17-2013, 03:39 PM   #6123
ChrisHager
ChrisHager's Avatar
Ah. Well there ya go!
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 04-17-2013, 03:56 PM   #6124
billzcat1
Chicken in a Turkey Suit
2003 WJ
Ah that's the ticket. Looks like a brake controller is in my somewhat near-future. My mom bought a 16ft cargo trailer and all she has that is equipped to tow it is her motorhome. Her WK2 does not have a brake controller. Plus I intend to borrow that trailer to move in a few months.
billzcat1 is offline   Reply With Quote Quick reply to this message
Unread 04-17-2013, 04:03 PM   #6125
snobrdrkid07
Mr. WJ
Yeah when I was facing towing that 14 foot enclosed trailer up to school, I would have gotten the brake controller then. Only dabbled in research for it, guess it is simple as that. Since that didn't happen, still brake-controler-less. I did putts around the neighborhood with the enclosed trailer and used it for hauling some equipment around. That thing was huge compared to the Jeep. We've got a Prodigy controller in the LR that towed the trailer up.
I'm sure the WK2 would have some wiring provisions, granted if it has a tow package. Unless you're saying the WK2 won't be used for towing it and you would just use your WJ and her, the motorhome.
-Michael-
For Sale:
Unread 04-17-2013, 04:07 PM   #6126
billzcat1
2003 WJ
Well, the WJ has higher tow capacity and 100 ft-lbs more torque, plus I don't relish the idea of drilling holes in her $50k SUV to mount a brake controller.
It would just a matter of trading cars if she needed to move the trailer (she's mostly just using it for storage).
Unread 04-17-2013, 04:15 PM   #6127
snobrdrkid07
Mr. WJ
Ahh, I see now. Ha, another point there, although I got a good laugh when we did the same to the Land Rover. "Hmm, what do you think about here?" "Sure, good enough for me, drill away." That is pretty much how that went down.
Man the V6 has a bit more HP but really lacking in torque.
-Michael-
For Sale:
Unread 04-17-2013, 07:53 PM   #6128
snobrdrkid07
Mr. WJ
Took a video of pinion noise for fun. Sounds different then others I've heard. But seems like its just a Jeep thing over 100k. I'm not too concerned as many people have this noise and don't have any problems.
-Michael-
For Sale:
Unread 04-17-2013, 08:25 PM   #6129
snobrdrkid07
Mr. WJ
Don't know what happened. Here is the video. http://www.youtube.com/watch?v=pH1lReIy3Zo&
-Michael-
For Sale:
Unread 04-18-2013, 08:27 AM   #6130
ChrisHager
ChrisHager's Avatar
Are you talking about the sound more easily heard upon decel - a rhythmic hum? It almost sounds like tires. You should hear the soothing hum from my tires if that bothers you!
Also, what are you listening to? That's clearly not country music!
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 04-18-2013, 09:23 AM   #6131
snobrdrkid07
Mr. WJ
Yeah the deceleration noise... which I thought was a pinion. Interesting.
I'm an all around type of music person.
-Michael-
For Sale:
Unread 04-18-2013, 12:37 PM   #6132
snobrdrkid07
Mr. WJ
Track bar is squeaky squeaky. Assuming its squeaking against the frame mount, needs grease. Guess I'm going to suck that one up and buy a tube of Kevin's poly grease. Maybe I'll pick up that new track bar bolt while its out.
-Michael-
For Sale:
Unread 04-19-2013, 02:18 PM   #6133
snobrdrkid07
Mr. WJ
Update! I should have some 255/75-17's on Moabs for the Jeep next weekend. Granted if everything goes to plan.
-Michael-
For Sale:
Unread 04-19-2013, 02:57 PM   #6134
billzcat1
2003 WJ
If they have Wrangler SR-As on them, don't bother. Worst tire ever. If they have the BF-G M/Ts, then get ready to trim!
Unread 04-19-2013, 03:00 PM   #6135
snobrdrkid07
Mr. WJ
Wrangler's. Going to see if they make any difference. (They're not going to be mine)
-Michael-
For Sale:
ome hd , OME lift kit , snobrdrkid , wj
