Snobrdrkid's WJ Build Thread - Page 382 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri2007-2016 Jeep JKU 4" X-series suspension lift **dea
Unread 01-01-2013, 06:09 PM   #5716
snobrdrkid07
snobrdrkid07's Avatar
I'm curious to why you would have issues with that much caster. What did it do when you had 6 or so degrees of caster?
I mean I don't understand how or why more caster would negatively affect it.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is online now   Reply With Quote Quick reply to this message
Unread 01-01-2013, 06:27 PM   #5717
wj4play
Well like a bent shopping cart wheel - bent = more caster causing the shopping cart wheel to flop back and forth
The farther away from center (0*= perfectly vertical) and increasing caster (rotating/tilting back centerline of knuckle) can cause this. That is why worn suspension on factory WJs get it due to caster to change
You measure caster on the bottom of the knuckle flat part - I used clingometer on my iPhone or you can get a digital degree level also but the app is free
99 Grand, 37" and mostly factory - Raised tank and trimmed fenders etc
wj4play is offline   Reply With Quote Quick reply to this message
Unread 01-01-2013, 06:52 PM   #5718
wj4play
This should give u an idea
Unread 01-01-2013, 07:06 PM   #5719
snobrdrkid07
Okay so a shopping cart has negative caster, and you don't want that.
The jeep has positive caster, from the factory around 6.5 to 7 degrees. I've always been told that around that number you have the most stability, lessening the caster to around 4 or such will give you less stability, less return to center, and more shimmy.
-Michael-
Unread 01-01-2013, 07:25 PM   #5720
wj4play
Actually was using shopping cart as a loose example lol
As for what is more stabile I am no expert but what I do know as with anything - more is not always better and you will find giving your jeep 7* or more will give you DW especially at higher speeds.
You will find a happy median between 6* and 4* just be ready to adjust those CAs
If IRO suggests starting at 4.5* they probably have a reason and since your changing your suspension factory rules may no longer apply
Just my 2€
Unread 01-01-2013, 07:39 PM   #5721
wj4play
Was just looking back but arm't you lifting it? Springs? Or just new ca's with factory springs?
Unread 01-01-2013, 07:41 PM   #5722
snobrdrkid07
I've got a 2.5" lift on the Jeep right now by OME HD springs.
-Michael-
Unread 01-01-2013, 07:44 PM   #5723
wj4play
Under 3" and factory specs should be fine from what I have read but in real life my 2" BB caused DW when things started to get worn
Unread 01-01-2013, 07:56 PM   #5724
snobrdrkid07
Right, I've been told that an even stock WJ can get DW with really worn out parts. And solid axle from vehicle its possible. When you take a stock WJ compared to a BB lifted WJ the only thing that essentially changes in the front is the amount of caster that you have. Right?
From what I have been previously told, at a small lift like I have factory front alignment specs are still pretty relevant.
-Michael-
Unread 01-01-2013, 08:10 PM   #5725
wj4play
BB or 2" coils achieve the same thing geometry wise. Factory specs would be just fine for you I would think
As stated by someone else earlier that your SS prolly keeping things under control. Have you thought about adding a second SS for more stability?
Also may want to consider a little adjust down to 5* if you still have some DW
Unread 01-01-2013, 08:17 PM   #5726
snobrdrkid07
Right, as you said coils or BB will do the same thing.
The thing is also this, if everything is setup right you shouldn't need a second steering stabilizer. Hopefully with these new parts going in soon it will fix it up.
Lol, again I don't have DW. Only thing I'm trying to get rid of is the little shimmy/wobble when I hit bumps. Trying to be more clear. It just shakes the steering wheel for a second or two. But it will go away on its own and will *not* continue to get worse like full blown death wobble.
-Michael-
Unread 01-01-2013, 10:09 PM   #5727
wj4play
Still sounds like mini DW
I still think even with 2" of lift you need to have your caster adjusted even tho 2" only changes castor barely.
Wider bigger tires will cause u to have feed back to the steering wheel as well. Double SS will help cure this but it is also believed that a properly setup suspension won't yield these things like you said
Unread 01-01-2013, 10:17 PM   #5728
snobrdrkid07
Hahaha, shhhh don't say that
But, I checked up on some records, on my previous alignment before the lift, I had 6.8* of caster, and now I have 4.1* of caster with my lift. So who knows how I lost that much caster. I also have a feeling that my upper control arm bushings are worn. I didn't always drive the WJ with grace as I do now.
Yeah I'm still a little concerned what it gonna happen when I go from my stock 29.5 inch tires to a 30.5 or 31 inch tire. Haha.
-Michael-
Unread 01-01-2013, 10:36 PM   #5729
wj4play
If u get those adjustable CAs and new bushings you will be fine. As u lift your wj the axle moves away from the body and the axle will rotate messing up your caster at ride height with fixed CAs
I ran 265/75/16s for 5/6 years then ran 285/75/16s on my BB for a couple of years - had to trim bumper and fenders but I liked it. 31/33s however you look at that size of tires were ok but sucked in the winter. 265s were fine though
I also don't understand everyone with junked upper bushings - I plowed for 4 years with my wj (7'6" pro plow) and when I swapped in all new CAs mine looked like new still. I expected them to be trashed
Unread 01-02-2013, 08:45 AM   #5730
ChrisHager
ChrisHager's Avatar
The dual steering stabilizers aren't necessary. Installing two only acts as a band-aide and can actually wear components more. I'd suggest getting everything replaced first and see where you're at. Adjust the CA's a little here and there until it's just how you like it.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
His: 2009 Expedition
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline   Reply With Quote Quick reply to this message
ome hd , OME lift kit , snobrdrkid , wj
