Snobrdrkid's WJ Build Thread - Page 381 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 12-27-2012, 10:41 AM   #5701
squashman702
1994 ZJ
Originally Posted by snobrdrkid07
Here you go.
Crazy. Never seen that happen before. Must've been moisture/mud/something in there for a long while.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline   Reply With Quote Quick reply to this message
Unread 12-27-2012, 10:44 AM   #5702
snobrdrkid07
snobrdrkid07's Avatar
Originally Posted by ChrisHager View Post
I can understand that. I probably need an entire weekend (or at least a full Saturday) for tinkering on mine and I'm not not seeing that happening for a while...
Yeah dude. Just extremely fortunate that it can be handed off like that.
Maybe some mud blocked the drain hole and water was able to sit up in there. But yeah, it needs replaced haha.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 12-27-2012, 03:03 PM   #5703
snobrdrkid07
Well I finally got a chance to clean the dang thing! It has been forever!
-Michael-
Unread 12-27-2012, 04:55 PM   #5704
billzcat1
Chicken in a Turkey Suit
2003 WJ
Buy a camera! Your Droid phone is not doing your beautiful Jeep any justice!
billzcat1 is offline   Reply With Quote Quick reply to this message
Unread 12-27-2012, 05:00 PM   #5705
snobrdrkid07
Ahhh i know, we have got a two at home. I just never have it on me! And they are not mine.
-Michael-
Unread 12-30-2012, 11:58 AM   #5706
snobrdrkid07
Tried to install the heated/auto dim mirror. Turns out I need some sort of harness that's long enough to connect the mirror to the door panel.
-Michael-
Unread 12-30-2012, 12:01 PM   #5707
compcrasher86
And I just got rid of my spare door panels a coupke weeks ago
Matt
compcrasher86 is offline   Reply With Quote Quick reply to this message
Unread 12-30-2012, 12:14 PM   #5708
snobrdrkid07
http://www.wjjeeps.com/mirror_autodim_wiring.jpg.
One of those.
-Michael-
Unread 12-30-2012, 05:06 PM   #5709
snobrdrkid07
So the Jeep went on huge troll mode again leaving Dad's house. Rolled the window down and then it would not go back up. Open the and closed the door and then it went back up. That ground wire in the driver door boot. *tisk tisk* Secondly the trunk would not shut, twice, then on the 3rd time it went. Need to grease the latch again I guess. Weird. Dad was just standing there having a little laugh as I am screwing around with the Jeep.
I drove the Rubicon around today and the WJ is much smoother aside from what is mostly likely the rear tires in need of balance on the WJ. (I do not know what else it could be!?) I did notice that the Rubicon does a little steering shimmy on bumps at "highway" speeds although it did feel "firmer" and not "losey gooesey" (Ya that sounds childish but that was the first thing to come to mind.) I guess new control arm bushings and a heim in the track bar have less room for play.
Lastly the WJ is finally getting that work done later this week. I am going to draft up what all is going to be done in more detail on a word document and will prbably post a link to a google doc later.
-Michael-
Unread 01-01-2013, 01:47 PM   #5710
snobrdrkid07
I found this video on youtube and was pretty interesting. I've just been wondering what causes the tires to shimmy a few times back and forth on a pothole or something like that. That is all my Jeep will do, just shimmy back and forth for a second then go away on those decent holes that jostle the suspension. But no full out DW. I don't get why it does it.
What the video shoes in the first minute or so shows, what I am guessing the WJ does when I hit a pot hole (I usually try to avoid) similar to the size in the video.
Note: Thursday the 3rd, Jeep is going in for new front upper control arms and bushings, then also installing the IRO lowers to put caster around 6.5* (Along with a ton other stuff, however the stuff upfront was worth mentioning again)
-Michael-
Unread 01-01-2013, 02:54 PM   #5711
compcrasher86
Your SS is most likely what's keeping it from going into full out DW. In that video he added new shocks and dual SS.. he probably didnt get rid of the source of his DW he just masked it :/
Matt
Unread 01-01-2013, 02:55 PM   #5712
snobrdrkid07
Right, I get that. Maybe I did not phrase it right, I was wondering why it wobbles over bumps and stuff?! haha
-Michael-
Unread 01-01-2013, 03:24 PM   #5713
wj4play
Caster angle .. I really hope you are installing adjustable lowers otherwise you won't be able to adjust your caster at all.... Fixed uppers and fixed lowers will suck if you need to tweak your caster at all. Even if they say caster will be about 6.5* you will be disappointed
IRO write up recommends 4.5* with their long arms. I am at 4.5" lift on my front with short arms and set my caster at 4* before DW stopped.
Picture a bent shopping cart wheel that wobbles back and forth.
Take my advice as you want but I hope the best to you.
Hope u work out your DW.
99 Grand, 37" and mostly factory - Raised tank and trimmed fenders etc
wj4play is offline   Reply With Quote Quick reply to this message
Unread 01-01-2013, 03:44 PM   #5714
snobrdrkid07
Hey thank you for the reply. The front uppers will be stock and the lowers will be ADJUSTABLE from IRO. I was planning on setting caster to around 6.5* which is stock spec for caster. I do not know exactly why IRO suggests 4.5* other then to avoid drive line issues with the front pinion angle.
-Michael-
Unread 01-01-2013, 06:02 PM   #5715
wj4play
Sorry if you posted before that adjustable CA but i miss a lot of detail due to being on my iPhone.
I adjusted mine to 6.5 for factory spec but it was horrible. I read IRO manual for long arms and re adjusted to 4.5 and eventually settled on 4
More caster will bring the steering wheel back to center faster than less castor, I have heard most dodges solid axle front eventually suffer DW and same with factory WJs with no lift but worn out steering components.
Just letting you know what worked for me but seem that everyone has different results on different jeeps. I wouldn't worry about pinion angle as much as I would for caster.
DL vibes can be cured with a double Cardon if you end up with that happening
ome hd , OME lift kit , snobrdrkid , wj
