Snobrdrkid's WJ Build Thread - Page 379 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options! 2 door JK Recruit Half hardtop Kits Now available!
Unread 12-23-2012, 06:51 PM   #5671
EMS WJ 2000
EMS WJ 2000's Avatar
How are your HIDs working for you and are you just running stock 100w bulbs for your highs?
Danny
2000 WJ Laredo (Daily Driver)
4.0 I-6 4x4 186,000+ miles and still going strong.
2007 Tahoe (Wife's truck)
Fully loaded
Only two defining forces have ever offered to die for you:
...Jesus Christ and the American Service Members....One died for your soul; the others for your freedom.
EMS WJ 2000 is offline   Reply With Quote Quick reply to this message
Unread 12-23-2012, 06:58 PM   #5672
snobrdrkid07
Mr. WJ
snobrdrkid07's Avatar
They've been great, running the projectors and HID's are a great combo. The high beams are halogen bulbs so there is no warm up time with flashing your high beams.
~ 04 WJ 4.0 | Selec-Trac 242 | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Custom Front D.S. | Stillen Rotors/Metal Matrix Pads | Tow Package w/ 3.73's | Projectors w/ 55w HID H1 5000K Lows | Sylvania Ultra 9005 Fogs | Moog HD Steering | Kenwood eXcelon Radio | Memphis Speakers | Alpine Amps | Alpine Subs | Moog STB SS | Superchips Flashpaq | Auxiliary Transmission Cooler | Rock Lights | Light Bars ~
~ Snobrdrkid's "Build" Thread ~ YouTube Channel ~ Fuelly ~WJ 4.0 Transmission Cooler Info ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | 2" Spacer Lift | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
For Sale:
Front XJ/TJ 2" Budget Boost. PM for details.
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 12-23-2012, 07:13 PM   #5673
JerzeyBoyWJ
2003 WJ
Didn't think you could run premium fuel unless you ran a tuner ...well I mean I guess you can run it but the safe way is with a tuner
Sent from my iPhone5 using JeepForum
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline   Reply With Quote Quick reply to this message
Unread 12-23-2012, 07:24 PM   #5674
EMS WJ 2000
I have the stock housings and I was wondering if there would be a problem running the 55w HIDs for both low and high beam with the stock housings?
Danny
Fully loaded
Unread 12-23-2012, 07:25 PM   #5675
snobrdrkid07
Mr. WJ
I've never heard that before. We've ran premium in all our ATV's, Motorcycles, Jet Skis, Boats, lawn equipment, generators, and other toys. Then Dad and I have always ran premium in the Jeeps on occasion. All the other cars we have require premium, the Jeeps are the only 2 that don't "require" it. I know for all the "toys" he will only put premium in them for whatever reason. Again I've never heard it as "bad" to run premium without a tune.
-Michael-
For Sale:
Unread 12-23-2012, 07:27 PM   #5676
snobrdrkid07
Mr. WJ
That's a very bad idea, running HID's in stock halogen housings is not the way to go. I don't want to get into it all. There are dozens of threads on Jeepforum explaining why. The glare of HID's in halogen housings is terrible. Basically don't do it.
-Michael-
For Sale:
Unread 12-23-2012, 07:30 PM   #5677
EMS WJ 2000
Darn.
Dont really want to dump a few hundreds of dollars into new housings, the ones I have are aftermarkets (not from Jeep). With the projectors could you run HIDs in the low and high beams?
Danny
Fully loaded
Unread 12-23-2012, 07:39 PM   #5678
snobrdrkid07
Mr. WJ
Darn.
Usually, only in the Low Beams. The highs are usually just halogen reflectors. The HIDs take some time to warm up and aren't good for high beams when you need to flash someone. Id only recommend halogens in the high beams.
-Michael-
For Sale:
Unread 12-23-2012, 07:40 PM   #5679
EMS WJ 2000
Cool thanks.
Can you PM me where and how much your projectors were?
Danny
Fully loaded
Unread 12-23-2012, 07:45 PM   #5680
snobrdrkid07
Mr. WJ
Cool thanks.
Sent.
-Michael-
For Sale:
Unread 12-25-2012, 08:30 AM   #5681
snobrdrkid07
Mr. WJ
Merry Christmas Everyone! Hope its all going really well for everyone and enjoying the time off.
-Michael-
For Sale:
Unread 12-25-2012, 02:00 PM   #5682
snobrdrkid07
Mr. WJ
Opinion time!
1. What bushings in the front take the most beating? The uppers or the lowers?
2. Should I get new stock rear lower control arms to help keep the rear stable?
3. Stock upper control arms and bushing replacement an okay way to go? Compared to like IRO type arms?
-Michael-
For Sale:
Unread 12-25-2012, 03:59 PM   #5683
compcrasher86
Opinion time!
1. Uppers on the WJs seem to take the most beating. Granted my lowers are much more beat up but I think that has to do with the New England road salts.
2. If you can budget it, sure. They're VERY easy to replace so its purely budget. Focus on the front first though sounds like you want a tight front end more than anything.
3. Yes. Especially if you're going to have a freshly rebuilt driveshaft you're probably unlikely to encounter driveline vibes from less than perfect front pinion angle under 3" lift.
Matt
compcrasher86 is offline   Reply With Quote Quick reply to this message
Unread 12-26-2012, 12:34 PM   #5684
snobrdrkid07
Mr. WJ
Well the good new continues. I am FINALLY getting major work done to the WJ! Here is everything that is getting done.
Front Related:
  1. Front Lower IRO CA's - Caster set to 6.5*
  2. Front Upper Control arms - Mopar
  3. Front Axle Upper Bushings - Mopar
  4. Ball Joints
Rear Related:
  1. A-Arm - Mopar
  2. Ball Joint - Mopar
  3. Rear Lower CA's - Mopar
Fluids:
  1. Brake Fluid Replace and Bleed
  2. Power Steering Flush and new Fluid, the Mopar Spec
  3. Drain and Replace Coolant with Zerex G05 or whatever it is
Misc Parts:
  1. Front Drive Shaft Rebuild
  2. Front Output Yoke is getting checked
  3. Tranmission Crossmember Replaced
  4. Emergency Brake Fix
  5. Electric Fan Replaced
  6. New U-Joints for Rear D.S.
  7. Rear Brake Rotors and Pads - if needed
I think that is most of it. Parts are being ordered this week and its getting dropped off on the 3rd!
-Michael-
For Sale:
Unread 12-26-2012, 12:50 PM   #5685
JerzeyBoyWJ
2003 WJ
What's wrong with your crossmember ?
ome hd , OME lift kit , snobrdrkid , wj
