Snobrdrkid's WJ Build Thread - Page 378 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! *STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light BaRuffstuff 10 year sale
Unread 12-18-2012, 07:22 PM   #5656
ChrisHager
ChrisHager's Avatar
Sure can. Give me a sec. Wife just got home therefore I'm on a trailer wiring break...
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
His: 2009 Expedition
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline   Reply With Quote Quick reply to this message
Unread 12-18-2012, 07:47 PM   #5657
ChrisHager
ChrisHager's Avatar
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 12-18-2012, 07:51 PM   #5658
ChrisHager
ChrisHager's Avatar
If you need measurements, I have a good hour and a half of garage time. The girls just started up a movie, my class prep is pretty much finished, and I think the trailer wiring is done! I actually have a few minutes to tinker! Haha.
Edit: Sorry if I'm junking up your thread Michael.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 12-18-2012, 07:53 PM   #5659
JerzeyBoyWJ
2003 WJ
Those are old style rc arms ...pre warning those bushing suck and you can't replace them ...I had those arms on my jeep and I called rc to order new bushings and they said I would have to order new arms because they changed over to clevlite oem style bushing and they no longer make bushings for there old arms
Sent from my iPhone5 using JeepForum
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline   Reply With Quote Quick reply to this message
Unread 12-18-2012, 08:04 PM   #5660
ChrisHager
ChrisHager's Avatar
To be honest, that's what I was leaning towards as well but I wasn't positive. Again, they are 'new' and free though I am curious what's sitting in the box.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 12-18-2012, 11:50 PM   #5661
snobrdrkid07
snobrdrkid07's Avatar
Maybe you can use those arms to "cash in" for new RC-X arms? How are they not replaceable? They one solid bushing formed into the arm?
Chris - Don't worry about it! haha
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600s | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100s | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 12-20-2012, 12:54 AM   #5662
snobrdrkid07
Did a once around the Jeep for tomorrows trip home. Filled with premium gas, checked oil, and checked tire pressure. So my passenger rear may have a slight leak, was down to 26 cold. Put both the rears to 32 cold. (ambient temp 35* F and Jeep has been sitting most of the day). Leaving the front at 28 psi cold, don't wanna mess with it, higher PSI has shown to increase wobbles on bumps, its fine now where it is at. Will mess with it later when I get home, anyways, I digress. So my friend was leaving the apartment while I was out messing with my Jeep and he wanted check his tires on his XJ for fun. Turns out his were all around 26 and he has Michelin LTX M/S tires. So I decided to check sidewall flex comparison. Pushed on the WJ sideways and my tires at 32 PSI on the rear, flexed in the sidewall and moved around like it was going out of style. The Michelin's, basically zero movement, at 26 PSI!? I could not believe it. *thumbsdown* for my tires.
-Michael-
Unread 12-20-2012, 01:07 AM   #5663
Thomahawk
Thomahawk's Avatar
Yes, all tires Are different tire pressure wise, sidewall stiffness, load range,,,,
Needed to go up from 33 to 35 psi to Get my new Hakka's comforteble and handling better.
Tires, tires, tires,,,, you Will Get it figured out.
Buildthread http://www.jeepforum.com/forum/f197/...grade-1813490/
Thomahawk is offline   Reply With Quote Quick reply to this message
Unread 12-20-2012, 01:10 AM   #5664
snobrdrkid07
Yeah man, I have been figuring that out the hard way. I used to run my tires at 35 PSI, but now that high seems like they are too "stiff" or "bouncy" and the Jeep did not like that.
Anyone want to chime in on the Goodyear SilentArmor's sidewall flex before I plunge myself into another hole?!
-Michael-
Unread 12-20-2012, 01:22 AM   #5665
Thomahawk
Thomahawk's Avatar
Sorry no, but What's up with your sno brd kid? Seing any snow lately? Rofl
Unread 12-20-2012, 01:24 AM   #5666
snobrdrkid07
Snobrdrkid = Snow Boarder Kid, which you got, and not many people do! Too bad I am not a kid anymore, life was a lot easier! haha.
But, we have one dusting here that resulted in about an inch, nothing at all! It has been a WARM winter... :/
-Michael-
Unread 12-20-2012, 08:30 AM   #5667
ChrisHager
ChrisHager's Avatar
As far as tires go, I believe I posted before in here that the Geolanders on the F250 took a ridiculous amount of PSI to get rid of the wander/sway/sidewall flex. I'm betting that the SA's will be awesome for you, especially with the reviews Billz has on them.
I didn't have too much trouble coming up with Snow Boarder Kid, though then again, I do sometimes struggle with all the 'txt' shorthand crap some people use. I mean, a little is typical for everyone but texting one, 15 character word that's all abbreviations... Really? I think I'm getting old.
We might have some snow by this evening! We've had a slight dusting previously but nothing that has stuck to the roads. They bumped our snowfall count for today up to around 3". I don't get to try out the WJ/DuraTracs though unless I go looking for some trouble - I traded ReJeana the WJ for the TJ. With the 60 MPH gusts we are going to get along with the 50F rain turning slick then to snow (it's supposed to drop from 50ish to 20ish by this afternoon and it's raining right now), I figured the 4WD Full-Time would be better than her driving a 2WD top - I really need to show her how to use/when to use the 4WD in the wrangler.
And now that I'm done rambling, I'm going back to my coffee.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 12-20-2012, 08:36 AM   #5668
snobrdrkid07
Haha, that is 2! I just remember way back when that there was some confusion about it. I made that user name, oh my, like 6 or 7 years ago now?! Thing is I can't jack the pressure, it makes the Jeep go "mehhhh" or at least the higher pressure had negative effects that one time. I thought about that last night too, no way he (Billz) could give a good review and them be shi***.
Ah, lucky! We may get some here in blacksburg tonight, too bad I am about to be on my way home to Chesapeake. Good luck with the snowfall and be safe out there!
-Michael-
Unread 12-20-2012, 08:45 AM   #5669
ChrisHager
ChrisHager's Avatar
I'd be bummed. I like snow!
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 12-21-2012, 11:19 AM   #5670
snobrdrkid07
I talked to dad some about fixing/upgrading/maintaining the Jeep over break. Most of the work won't happen until after Christmas.
He wants to replace as many parts with stock Mopar parts instead of aftermarket. For example the A-arm, so we don't have to worry about grease or adjusting, just toss it in there. Then possibly just getting new front upper's from Mopar.
Next decently big ticket item is the front driveshaft. Looking at having it rebuilt, I just need a back up plan if the rebuild does not fix the vibes... :/
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
