Snobrdrkid's WJ Build Thread - Page 362 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 11-05-2012, 10:12 AM   #5416
snobrdrkid07
snobrdrkid07's Avatar
Originally Posted by Thomahawk
I would believe thats possible, hope you got it sorted out soon.
Yeah. Me too. If there is play in the joints.
Anyone recommend anything on how to rebuild?
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is online now   Reply With Quote Quick reply to this message
Unread 11-06-2012, 10:21 AM   #5417
snobrdrkid07
Pulled out the driveshaft. While I had a Jeep friend ride with me and tell me, they weren't "bad" but something was "up". So, with that being said I'm just going to leave the shaft out until I can re build it or have it rebuilt.
Yoke is seeping a little bit of fluid. Didn't put the new seal in yet.
There was something I noticed, I was pushing up and down on the shaft and noticed a bit of movement. Turns out that ever so slight movement was coming from the yoke on the output shaft... errrrr is that a problem???
-Michael-
Unread 11-06-2012, 03:21 PM   #5418
squashman702
1994 ZJ
Sounds like a bad U joint, which would definitely cause your vibrations.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline   Reply With Quote Quick reply to this message
Unread 11-06-2012, 03:37 PM   #5419
snobrdrkid07
See my original thought was a U joint too, which I intend to replace them all anyways.
But, the yoke was able to move every so slightly up and in down. Just barely. Not sure how to describe it. Kinda like the output shaft was just slightly too small for the hole it goes through??
-Michael-
Unread 11-06-2012, 03:38 PM   #5420
squashman702
1994 ZJ
Yoke on the axle? Pinion bearing may be on it's way out.
Think Twice Garage
Unread 11-06-2012, 03:43 PM   #5421
snobrdrkid07
Yoke on t=case. Sorry.
-Michael-
Unread 11-06-2012, 03:50 PM   #5422
squashman702
1994 ZJ
Same deal still- bearing may be on it's way out.
Think Twice Garage
Unread 11-06-2012, 03:52 PM   #5423
snobrdrkid07
Well damn. Ant correlation to me swapping the yokes and the bearing deciding to go "bad"
Also if this is loose could that cause vibes? And when I mean loose, I'm talking like a half of a millimeter of movement.
-Michael-
Unread 11-06-2012, 04:14 PM   #5424
compcrasher86
Make sure the shaft is actually moving as well and its not just the yoke moving on the shaft/not tight enough.
Matt
compcrasher86 is offline   Reply With Quote Quick reply to this message
Unread 11-06-2012, 04:17 PM   #5425
snobrdrkid07
This is still possible. Yet its cranked down to 110 foot pounds at the moment. Gonna have another Jeep Club friend check it out sometime this week and go from there.
-Michael-
Unread 11-10-2012, 01:45 PM   #5426
snobrdrkid07
Hmmm what is this. Haha
-Michael-
Unread 11-10-2012, 01:51 PM   #5427
Thomahawk
Thomahawk's Avatar
Idk, but look sweet, drool....?
Buildthread http://www.jeepforum.com/forum/f197/...grade-1813490/
Thomahawk is offline   Reply With Quote Quick reply to this message
Unread 11-10-2012, 01:52 PM   #5428
snobrdrkid07
Rubicon is getting some new poly bushings apparently.
-Michael-
Unread 11-10-2012, 07:14 PM   #5429
billzcat1
Chicken in a Turkey Suit
2003 WJ
Attachment 504896
A bad idea? Poly bushings have no place in those control arms.
billzcat1 is offline   Reply With Quote Quick reply to this message
Unread 11-10-2012, 07:51 PM   #5430
snobrdrkid07
And this is why I wish dad would have told me that he was going to do that. I believe they are from energy suspension. I would have told him just to order IRO adjustable control arms, again if I knew prior too.
How bad of an idea is it to have those there... *sigh*
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
