Snobrdrkid's WJ Build Thread - Page 361 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 11-02-2012, 10:22 AM   #5401
snobrdrkid07
snobrdrkid07's Avatar
Yeah, no kidding. I'm not sure what they freaking sold me. "Cooler" is a start. Maybe I'll go back and ask for transmission line and see what they give me. What's different between like transmission cooler and like other "cooler" type line?
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 11-02-2012, 11:03 AM   #5402
billzcat1
Chicken in a Turkey Suit
2003 WJ
You have to watch out for those parts monkeys. I asked for Power Steering Return hose (in stock at $1.29/ft per AZ webpage). They give me fuel injection hose at $4.09/ft. Parts Monkey says "yes it's compatible, and higher pressure rating". I go home and google it. Fuel Injection Hose? BAD IDEA. Transmission cooler/Power steering return hose is a different compound and is rated for 4 times the pressure.
billzcat1 is offline   Reply With Quote Quick reply to this message
Unread 11-02-2012, 11:12 AM   #5403
snobrdrkid07
Well it does in fact say cooler on it. I don't know what it says before that because its tucked away. So that's a "start" in the right direction, right? Maybe?
I'm not sure why the one would be leaking and the rear are fine.
-Michael-
Unread 11-02-2012, 11:17 AM   #5404
Thomahawk
Thomahawk's Avatar
When its labeled cooling, my first thought is Coolant fluid, might be good enough, i dont know, i just know there Are Oil/fuel specific Lines, also due to temp and pressure, check it out, make sure you have the right one.
Buildthread http://www.jeepforum.com/forum/f197/...grade-1813490/
Thomahawk is offline   Reply With Quote Quick reply to this message
Unread 11-02-2012, 12:46 PM   #5405
leadsled jeep
I just KNEW I liked Jeepers! I am a 1911 guy as well. Stock Springfield Loaded stainless here. I did just order some XS tritium sights for it however.
Just starting IDPA matches here.... Once a month. Good stuff!!
Chris
'02 Overland 176k+ miles. 2.5" lift, EMF Control Arm upgrades
leadsled jeep is offline   Reply With Quote Quick reply to this message
Unread 11-02-2012, 02:31 PM   #5406
snobrdrkid07
Hmmm. Will have to check it out more. Could replace that whole hose with the "transmission cooler" hose that came with the cooler itself? (I still have that spare hose and the factory hose just in case for these situations)
-Michael-
Unread 11-02-2012, 02:41 PM   #5407
Thomahawk
Thomahawk's Avatar
If you have the line that came with the cooler and its the right size and length needed, i would just swap that in with a good clamp and not think of that any more.
Unread 11-02-2012, 03:16 PM   #5408
compcrasher86
It could be that the clamp chewed through the hose I've seen that before. Cut an inch off the hose like tomahawk said and slip it on and re-clamp. Make sure inside of clamp is smooth and doesn't have any sharp edges.
Matt
compcrasher86 is offline   Reply With Quote Quick reply to this message
Unread 11-02-2012, 03:19 PM   #5409
Thomahawk
Thomahawk's Avatar
Exactly what i pictured in my mind, ha ha
Unread 11-02-2012, 03:59 PM   #5410
snobrdrkid07
I'll cut off a section and recap and try that first before I replace everything. Would try that first.
-Michael-
Unread 11-03-2012, 09:58 PM   #5411
snobrdrkid07
Hope to put in the drive shaft tomorrow. We shall see. Also get that seeping auxiliary line taken care of.
Realizing today how bad I need that a-arm fixed. Had 5 people on board on the highway, the Jeep was line bouncing and steering felt oddly loose. Errhh. Maybe because of the weight it was making it feel like that.
-Michael-
Unread 11-04-2012, 04:28 PM   #5412
snobrdrkid07
New front yoke went on without issue. Drive shaft fit just fine... BUT, too bad it vibrates?! 35+ it has a noticeable vibration. Not to the point where the Jeep is shaking apart but enough to not be acceptable. Will be seeing who is local around here to get it rebalanced/rebuilt.
-Michael-
Unread 11-04-2012, 08:03 PM   #5413
compcrasher86
Ugh that's obnoxious dude maybe a weight got knocked off or something? Check the u-joints thoroughly on the DC and axle end?
Matt
Unread 11-04-2012, 08:06 PM   #5414
snobrdrkid07
All the weights look to be there. I am thinking the 3 u-joints need replaced. The double cardon end was a bit sloppy.
Would bad u-joints or center "Ball" thing cause vibes?
-Michael-
Unread 11-05-2012, 02:46 AM   #5415
Thomahawk
Thomahawk's Avatar
I would believe thats possible, hope you got it sorted out soon.
ome hd , OME lift kit , snobrdrkid , wj
