Snobrdrkid's WJ Build Thread - Page 338 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
WIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,
Unread 08-14-2012, 01:04 AM   #5056
JerzeyBoyWJ
2003 WJ
Originally Posted by snobrdrkid07 View Post
To those who want close up pictures, or were interested in the WJ Rough Country adjustable a-arm.
Attachment 452532
Attachment 452531
Attachment 452533
Attachment 452534
I don't like the factory frame bushings, ehh. Also the out of place area where it mounts over the axle. I think ill still go IRO for sure.
IRO still uses the factory bushings where it mounts to the frame so theres no difference there ...but the only difference from IRO's VS. Rough Country is where they mount on the axle ...but i really do like how rough county has mounts on the a arm for the brake lines and all that ...when IRO just has you leave the break lines hanging and not attach to the a-arm like it was with the stock a arm
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline   Reply With Quote Quick reply to this message
Unread 08-14-2012, 10:44 AM   #5057
compcrasher86
Dint know IRO bushings are like stock, I did hear they don't use crown or Omix ada due to quality control issues, that's just the word of the grapevine though idk. I'm curious who rough country uses. Also, anybody know the price on the RC arm? I've gotten a couple IRO products that are nothing but quality and I've heard of some not so great stories about WJ specific RC items (erhem shock relocation brackets)
Matt
compcrasher86 is offline   Reply With Quote Quick reply to this message
Unread 08-14-2012, 10:53 AM   #5058
JerzeyBoyWJ
2003 WJ
those shock relocation brackets are the worst ...like idk how they even thought they were gonna work ....your cant relocate where the shock mounts in only one spot ..then its gonna cause a serious angle where you didnt relocate ..then you say buh bye to your bushings in like 3 weeks
happened to me ..so i know from experience ..sadly ive had the whole RC experience ...i should make a youtube documentary
Unread 08-14-2012, 05:13 PM   #5059
snobrdrkid07
snobrdrkid07's Avatar
Waiting on a price for the rough country a-arm.
Not if its a similar price, IRO will still be a winner no doubt.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 08-14-2012, 07:48 PM   #5060
billzcat1
Chicken in a Turkey Suit
2003 WJ
The difference in the mount is so that the RC arm can be longer without requiring the axle to move back. Remember it is supposed to come with their LA kit.
Lengthening the upper A-arm without lengthening the lower arms will increase antisquat a lot if your rear a-arm is angled upward (axle to body) more than your lower arms. It'll decrease anti squat if you are angled less than your lower arms. So the height adjustment/varied mounting positions may be key here. Is there even enough room above the axle at this lift height to accommodate the taller mount for either of the AM A-arms?
billzcat1 is offline   Reply With Quote Quick reply to this message
Unread 08-14-2012, 07:54 PM   #5061
snobrdrkid07
I do know that the IRO a-arm can work with 2-7" inches of lift. I actually don't know about the rough country arm, like the minimum lift. I did talk on the phone to an IRO rep asking what happens when I load the jeep and my lift height dips just below two inches and he said it'd be okay. Now the other thing is that I need to adjust any after market arm to the length of my current a-arm to keep the pinion angle in check.
The rough country axle mount looked like it mounted closer towards the front of the vehicle from my perspective.
-Michael-
Unread 08-14-2012, 08:02 PM   #5062
billzcat1
2003 WJ
Yeah, no. Check this out.
It would move the mount to the rear of the axle centerline.
And you'd only match A-arm to OEM arm length if you were certain the pivot were in the same spot. If you install any of the adjustable A-arms, you'll have to set the pinion angle with it installed.
Unread 08-14-2012, 08:05 PM   #5063
snobrdrkid07
You know what. I was looking at it backwards. My bad. But what was that picture supposed to show? The a-arm spacer?
The two bolts go in the rear and the 1 bolt goes in the front. Oops!
Edit: you're right, makes sense, different mounting point, can't be the same length.
-Michael-
Unread 08-14-2012, 08:07 PM   #5064
billzcat1
2003 WJ
No just show the layout of the triangular bolt pattern.
Unread 08-14-2012, 08:13 PM   #5065
snobrdrkid07
Yeah, got that now haha. Little slow tonight, haha.
What do you think? RC or IRO?
-Michael-
Unread 08-14-2012, 09:02 PM   #5066
billzcat1
2003 WJ
I dunno. Send your money to China or USA?
Unread 08-14-2012, 09:05 PM   #5067
snobrdrkid07
America any time and any day. IRO quality and reputation says enough.
-Michael-
Unread 08-15-2012, 03:36 PM   #5068
snobrdrkid07
Can I get a pic request of the Moog TRE on the pitman arm? For some reason I think mine is not tight enough. I will grab a picture of mine later on.
-Michael-
Unread 08-15-2012, 03:42 PM   #5069
billzcat1
2003 WJ
Just retorque it to spec and you'll know for sure.
Unread 08-15-2012, 03:46 PM   #5070
snobrdrkid07
That's a better idea, lol. What is the torque spec? I could not find it on the WJ info thread sticky.
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
