Snobrdrkid's WJ Build Thread - Page 336 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
Introducing MONSTALINERô UV Permanent DIY Roll On Bed LineWIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ
Unread 08-07-2012, 03:11 PM   #5026
mreed21
Thanks.
Sent from my DROID RAZR using JeepForum
mreed21 is offline   Reply With Quote Quick reply to this message
Unread 08-07-2012, 03:13 PM   #5027
snobrdrkid07
snobrdrkid07's Avatar
Not a problem man. I really trust Eric the car guy. He has great videos and great info.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 08-10-2012, 01:33 PM   #5028
snobrdrkid07
Finally. Going down to the shop on Monday.
-Michael-
Unread 08-10-2012, 03:17 PM   #5029
Dusk53
Youre taking your jeep to the shop to get your track bar bushings swapped out? Did i miss something?
http://www.jeepforum.com/forum/f197/dusks-wj-build-1272851/ - Mah build
East Carolina University
Dusk53 is offline   Reply With Quote Quick reply to this message
Unread 08-10-2012, 03:19 PM   #5030
snobrdrkid07
Going down to the shop because they are also going to road force balance the tires. Then also double check the track bar bolt holes.
-Michael-
Unread 08-10-2012, 03:23 PM   #5031
Dusk53
Ahh i see... I need to get my tires balanced too. I hope those holes aren't ovaled out bud.
Unread 08-10-2012, 03:35 PM   #5032
ChrisHager
ChrisHager's Avatar
If they are, your friends helping you out at the shop should be able to weld on a couple washers pretty easily. Shouldn't be too big of a hassle.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
His: 2009 Expedition
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline   Reply With Quote Quick reply to this message
Unread 08-10-2012, 03:46 PM   #5033
snobrdrkid07
Yeah they should be able to do that without any issue. My Jeep is trolling me, I've got to get the new bushings in. Too much axle movement currently. Its causing some oscilation on bumps. I swear, greasing the bushings made them go to sh**. Oh well, thankfully those new bushings are in. Like those JKS bushings are bad. I mentioned before that the bar is over a year old, maybe they had a bad run way back when.
-Michael-
Unread 08-11-2012, 12:33 AM   #5034
snobrdrkid07
Hey guys, I did a walk around of my Jeep for fun today. Please take a few minutes to watch and tell me what you think in the comments on YouTube! It is currently the featured video, here is a link to my channel, don't forget to subscribe please!
http://www.youtube.com/user/Snobrdrkid07/featured
-Michael-
Unread 08-12-2012, 02:52 PM   #5035
Larryftmfw
You did a good job on the video! Jeep is looking good
Sent from my iPhone using JeepForum because I can!
Larryftmfw is offline   Reply With Quote Quick reply to this message
Unread 08-12-2012, 04:42 PM   #5036
snobrdrkid07
Thanks man! It was a quick and fun little video!
-Michael-
Unread 08-12-2012, 04:51 PM   #5037
Larryftmfw
Yea, those shocks look good! But I'd ditch the boots if I were you, they tend to hold water and dirt in them and will ruin You'r shocks quickly
Unread 08-12-2012, 09:40 PM   #5038
snobrdrkid07
Removing the boots voids the warranty. Also, there are drain holes in these boots if something gets in there. The seal at the top is spot on too
-Michael-
Unread 08-12-2012, 11:01 PM   #5039
Larryftmfw
That's crazy
Unread 08-12-2012, 11:03 PM   #5040
snobrdrkid07
Only way water cab get in there is if its submerged for a long period of time. The boot seals on the top and bottom are very tight.
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
