Snobrdrkid's WJ Build Thread - Page 333 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 07-31-2012, 10:06 AM   #4981
ChrisHager
ChrisHager's Avatar
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
His: 2009 Expedition
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is online now   Reply With Quote Quick reply to this message
Unread 07-31-2012, 10:28 AM   #4982
Thomahawk
Thomahawk's Avatar
Niiiiiceeeeeee!
Buildthread http://www.jeepforum.com/forum/f197/...grade-1813490/
Thomahawk is offline   Reply With Quote Quick reply to this message
Unread 07-31-2012, 12:33 PM   #4983
AgitatedPancake
Cool, sounds like he did a quick look at things for you. If you still have any slop at all after the track bar bushing replacement I'd inspect the control arms a little more thoroughly than just looking. The upper control arm bushing that I showed you a picture of is tucked up in the body and not something you can get a very good look at for inspecting. I'm suspect of them in any high mileage WJ, even if not death wobbling.
To contact me, email Greg@Frobotfab.com
Frobot Fabrication Facebook
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread: http://www.mallcrawlin.com/forum//showthread.php?t=7387
AgitatedPancake's Youtube Channel
AgitatedPancake is offline   Reply With Quote Quick reply to this message
Unread 07-31-2012, 12:40 PM   #4984
snobrdrkid07
snobrdrkid07's Avatar
I agree, if it is still swaying around after the track bar is tightened up. We will have to pull control arms and look more closely at them. At least I now know the ball joints don't have any play in them. And the the control arms don't have any noticeable movement during the "front end shakedown" that's what he called it lol.
Like I said previously, I am going to take it back and we are going to the track bar install and we will closely look at the track bar hole etc. There was no point to take it off today to turn around and do the same thing a few days later and install the new bushings. (Hope the bushings will be here Friday or Saturday)
At least for now I have some more peace of mind that its not going to fall apart on me.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 07-31-2012, 12:43 PM   #4985
snobrdrkid07
Ouch rust. :
Found that hiding behind a piece of trim plastic. Driver side rear tire fender.
Scraped the bubbled paint and scraped the rust off to clean sheet metal and painted over w/ touch up paint. Going to clear coat it later.
forumrunner_20120731_134307.jpg   forumrunner_20120731_134314.jpg   forumrunner_20120731_134332.jpg
-Michael-
Unread 07-31-2012, 01:32 PM   #4986
wj4play
Originally Posted by snobrdrkid07 View Post
Ouch rust. :
will come back it you at least did not blast it or use some rust eating primer Just FYI
EDIT: fixed it
wj4play is offline   Reply With Quote Quick reply to this message
Unread 07-31-2012, 01:35 PM   #4987
snobrdrkid07
Originally Posted by wj4play
will come back it you at least did not blast it or use some rusting primer Just FYI
Umm. Not sure what you mean. Can't read the text haha
-Michael-
Unread 07-31-2012, 01:42 PM   #4988
squashman702
1994 ZJ
It's not clean enough- should have sanded down some of the area. That will last for a bit but the rust will bubble back through.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline   Reply With Quote Quick reply to this message
Unread 07-31-2012, 01:49 PM   #4989
snobrdrkid07
Well if it will hold for a bit that's fine. If someone would like to share the correct way to do it, that'd be great. Sounds like I need to rough it up more? I had scraped it down to bare silver sheet metal and then went over it with the touch up. Needs primed first?
-Michael-
Unread 07-31-2012, 02:26 PM   #4990
wj4play
http://www.rustoleum.com/CBGProduct.asp?pid=40
Unread 07-31-2012, 02:32 PM   #4991
snobrdrkid07
Thanks man. Ill pick up a can of that and redo it
-Michael-
Unread 07-31-2012, 02:35 PM   #4992
compcrasher86
Ouch! That's how it all starts. Mud and water and gunk gets held back there and it just starts eating away. Sucks. Funny because mine is spotless up until the rockers and then it's like Hooooooly moly. Still gotta decide what to do about that. I may just cut them out the overland sliders pretty much take their place.
Matt
compcrasher86 is offline   Reply With Quote Quick reply to this message
Unread 07-31-2012, 02:39 PM   #4993
snobrdrkid07
I knowww I hate it. Really makes me upset. Thankfully that is the ONLY spot on the entire painted surface that I have an issue with. If it comes back ill have a shop take a look at it. But what are you gonna do about it, other then fix it, its just going to happen. The entire under body frame doesn't have a spec of rust on it. The only other issue with rust was where the coil perch was. That is virtually it. I've taken care of all other spots with "rust-killer" primer and black paint.
-Michael-
Unread 07-31-2012, 02:40 PM   #4994
compcrasher86
Rust is a killer it really sucks man. Mine never had a single problem till I moved up north the salt they have in upstate NY chews metal apart vs in my hometown salt is banned so we only get sanded which is awesome
Matt
Unread 07-31-2012, 02:43 PM   #4995
snobrdrkid07
Ugh... terrible. Salt is a killed. I wish the whole uni-body was dunked in like multiple layers of primer to get into every last crack.
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
