Snobrdrkid's WJ Build Thread - Page 331 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 07-30-2012, 03:04 PM   #4951
Larryftmfw
Originally Posted by snobrdrkid07
No, there was no need to.
That's what you think! You'll need em
Sent from my iPhone using JeepForum because I can!
Larryftmfw is offline   Reply With Quote Quick reply to this message
Unread 07-30-2012, 03:16 PM   #4952
ChrisHager
ChrisHager's Avatar
...I didn't...
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
His: 2009 Expedition
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline   Reply With Quote Quick reply to this message
Unread 07-30-2012, 03:21 PM   #4953
snobrdrkid07
snobrdrkid07's Avatar
Originally Posted by AgitatedPancake View Post
Sorry it took me a while to get back to your thread! You definately have some excess movement at that frame side track bar bushings, I have no experience with Kevins but harder bushings should help out for sure. The pop in the floorboard/gas pedal....if I had to throw a shot in the dark I would say control arm bushings. The sway you describe sounds a LOT like how my jeep used to drive on short arms, the upper control arms had never been removed from the jeep let alone had a bushing replaced. Needless to say, the frame side bushings were SHOT when I pulled the short arms out to install claytons so long ago.
You might need to unbolt the control arms to see the frame side bushings, but if they are anything like mine were 6 years ago, it's worth it! If you have any slop in the balljoints also, that will cause wandering as well so good thing you're getting it all checked out. Unit bearing is the term for your front wheel bearing assemblies. They wear out like wheel bearings on any vehicle, and have to be replaced if they start to have slop, causing wandering similar to shot balljoints.
Not a problem man, I'm glad you were able to!
For the Track Bar, I agree that that amount of movement is way too much and I am pretty sure that is not helping with some of the slop in the steering. When I back out of the drive way I notice how much lateral movement there is between the axle and the body. To me, that screams track bar. You can just see it move back in forth over the axle. As for the KOR Bushings, there have been a few members on here that run them and have been happy with the lack of movement with them. A video of the KOR bushing movement from a member. (Running a JKS track bar.)
http://vid1103.photobucket.com/album.../VIDEO0008.mp4 - (Thanks Chris!) What do you think about that amount of movement?
For the wondering on the road/highway, I would have guessed that it would be caused by the track bar movement? The "pop" sound is ONLY when turning the wheels or when there is lateral stress on the Jeep/Axle. For example turning out of a parking spot or when taking a turn off an exit ramp on the highway. From what I have been able to see, the Control Arms still look solid. I guess I will find out more when I take the track bar off tomorrow and see what the bolt hole looks like. My guess is that the sleeve is moving around. Not sure how with 100 ft-lbs of torque on it...
So for the final run down list for tomorrow:
  • Checking the Frame Side TB Hole for wallowing - if they are messed up, gonna see if they can do that washer welding thing
  • Try to figure out what is popping, I will show the guys at the shop what I am talking about. Will give them a demo haha
  • Inspect the Ball Joints - IF bad, replace asap
  • Un-Bolt and inspect control arm bushings - IF bad, will have them look at getting RC-X adjustable lower control arms at COST, (they are a RC dealer), but would rather have something other then RC...
  • I will tell them about the unit bearing as well.
  • Replacing the JKS bushings with KOR Bushigns later this week to get rid of the slop
Can worn "incorrectly" tires cause vibrations?
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 07-30-2012, 03:22 PM   #4954
snobrdrkid07
Originally Posted by ChrisHager View Post
...I didn't...
Nope, you don't. You can use the JKS sleeves. The KOR bushings are a direct replacement of the JKS bushings.
-Michael-
Unread 07-30-2012, 03:33 PM   #4955
Larryftmfw
So I thought too until they caused excessive play
Unread 07-30-2012, 03:34 PM   #4956
snobrdrkid07
I am confused? My bushings are what is causing all that movement...
-Michael-
Unread 07-30-2012, 03:35 PM   #4957
Larryftmfw
I'm saying the sleeves from my jks bar were loose inside the kor bushing
Unread 07-30-2012, 03:38 PM   #4958
ChrisHager
ChrisHager's Avatar
WJ Grand Cherokee Note: This kit not necessary for installation on a JKS-127 bar for the WJ Grand Cherokee. Use the sleeves the bar came with, and our KOR-1199 bushings instead.
KOR Bushings
Front; 1.0 - 6.0" Lift; Poly Bushing; PN OGS127 $160.00
JKS Adjustable Track Bar
Perhaps you had an issue with your track bar?
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 07-30-2012, 03:42 PM   #4959
snobrdrkid07
Larry - You may have had an issue with your JKS bar. Everyone I have talked to said the JKS sleeves and the KOR bushings were extremely hard to press in.
-Michael-
Unread 07-30-2012, 03:43 PM   #4960
Larryftmfw
No it was just some improperly molded bushings I suspect
Unread 07-30-2012, 05:02 PM   #4961
snobrdrkid07
Maybe... not sure what happened. What did you do with them?
-Michael-
Unread 07-30-2012, 05:09 PM   #4962
Larryftmfw
Returned them *****es lol
Unread 07-30-2012, 05:18 PM   #4963
snobrdrkid07
Oh hahaha. What now, running JKS bushings again?
-Michael-
Unread 07-30-2012, 05:28 PM   #4964
Larryftmfw
The ones from the iro track bar
Unread 07-30-2012, 05:31 PM   #4965
snobrdrkid07
The JKS sleeves and JKS bar work with the IRO bushings??
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
