Snobrdrkid's WJ Build Thread - Page 328 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 07-26-2012, 08:15 AM   #4906
squashman702
1994 ZJ
Originally Posted by snobrdrkid07 View Post
I'm not sure what that is? I'm running a regular old JKS bar.
Double shear means that the bolt is set up as follows:
Bolt head> bracket > trackbar bushing > bracket > nut.
Single shear factory setup on a ZJ/TJ/XJ/etc (not sure about the WJ) is:
Nut> bracket > TRE end of trackbar.
The quick explanation is that double shear is typically what most aftermarket setups utilize because it's stronger and splits the force on the bolt across two metal brackets instead of one.
If you're not able to get the torque wrench to click on 90 lb/ft on the axle side, I'd be willing to bet that it's not tight enough. Trade the torque wrench for a breaker bar and cheater bar if you can't physically put enough force on the torque wrench. Also, did you pull the bolt and trackbar entirely then run the bolt back through to see if the hole has wallowed out at all?
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline   Reply With Quote Quick reply to this message
Unread 07-26-2012, 08:24 AM   #4907
snobrdrkid07
snobrdrkid07's Avatar
The way its is on the WJ is: bolt head, frame, tb, frame, nut. The nut isnt shifting around so I would not think that it is wallowed out. I took a impact gun to it yesterday and its around 100 ft-lbs now.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 07-26-2012, 08:40 AM   #4908
ChrisHager
ChrisHager's Avatar
I still may get the KOR bushings, what do you think?
The KOR Bushings may help. It's hard to say really. If you've ruled everything else out, they're worth a try!
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
His: 2009 Expedition
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is online now   Reply With Quote Quick reply to this message
Unread 07-26-2012, 08:49 AM   #4909
snobrdrkid07
Yeah the might. I just drove it again at 34 psi cold and its much better then it was. It doesn't want to try and dw automatically at 50 MPH. Im wondering if my tires wore funny...
-Michael-
Unread 07-26-2012, 09:07 AM   #4910
squashman702
1994 ZJ
Did you pull everything and check it like I said? Best way to be sure.
Think Twice Garage
Unread 07-26-2012, 09:17 AM   #4911
snobrdrkid07
I've had it out a few times now. The holes look fine. I will take a video if the noise later today after work. Ill put the camera under the front and just turn the wheels back and forth to x2 check everything. I don't understand how it wallow out when I havent had any actual full out DW.
-Michael-
Unread 07-26-2012, 11:06 AM   #4912
squashman702
1994 ZJ
It could wallow out but not be big enough to allow for enough movement for full-on deathwobble.
If you're not getting death wobble, you need to get under yourself while someone else moves the wheel and touch all of your joints (TRE, trackbar, etc) to make sure that things are not moving. The slight movement you get probably won't be readily apparent without doing so.
Think Twice Garage
Unread 07-26-2012, 11:13 AM   #4913
snobrdrkid07
Man, that sucks. :/ how do you fix it?
I am probably going to do that today. I will have my video camera under there and check for things. Especially the track bar. Because fortunately I am not getting full out death wobble
-Michael-
Unread 07-26-2012, 11:16 AM   #4914
ChrisHager
ChrisHager's Avatar
You can fix it by welding on some proper sized washers...
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 07-26-2012, 11:24 AM   #4915
snobrdrkid07
This is true. You know what guys. I forgot about my friends who own a performance/offroad shop. Ill call them later today and I'm sure they could help me out with this track bar situation. (I have not confirmed that it is wallowed, I doubt it is, but they can look at it too and fix if needed)
-Michael-
Unread 07-26-2012, 12:10 PM   #4916
squashman702
1994 ZJ
This is the best solution. Done it on a couple of Jeeps and worked every time.
Think Twice Garage
Unread 07-26-2012, 12:19 PM   #4917
snobrdrkid07
I think I am going to weld in some washers. Regardless if the bolt holes are bad or not. Just for good measure. Any chance anything is wrong with the axle side mount?
I am going to give my friends a call about welding that in there. The guys hat own the off road shop. They should be able to help me out.
I need to know what size washers to get. Thickness, material, inside diameter and outside diameter. Also I may get a new grade 8 bolt.
Sorry I've been extra 'stressed out'. Between the jeep giving me crap and one of my best friends and roommate being in the hospital. I've been really just been over my stress limit.
Still working on getting that video of the track bar later today.
Planning on doing an oil change and having the ball joints professionally looked at this weekend
Future note, if all goes well I may get some rough country adjustable lower control arms. Because my friends who own the off road shop are a rough country dealer and may be able to hook me up with some arms for cheap.
-Michael-
Unread 07-26-2012, 12:22 PM   #4918
Larryftmfw
The only thing I'm thinking is my track bar holes are very wallerd! But it hasn't caused a death wobble yet
Sent from my iPhone using JeepForum because I can!
Larryftmfw is offline   Reply With Quote Quick reply to this message
Unread 07-26-2012, 12:47 PM   #4919
squashman702
1994 ZJ
You need to check the axle side of the mount the same way as the body side. Odds are, the axle side is the issue. The metal for the mount is thinner and I have only seen the hole wallowed out on that side.
In terms of hardware, the stock bolt size on a ZJ is an M10 IIRC. Never owned a WJ, but the D30 is fairly similar between the two. Go to HD/Lowes/Tractor Supply and track down a washer that is tightest on this bolt- it won't neccesarily be an M10- may be M8 or a standard size, and use that to weld in place. I would definitely replace the bolt at this point as well.
No need to waste the money to get the ball joints looked at. Jack up one side with the wheel still on the Jeep, and wedge a pry bar under the tire. If you have anything more than a CH of play vertically in the tire, you probably need to do ball joints. The allowable standard is somewhere around 1/32-1/16" of movement.
Think Twice Garage
Unread 07-26-2012, 12:59 PM   #4920
snobrdrkid07
I'd be really surprised if the axle side was the issue. Usually on the WJ it is the frame side where I see people weld washers onto it. None the less ill have them both checked out. Not sure, wonder if someone else can say.
Ill see if someone can chime in on the bolt and washer size. Ill need to get all of these parts prior to starting to take things apart.
Alright maybe ill do that too when I get a chance later today.
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
