Snobrdrkid's WJ Build Thread - Page 327 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 07-25-2012, 08:30 PM   #4891
Thomahawk
Thomahawk's Avatar
Originally Posted by snobrdrkid07
Yeah man. Alot of progress. I'm trying to track down death wobble now. Kinda making me want to go back to stock. Lol.
Ha ha ha, i see, keep digging into it, you Will find the reason for the DW.
NO Way back!!!
Buildthread http://www.jeepforum.com/forum/f197/...grade-1813490/
Thomahawk is offline   Reply With Quote Quick reply to this message
Unread 07-25-2012, 08:35 PM   #4892
snobrdrkid07
snobrdrkid07's Avatar
I've done sooooo much only a few things left. Track bar bushings too soft or tires worn incorrectly and causing issues.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 07-25-2012, 08:38 PM   #4893
99WJdan
I have that pop too!
99' WJ 4.7, 3.5" lift, Bilsteins, JKS goodies, 32" Guard Dogs on 16x7 4" BS Soft 8s
Build- http://www.jeepforum.com/forum/f197/99wjdans-build-thread-1304554/
99WJdan is offline   Reply With Quote Quick reply to this message
Unread 07-25-2012, 08:40 PM   #4894
snobrdrkid07
Yeah. Idk what it is man. Track bar?
-Michael-
Unread 07-25-2012, 08:49 PM   #4895
Thomahawk
Thomahawk's Avatar
Maybe its just the Money poping sound, lol,
sorry guys.
Unread 07-25-2012, 08:49 PM   #4896
99WJdan
No idea. Mine sounds like its coming from passenger side front. Also a pop noise when braking sometimes.
Im just shot gunning it now in hopes of fixing it. Im not 100% positive on this but when i replaced the axle shafts in october it went away for a little. Going to replace ball joint next i guess. Maybe jks bushings. I doubt the axle shafts went bad in like 4 months.
Unread 07-25-2012, 08:55 PM   #4897
snobrdrkid07
sorry guys.
Yeah I am busted haha.
It sounds like the TB on my because it happens when I go into the drive way on an angle and one tire hits the bump then the other and Ill hear it.
-Michael-
Unread 07-25-2012, 08:58 PM   #4898
99WJdan
Yup. At a certain angle right? Mine does it almost a full lock turning right. About when the drivers side goes off the curb and the passenger side is on top still.
Unread 07-25-2012, 09:02 PM   #4899
snobrdrkid07
My sound is always from the same spot, turning either way. But it doesnt have to be full lock going to the drive way for that to make the sound. weird...
-Michael-
Unread 07-25-2012, 09:06 PM   #4900
99WJdan
Oh well if you find out what it is let me know and vise versa haha.
Unread 07-25-2012, 09:08 PM   #4901
snobrdrkid07
You got it. Getting my other set of rims/tires tomorrow. Didn't have any issues with them when I had them on before the lift. Gonna find out whether or not my tires are worn badly.
-Michael-
Unread 07-26-2012, 07:59 AM   #4902
squashman702
1994 ZJ
Sounds a lot like a trackbar issue. Are you running double shear on the body side?
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline   Reply With Quote Quick reply to this message
Unread 07-26-2012, 08:03 AM   #4903
snobrdrkid07
I'm not sure what that is? I'm running a regular old JKS bar.
-Michael-
Unread 07-26-2012, 08:11 AM   #4904
ChrisHager
ChrisHager's Avatar
Mine made noise because the jam nut worked loose. I'm sure you checked it but it wouldn't hurt to check it again. Also, make sure your track bar end links are tight. They will make a clunk as you describe.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
His: 2009 Expedition
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is online now   Reply With Quote Quick reply to this message
Unread 07-26-2012, 08:13 AM   #4905
snobrdrkid07
Yeah my jam nut is tight. I checked last night.
I lowered the PSI of the tires and torqued down the track bar bolt yesterday and now its feeling like it wants to dw at 50 MPH. I'm thinking the tire pressure did that. Ill put them back up to 33-34 and see what that does.
I still may get the KOR bushings, what do you think?
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
