Snobrdrkid's WJ Build Thread - Page 326 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
WIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,
Unread 07-25-2012, 09:15 AM   #4876
snobrdrkid07
snobrdrkid07's Avatar
Sure enough that one tire was out of balance. I watched them do the other 3 and the machine said they were 'OK'. When they got to the one that had NO weights on it. It was 0.25 oz out of balance on the one side. Vibes are mostly gone. Going to rotate the tires and put the one remaining tire that was worn wrong in the rear.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 07-25-2012, 09:47 AM   #4877
Larryftmfw
Very good
Sent from my iPhone using JeepForum because I can!
Larryftmfw is offline   Reply With Quote Quick reply to this message
Unread 07-25-2012, 12:23 PM   #4878
99WJdan
Glad you got that settled.
99' WJ 4.7, 3.5" lift, Bilsteins, JKS goodies, 32" Guard Dogs on 16x7 4" BS Soft 8s
Build- http://www.jeepforum.com/forum/f197/99wjdans-build-thread-1304554/
99WJdan is offline   Reply With Quote Quick reply to this message
Unread 07-25-2012, 12:26 PM   #4879
snobrdrkid07
Yeah its mostly fixed now. What's left is a strong feeling that the little remaining vibes are the road and the worn tire that's still in the front.
-Michael-
Unread 07-25-2012, 03:16 PM   #4880
snobrdrkid07
Gonna rotate that one tire and stuff later today. I tried to tighten the track bar bolt by hand again. Set wrench to 90 and I couldn't get it to even click. Can't get enough leverage. Gonna take an impact gun to it, is that an ill-advised move? I'm trying to get it tight enough to where the sleeve won't move around.
-Michael-
Unread 07-25-2012, 04:23 PM   #4881
99WJdan
I used my impact on the track bar, on the highest setting.
Unread 07-25-2012, 04:34 PM   #4882
snobrdrkid07
LOLOLOL. I just hit mine with an impact gun turned up pretty dang high and hit it 3 times. So it should be pretty tight. Test drive later. Also my front tires were at 37 PSI!? So I dropped them down to 33 PSI.
-Michael-
Unread 07-25-2012, 04:39 PM   #4883
AgitatedPancake
tighten your track bar bolts till you think you're going to break them. If you do break them, replace with grade 8 and repeat
To contact me, email Greg@Frobotfab.com
Frobot Fabrication Facebook
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread: http://www.mallcrawlin.com/forum//showthread.php?t=7387
AgitatedPancake's Youtube Channel
AgitatedPancake is offline   Reply With Quote Quick reply to this message
Unread 07-25-2012, 04:43 PM   #4884
snobrdrkid07
Hey AP thanks for posting. I hit it pretty good so ill see what happens when I drive it later. Can you correct me if I'm wrong here. The sleeve in the JKS bar is supposed to be held in place against the frame mounts and clamped down via the tightness of the track bar bolt? Also, do you know what grade the factory track bar bolt is?
-Michael-
Unread 07-25-2012, 05:09 PM   #4885
99WJdan
I did that a few months ago and they eventually work their way loose. The previous owner had my tires inflated to 44psi i keep my treadwrights at 37psi.
Unread 07-25-2012, 05:12 PM   #4886
snobrdrkid07
I freaking hate track bars and their bolts. Ill keep mine at 33, its only a 29.5 inch tire.
-Michael-
Unread 07-25-2012, 06:02 PM   #4887
snobrdrkid07
Jeez, its so hard not to give up on this jeep. Even with the track bar tighter. I'm still getting a 'pop' sound when moving and turning then when I turn the other way while driving it'll do that pop again. Not loud but noticeable and I can feel it a little bit. I don't know what it is. I had a wobble feeling that was set off by a bump and didn't stop. It wasn't full out dw but it took 5 seconds for it to go away. I'm just so close to going back to stock. I just do not know what else to do.
-Michael-
Unread 07-25-2012, 07:29 PM   #4888
snobrdrkid07
Well latest update is that lowering the pressure to about 33 PSI and tightening the TB bolt with an impact gun has brought about the beginning of DW. It is shimmying like it wants to go to DW at 50 mph. I am so lost here in what to do. Ive done almost everything.
-Michael-
Unread 07-25-2012, 08:11 PM   #4889
Thomahawk
Thomahawk's Avatar
You got the lift on. I did not Even knew, seems like you had a great amount of work and progress to your project lately, thumbsup.
Buildthread http://www.jeepforum.com/forum/f197/...grade-1813490/
Thomahawk is offline   Reply With Quote Quick reply to this message
Unread 07-25-2012, 08:13 PM   #4890
snobrdrkid07
Yeah man. Alot of progress. I'm trying to track down death wobble now. Kinda making me want to go back to stock. Lol.
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
