Snobrdrkid's WJ Build Thread - Page 325 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire
Unread 07-24-2012, 03:26 PM   #4861
99WJdan
A chain store like that shouldn't have a problem re-balancing them for you. Isn't this like your second time going back to them?
99' WJ 4.7, 3.5" lift, Bilsteins, JKS goodies, 32" Guard Dogs on 16x7 4" BS Soft 8s
Build- http://www.jeepforum.com/forum/f197/99wjdans-build-thread-1304554/
99WJdan is offline   Reply With Quote Quick reply to this message
Unread 07-24-2012, 03:41 PM   #4862
alwaysHI
2003 WJ
Originally Posted by snobrdrkid07
were a good store until the manager changed. Then quality and customer satisfaction went out out door with the previous manager....
Reminds me of work..
Bronson = 21 yrs. old
BUILT, NOT BOUGHT - WORKED HARD FOR, NOT KISSED MOMMY/DADDYS A** FOR!
Build Thread - http://www.jeepforum.com/forum/f197/alwayshi-build-thread-1256466/ - SOLD
alwaysHI is offline   Reply With Quote Quick reply to this message
Unread 07-24-2012, 03:44 PM   #4863
snobrdrkid07
snobrdrkid07's Avatar
I'm gonna go back and get my way with their shotty work. I'm just wondering if I need to go to ANOTHER shop for them to do it "right"
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 07-24-2012, 03:45 PM   #4864
snobrdrkid07
I couldnt work for an *** of a manager. Or would have a hard time doing so.
-Michael-
Unread 07-24-2012, 03:51 PM   #4865
alwaysHI
2003 WJ
Gotta do what you gotta do
Unread 07-24-2012, 03:53 PM   #4866
snobrdrkid07
Oh I know it. I'm sure ill have to deal with a bad boss at least once in my working times. In this case I'm not sure if the new manager doesn't care about quality or is a push over to employees there. Either way, its not that great.
-Michael-
Unread 07-24-2012, 05:02 PM   #4867
snobrdrkid07
On another note. The JKS bar sounds like its clunking. Need to check the jam nut. When I pull in the driveway the sound is simultaneous with the steering wheel bump. I'm betting the sleeve is bumping into the bolt because its not tight enough. Haha
-Michael-
Unread 07-24-2012, 06:32 PM   #4868
compcrasher86
I don't think loose jam nut would cause a lot of clunking the threads shouldn't have any play in them really. Never heard of Merchant tire but the local NTB up here has a very lazy reputation. My buddy works for them and he says he is often rushed when doing oil changes because they pay him flat rate per oil change and he gets yelled at when he takes too long. IMO if someone else changed my oil, which I wouldn't really let happen to begin with, they can take their sweet time and do it right. Agh gettin sidetracked. Wheels often don't balance out if at all without weights so check out another reputable shop in the area. I brought my tire to Firestone when I needed a valve stem replaced and they did a great job and rebalanced the tire perfectly. I've never felt a single imbalance related vibe or wobble. Again, it all depends on local management, tires, tire wear, etc I guess.
Matt
compcrasher86 is offline   Reply With Quote Quick reply to this message
Unread 07-24-2012, 06:38 PM   #4869
snobrdrkid07
Jam nut is tight. Gotta be the end bolts. Again probably the frame side. JKS bar.... why you cause me so much hassle! Makes me want to get a new factory bar. Going to get the big ol torque wrench out tomorrow again. Maybe an impact gun.
I am going to go in the morning tomorrow and causally ask why my just balanced tire has no weight on it. Then go from there is you know what I mean. I will either have them rebalance if they don't give me my money back and if they do. Ill go somewhere else. I mean how freaking hard can it be to balance a 30 inch tire. You put it on a machine and it tells you exactly where to put a weight.
-Michael-
Unread 07-24-2012, 09:08 PM   #4870
Larryftmfw
New steering box is in! Steering is billion times better!!! The steering wheel doesn't roll from side to side over bumps! Still binding when turning it left tho : / idk what's causing that
Sent from my iPhone using JeepForum because I can!
Larryftmfw is offline   Reply With Quote Quick reply to this message
Unread 07-24-2012, 09:32 PM   #4871
snobrdrkid07
That's great man. Its much tighter now from what it sounds like?
-Michael-
Unread 07-24-2012, 09:36 PM   #4872
Larryftmfw
Just how I like it ; ), still need new 3 new tie rod ends and a ss! Maybe that will fix my binding when turning the wheel left when not moving?
Unread 07-24-2012, 09:49 PM   #4873
snobrdrkid07
Binding would be in the gear box. Possible air in the line?
-Michael-
Unread 07-24-2012, 10:07 PM   #4874
Larryftmfw
That's impossible
Unread 07-24-2012, 10:29 PM   #4875
snobrdrkid07
I don't know! I am just thinking of things!?!
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
