Snobrdrkid's WJ Build Thread - Page 324 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
WIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,
Unread 07-23-2012, 02:33 PM   #4846
snobrdrkid07
snobrdrkid07's Avatar
There really was not an grease in it. Guess there was supposed to be grease in there. The CV Boot is also a little cracked up too.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 07-23-2012, 03:04 PM   #4847
Larryftmfw
Yea there is, replace the cv boot too!
Sent from my iPhone using JeepForum because I can!
Larryftmfw is offline   Reply With Quote Quick reply to this message
Unread 07-23-2012, 03:05 PM   #4848
snobrdrkid07
I wanna get a whole new d.s. with the double cardon at the t-case
-Michael-
Unread 07-23-2012, 03:09 PM   #4849
Larryftmfw
You won't regret it
Unread 07-23-2012, 03:10 PM   #4850
snobrdrkid07
Yeah I plan on putting ZERO dollars into my old d.s.
-Michael-
Unread 07-23-2012, 08:46 PM   #4851
snobrdrkid07
Still seem to have the vibes with the drive shaft gone. Its slight but there.
1. Rotate tires
2. Check lug nuts.
3. Have the shop to rebalance (apparently that shop isn't to great on quality) either road force balance and if that shop doesn't have it. I want my money back.
4. Check TB bolts. (Should be fine)
5. KOR bushings?
6. ?????? (Rage)
7. Sell Jeep.
-Michael-
Unread 07-24-2012, 11:15 AM   #4852
snobrdrkid07
Noticed today that a front tire doesn't have any wheel weights on it. Hmmm, seeing how they said they were all out of balance and that I'm doubting its perfectly balanced without any weight.
-Michael-
Unread 07-24-2012, 11:19 AM   #4853
billzcat1
Chicken in a Turkey Suit
2003 WJ
Unlikely. Find a new shop. If they use stick-on weights in the wheel barrel, cover them with duct tape. Unless the barrel is really clean, stick on weights like to fall off. Request clamp-on weights on the inner face. Outer face is ugly, damages the lip, and gets scraped off too easily on curbs or on the trail.
billzcat1 is offline   Reply With Quote Quick reply to this message
Unread 07-24-2012, 11:25 AM   #4854
snobrdrkid07
So ideally, have them put the wheel weights on the inner rim lip? I am going to call some friends with a off road shop that has a balancer and see if I can't get down there and balance them. Wheel out of balance still seems the most likely culprit for these 45-50+ mph vibes and highway vibes. Would you agree? I'm not to happy about the job that they did. Now it is making me question the alignment that they did...
EDIT: Went out to double check if there was weights on the inside rim lip. Driver side front: NO Weights on the the outside lip and NONE on the inside lip, nor any weight on the inside rim that I could see. Front Passenger side tire has no weight on the the outside but has a fairly large weight on the inside rim lip.
-Michael-
Unread 07-24-2012, 11:41 AM   #4855
billzcat1
2003 WJ
Yeah, except here's the thing... you can't fully balance a wheel on the inner lip. You have to have counter weights (stick ons) in the barrel. You can, however, get extremely close. Mine are balanced on inner lip only and I can't discern any vibes up to 80mph.
The good news is that Jeep alignment is even more simple than wheel balancing. You can do it with a tape measure. All that you can adjust is front toe. Set it 1/8" toe in and you are done.
Just find a new shop. 29" tires shouldn't be difficult to balance out. If you had 35s, maybe it might be difficult for SOME shops, in which case I'd recommend airsoft balancing (where you add a few ounces of airsoft pellets into the tire to auto-balance it). But for anything short of that you should have NO issue with wheel balance. Where did you take it before? Chain store?
Unread 07-24-2012, 11:44 AM   #4856
snobrdrkid07
Id like to get it as close as they can. Because I drive 80 mph on the highway and an out of balance tire is really annoying. What should I request the next shop to do? I have the alignment specs posted a few pages back. Everything looked to be in spec minus caster.
I took it to Merchants to have the wheels balanced. I should have listened to my friend when he said to stay away.
Also, I do believe these vibes increase with speed. The frequency of them.
-Michael-
Unread 07-24-2012, 02:47 PM   #4857
99WJdan
Just curious what shop did you go to? A chain store maybe? They guy who balanced my Treadwrights statically put all the weights on the inside of the rim, none on the outside, and I have no vibrations at highway speeds.
99' WJ 4.7, 3.5" lift, Bilsteins, JKS goodies, 32" Guard Dogs on 16x7 4" BS Soft 8s
Build- http://www.jeepforum.com/forum/f197/99wjdans-build-thread-1304554/
99WJdan is offline   Reply With Quote Quick reply to this message
Unread 07-24-2012, 02:50 PM   #4858
snobrdrkid07
Merchants Tire did the "balancing". My friend had told me that they were a good store until the manager changed. Then quality and customer satisfaction went out out door with the previous manager....
-Michael-
Unread 07-24-2012, 03:14 PM   #4859
99WJdan
Thats funny, merchants tire is also know as national tire battery (NBT). Thats where I got my Jeep aligned at and they did a great job.
Unread 07-24-2012, 03:16 PM   #4860
snobrdrkid07
Must have been like what my friend said. New manager ruined it. :/
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
