Snobrdrkid's WJ Build Thread - Page 323 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
Free shipping on slip yoke eliminator kits New lower PriceNew! JK/U skid plate system.FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome Effect
Unread 07-22-2012, 03:49 PM   #4831
Larryftmfw
Originally Posted by snobrdrkid07
That's insane and sucks.
I agree
Sent from my iPhone using JeepForum because I can!
Larryftmfw is offline   Reply With Quote Quick reply to this message
Unread 07-22-2012, 04:56 PM   #4832
wj4play
Originally Posted by snobrdrkid07 View Post
I also want to cut off that dam on the green line. Now that is questionable for water intake issues. I ended up NOT doing this
I chopped this off years ago and have never had an issue..
wj4play is offline   Reply With Quote Quick reply to this message
Unread 07-22-2012, 05:03 PM   #4833
snobrdrkid07
Mr. WJ
snobrdrkid07's Avatar
Oh no kidding? Did you also do the air box mod?
~ 04 WJ 4.0 | Selec-Trac 242 | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Custom Front D.S. | Stillen Rotors/Metal Matrix Pads | Tow Package w/ 3.73's | Projectors w/ 55w HID H1 5000K Lows | Sylvania Ultra 9005 Fogs | Moog HD Steering | Kenwood eXcelon Radio | Memphis Speakers | Alpine Amps | Alpine Subs | Moog STB SS | Superchips Flashpaq | Auxiliary Transmission Cooler | Rock Lights | Light Bars ~
~ Snobrdrkid's "Build" Thread ~ YouTube Channel ~ Fuelly ~WJ 4.0 Transmission Cooler Info ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | 2" Spacer Lift | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
For Sale:
Front XJ/TJ 2" Budget Boost. PM for details.
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 07-22-2012, 05:04 PM   #4834
wj4play
The lower control arm bushings not wide enough for the WJ LCA mount?
misalignment bushings,, and also IRO uses the same adjustable control arm for front/rear. normal stock use is fine but what I just found out is that when you move your rear axle back 2-3+ inches they are adjusted to far out (even tho they say they have 6+ inches of adjustment). If I would do it again (and I might anyway) I would go with IRONMan adj lowers with the bend and tell him to make then a few inches longer. and IRO adjustable rear -arm..
I can post a few pics if you want.
Edit:
No I did not do the other mod as you did.... but i might just do it now
4.5in up front/5.5in in rear on short arms
Adjusted to rear stock length
Adjusted all the way out
The reason I am moving the axle back so far is for my 37's
Front test fit
Unread 07-22-2012, 06:03 PM   #4835
snobrdrkid07
Mr. WJ
I'd like to see the pictures of the IRO arms. I'm only at 3 inches of lift so the axle wouldn't have to be pushed all that far. Control arms are probably in the fairly distant future. But that'd be another vote for the iron man control arms. Posting pictures is always good.
The air box mod was easy and probably helps haha. I'm not sure if ill cut that tube part out.
-Michael-
For Sale:
Unread 07-22-2012, 06:19 PM   #4836
wj4play
updated previous post with pics
Unread 07-22-2012, 06:52 PM   #4837
snobrdrkid07
Mr. WJ
Yeah you got a lot of lift and had to push the axle wayyyy back. I guess that's why the started to max out. Thank you for the pictures man.
-Michael-
For Sale:
Unread 07-22-2012, 09:32 PM   #4838
snobrdrkid07
Mr. WJ
Okay guys, another Jeep buddy needs some help.
Specs/Details:
-1994 YJ
-2.5 Liter 4 Cyl
-Was running fine last year (about 10 months ago)
-Did not run for that entire time
-Jump started it and then started up with out much issue.
-Will rev up with out an issue, BUT the issue is ---> under load it will fall on its face and stall out.
-Has fresh gas
-He had put Iridium spark plugs in it. (I had told him that copper plugs would be best, though)
I have told him to check:
-Fuel Filter
-Fuel Pressure
-Run some cleaner through it.
Anything else you guys can think of or suggest?
-Michael-
For Sale:
Unread 07-23-2012, 09:09 AM   #4839
snobrdrkid07
Mr. WJ
Here is the front drive shaft. Those pieces fell off immediately when I took the straps off the front. No beating or hammering at it. Just unbolted and it fell. The rzeppa joint is basically maxed out. When it is on a lift and the axle droops, it goes into ultra death mode. I will have the front drive shaft out for while so more pics can be taken if needed. I have class and then I will do some highway speed test driving later this afternoon.
-Michael-
For Sale:
Unread 07-23-2012, 10:00 AM   #4840
Cowboyup94
Specs/Details:
-1994 YJ
-2.5 Liter 4 Cyl
-Has fresh gas
-Fuel Filter
-Fuel Pressure
I would take that over to the YJ thread. We could guess all we want but really those guys would be able to help faster. I would definetly check the fuel pressure.
JEEP
Just Emptying Every Pocket
Cowboyup94 is offline   Reply With Quote Quick reply to this message
Unread 07-23-2012, 10:09 AM   #4841
Larryftmfw
Damn dude your u joint was in bad condition
Unread 07-23-2012, 10:52 AM   #4842
Cowboyup94
With that bad U joint were you getting vibes at all? I know when mine went 60+ was not possible.
JEEP
Unread 07-23-2012, 11:28 AM   #4843
99WJdan
Time to call Carolina Driveshaft
99' WJ 4.7, 3.5" lift, Bilsteins, JKS goodies, 32" Guard Dogs on 16x7 4" BS Soft 8s
Build- http://www.jeepforum.com/forum/f197/99wjdans-build-thread-1304554/
99WJdan is offline   Reply With Quote Quick reply to this message
Unread 07-23-2012, 12:56 PM   #4844
snobrdrkid07
Mr. WJ
1. What happened to that u-joint?
2. Can I just put that back in there?
3. I do not know 100% if that was causing the vibes yet. I was only able to get to about 50 mph today. I think that the vibes are actually still there. It may be a wheel still out of balance. *mad*
4. Still can not confirm 100% on vibes because I have not been on the highway.
-Michael-
For Sale:
Unread 07-23-2012, 01:31 PM   #4845
Larryftmfw
I'm sure that bad seal did it in, see how it was cracked? Probably had no grease in it did it?
ome hd , OME lift kit , snobrdrkid , wj
