Snobrdrkid's WJ Build Thread - Page 322 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! USA Standard Chromoly Front Axle Shaft Kits with Dana 30 4The Jeep Forum Discount is ON!
Unread 07-20-2012, 01:03 PM   #4816
ChrisHager
ChrisHager's Avatar
I'm not sure what tool he's talking about honestly... Unless it's a pump to suck out the old fluid.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
Originally Posted by alfaitalia View Post
"Wind them in until you strip the thread....then back a quarter turn!"
ChrisHager is online now   Reply With Quote Quick reply to this message
Unread 07-20-2012, 02:40 PM   #4817
Larryftmfw
Damn that new gear box is heavy!!!! How am I supposed to tell of its centered?
Sent from my iPhone using JeepForum because I can!
Larryftmfw is offline   Reply With Quote Quick reply to this message
Unread 07-20-2012, 03:14 PM   #4818
snobrdrkid07
Mr. WJ
snobrdrkid07's Avatar
Same, not sure what tool he was talking about.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 07-20-2012, 03:17 PM   #4819
snobrdrkid07
Mr. WJ
Wheel spin. Yes, finally.
Also got my blackstone oil sample kit.
-Michael-
Unread 07-21-2012, 06:36 AM   #4820
Larryftmfw
How hard are ball joints to replace?
Unread 07-21-2012, 08:02 AM   #4821
snobrdrkid07
Mr. WJ
Larry: Here are some video on a ball joint replacement on a dana 30 on a XJ. Should be about the same. It took him 5 hours to do it apparently.
video 1 -
part 2 -
Billz - What was that tool you were talking about for the power steering fluid?
-Michael-
Unread 07-21-2012, 11:20 AM   #4822
snobrdrkid07
Mr. WJ
Axle is off center by about 1/4 to 1/8 of an inch? Not worth messing with?
Also I was wondering this about the HVAC system. Obviously we all know that the WJ's have ATZ and Manual Climate. But, what I was wondering if it'd be possible just to swap the auto climate knows into my jeep and nothing else. However I was told that that the blend doors are electric and the manual doors are vacuum controlled. So I'm guessing it wouldn't work...
-Michael-
Unread 07-22-2012, 11:22 AM   #4823
Larryftmfw
Omg this steering box replacement is kicking my a$$
Unread 07-22-2012, 01:49 PM   #4824
snobrdrkid07
Mr. WJ
That sucks ^ Any updates?
So I took another highway trip and I am still getting some vibes, but these are different then before. I can feel these vibes all through the Jeep and the steering wheel. It is not moving the steering wheel left and right like DW or shimmy would. But the entire steering wheel vibrates up and down. When I let go you can see it move, when I have my hands on it does not appear to move/vibrate but can still feel it. It is a constant vibe from like 55+ mph on. To me that sounds like a wheel out of balance still or my d.s. going to blow? Again, this is NOT a left/right shimmy. Whatever is going on is causing vibes throughout the Jeep and making the steering wheel move up and down. Its not life and death, just obnoxious and I am trying to figure out what is causing it.
-Michael-
Unread 07-22-2012, 01:57 PM   #4825
billzcat1
Chicken in a Turkey Suit
2003 WJ
Sounds like wheel balance to me.
billzcat1 is offline   Reply With Quote Quick reply to this message
Unread 07-22-2012, 02:00 PM   #4826
snobrdrkid07
Mr. WJ
If it is a wheel that is off balance, STILL, that is going to piss me off. I just had them balanced, or they are "supposedly" balanced. *shakes head in disappointment* I am also going to try and pull off my front drive shaft FIRST and see what happens. Then if that does not do it, I will go get the tires "road-force" balanced.
-Michael-
Unread 07-22-2012, 02:52 PM   #4827
Larryftmfw
Update is a new pitman arm is being overnighted to me and I'm just going to turn the core in with the old one on it
Unread 07-22-2012, 03:17 PM   #4828
snobrdrkid07
Mr. WJ
That makes life easier haha. So you couldnt get the pitman arm off to save you're life? Haha
Took a shot of my front d.s. angle. Boot seems to be okay. No grease splatter.
-Michael-
Unread 07-22-2012, 03:41 PM   #4829
Larryftmfw
I sure couldn't, the impact gun wouldn't budge it
Unread 07-22-2012, 03:43 PM   #4830
snobrdrkid07
Mr. WJ
That's insane and sucks.
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
