Snobrdrkid's WJ Build Thread - Page 319 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
Iron Rock Offroad products - get them from Kolak!WIN a Rough Country Forged Track Bar - ExtremeTerrain!FS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 07-17-2012, 01:52 PM   #4771
snobrdrkid07
snobrdrkid07's Avatar
Got the one side. A little tap with a hammer and a socket got the sleeve out.
Everything looks okay. I got some grease. Will that grease work? So just grease anywhere the poly bushing touches metal?
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is online now   Reply With Quote Quick reply to this message
Unread 07-17-2012, 01:53 PM   #4772
billzcat1
Chicken in a Turkey Suit
2003 WJ
Just grease where the sleeve goes and the faces of the poly bushings. Not the face where the bushing slides into the bar.
billzcat1 is offline   Reply With Quote Quick reply to this message
Unread 07-17-2012, 01:56 PM   #4773
snobrdrkid07
So only where the red bushing touches the sleeve. Just to x2 check. I really want to start doing things right the 1st time, or at least by the 2nd time in this case Keep learning every day.
-Michael-
Unread 07-17-2012, 01:57 PM   #4774
billzcat1
2003 WJ
And the faces where the red bushing rubs on the body/axle mounts.
Unread 07-17-2012, 02:00 PM   #4775
snobrdrkid07
Greased the inside part where the sleeve goes.
Can I add some grease to the outside face to where it hits against the TB mounts to keep dirt out and squeaks gone?
-Michael-
Unread 07-17-2012, 02:03 PM   #4776
snobrdrkid07
I must have been posting pics as you replied. Thank you Richard.
-Michael-
Unread 07-17-2012, 02:29 PM   #4777
snobrdrkid07
Track bar successfully greased and torqued back down. Will check the torque again in like 20 or 30 miles.
Edit: heyyy, look at that. Greasing the track bar bushings got rid of the squeaks and clunks. Yay.
-Michael-
Unread 07-18-2012, 08:52 AM   #4778
snobrdrkid07
Since I have the suspension at about 98% complete, I figured I'd start another cheap mod for something to do. I am good at those
I am gonna steal this off WDYDTYWJT thread. I had the idea when I saw an H.O. air box and then sure enough it popped up the next day on that thread. Id like to basically do what this guy did and cut that tube out to make it look like the H.O. Box. Then I can also 1, get the mud out of it, and 2 put my new WIX Paper filter in!
-Michael-
Unread 07-18-2012, 11:34 AM   #4779
billzcat1
2003 WJ
I would just cut it straight, and cut it a little further back than the deepest part of that ellipse.
Unread 07-18-2012, 12:03 PM   #4780
snobrdrkid07
I just got back home from bring the trailer back from storage and put some blowers on the Jeep to try to cool it down a little faster so I can start this. I drew two different options in blue, I think you are saying something like option 2.
*I had my torque app hooked up today to keep an eye on temps, coolant never went over 210* in stop and go traffic with the trailer and its about 105 here today. Air intake temp was another story, peaked at about 155* when stopped. Wish I had a temp gauge on the trans, curious to see what it is running at.
-Michael-
Unread 07-18-2012, 12:25 PM   #4781
billzcat1
2003 WJ
Nope, just option 1. Not all the way to the box edge but close. Fancy shapes don't work unless you shape it as a venturi which isn't really possible.
Unread 07-18-2012, 12:50 PM   #4782
snobrdrkid07
Okay cool. I am going to get my hot knife out and see if that'll do it. (Because I can use that inside. Haha)
Little dirty...
-Michael-
Unread 07-18-2012, 01:21 PM   #4783
snobrdrkid07
I also want to cut off that dam on the green line. Now that is questionable for water intake issues. I ended up NOT doing this
-Michael-
Unread 07-18-2012, 03:07 PM   #4784
snobrdrkid07
Final mod. Cleaned it up. Smoothed out the edges. The cutting tool for the soldering iron worked great (200 watt iron). So that's why I cut it like I did.
-Michael-
Unread 07-18-2012, 03:55 PM   #4785
ChrisHager
ChrisHager's Avatar
Why are you cutting it like that? Better air flow? I must have missed something earlier.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
His: 2009 Expedition
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is online now   Reply With Quote Quick reply to this message
ome hd , OME lift kit , snobrdrkid , wj
