Snobrdrkid's WJ Build Thread - Page 315 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
We now have Uniballs!The Original 3/8" Ruffstuff Diff Cover!Introducing MONSTALINERô UV Permanent DIY Roll On Bed Line
Unread 07-13-2012, 01:20 PM   #4711
snobrdrkid07
Mr. WJ
snobrdrkid07's Avatar
Dusk - how much torque did you put on it??
They did have to put new weights on the front tires, so I guess they were not perfectly balanced... that may be a good sign.
~ 04 WJ 4.0 | Selec-Trac 242 | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Custom Front D.S. | Stillen Rotors/Metal Matrix Pads | Tow Package w/ 3.73's | Projectors w/ 55w HID H1 5000K Lows | Sylvania Ultra 9005 Fogs | Moog HD Steering | Kenwood eXcelon Radio | Memphis Speakers | Alpine Amps | Alpine Subs | Moog STB SS | Superchips Flashpaq | Auxiliary Transmission Cooler | Rock Lights | Light Bars ~
~ Snobrdrkid's "Build" Thread ~ YouTube Channel ~ Fuelly ~WJ 4.0 Transmission Cooler Info ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | 2" Spacer Lift | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
For Sale:
Front XJ/TJ 2" Budget Boost. PM for details.
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 07-13-2012, 01:22 PM   #4712
Dusk53
just put it down at like 90-100 ft pounds (it was so long ago i don't even remember exactly) should take a lot of the extra play out. Those KOR bushings are a bit too pricey to just jump on immediately (however - i plan on getting some eventually down the road)
And yeah, the balance should help a bit, but when my tires were out of balance i'd notice the vibrations/jumping all the time according to speed, not just random DW. however i suppose it varies vehicle to vehicle and how bad off it is.
http://www.jeepforum.com/forum/f197/dusks-wj-build-1272851/ - Mah build
East Carolina University
Dusk53 is offline   Reply With Quote Quick reply to this message
Unread 07-13-2012, 01:29 PM   #4713
snobrdrkid07
Mr. WJ
Yeah ill give that a shot and just put a little bit more on it. I was not getting death wobble on bumps or anything like that. What my issue is or maybe was, was that it had a constant vibration/shimmy at 50 ish MPH.
-Michael-
For Sale:
Unread 07-13-2012, 01:34 PM   #4714
Dusk53
Yeah, that sounds like wheels being out of balance for sure
Unread 07-13-2012, 01:36 PM   #4715
snobrdrkid07
Mr. WJ
Seeing how it was constant thing. That's when people were saying. Go get your wheels balanced and get the alignment checked. Haha
-Michael-
For Sale:
Unread 07-13-2012, 01:37 PM   #4716
snobrdrkid07
Mr. WJ
Mmmmm droop for your viewing pleasure. Surprised my drive shaft didn't pop out
-Michael-
For Sale:
Unread 07-13-2012, 01:46 PM   #4717
Dusk53
looks good. you should get the stick on weights as opposed to the ones that go on the lip, just a thought.
Unread 07-13-2012, 01:48 PM   #4718
snobrdrkid07
Mr. WJ
They put them on the rim lip. If I had known an hour ago. Lol.
-Michael-
For Sale:
Unread 07-13-2012, 02:13 PM   #4719
snobrdrkid07
Mr. WJ
Well guys. Tell me if this is a problem. My toe was WAY off, camber was off. All for wheels were 9 ounces outta balance. -___-
Edit and the front tires were starting to wear wrong.
-Michael-
For Sale:
Unread 07-13-2012, 02:26 PM   #4720
Larryftmfw
Holy crap
Sent from my iPhone using JeepForum because I can!
Larryftmfw is offline   Reply With Quote Quick reply to this message
Unread 07-13-2012, 04:23 PM   #4721
snobrdrkid07
Mr. WJ
Yeah no kidding. Its definitely better. I just think now the track bar bolt needs to be a little tighter. Still have a little bit of vibes. But its better. I'm gonna blame that on the track bar. Steering wheel needs re-centered again haha.
I have the before and after alignment specs that ill post later tonight.
-Michael-
For Sale:
Unread 07-13-2012, 05:02 PM   #4722
compcrasher86
looks like your buddy over at the dealership did a great allignment job
Matt
compcrasher86 is offline   Reply With Quote Quick reply to this message
Unread 07-13-2012, 05:04 PM   #4723
mreed21
Haha. Thats why i do almost all of my work on my jeep my self.
mreed21 is offline   Reply With Quote Quick reply to this message
Unread 07-13-2012, 05:08 PM   #4724
Larryftmfw
+1 to that!
Unread 07-13-2012, 06:32 PM   #4725
99WJdan
Im glad things worked out for you. Gives me hope that these new tires and alignment will make my WJ drive 100% better.
99' WJ 4.7, 3.5" lift, Bilsteins, JKS goodies, 32" Guard Dogs on 16x7 4" BS Soft 8s
Build- http://www.jeepforum.com/forum/f197/99wjdans-build-thread-1304554/
99WJdan is offline   Reply With Quote Quick reply to this message
ome hd , OME lift kit , snobrdrkid , wj
