Snobrdrkid's WJ Build Thread - Page 314 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
KrawlOff-Road.com Sale EventFS: Jeep Fog Light LED Bulbs! Several Brightness Options! *STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light Ba
Unread 07-13-2012, 09:16 AM   #4696
snobrdrkid07
snobrdrkid07's Avatar
If the bolt was moving around that'd mean the hole was loose? Because the bolt looks nice and tight.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 07-13-2012, 09:52 AM   #4697
snobrdrkid07
JKS Track Bar Videos
Okay Guys. Here we go. Tell me what you all think. Give the videos some more time to process if they do not load. They are also shot in 1080 for extra viewing pleasure.
Frame Side First.
Axle Side.
Found a video of Kevin's WJ with his bushings (and what looks like the upgraded bolts)
Some good news is that is that I DID NOT see any indication on the bolts moving around.
I also lowered the front tire pressure from 34 to 32 PSI.
Edit: I got an appointment for an alignment "check" that includes a printout of the specs. Which ill post. Then I am getting all 4 tires re-balanced for 40 bucks.
WOW Kevin Sucks on shipping...
-Michael-
Unread 07-13-2012, 10:04 AM   #4698
ChrisHager
ChrisHager's Avatar
Looks like your bolts are good. That's quite a bit of movement on the frame side bushing though...
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
His: 2009 Expedition
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline   Reply With Quote Quick reply to this message
Unread 07-13-2012, 10:07 AM   #4699
snobrdrkid07
Sigghhhh of relief on the bolts. Now I thought that as well with the frame side. Think I should just go ahead and get the KOR Bushings?
-Michael-
Unread 07-13-2012, 10:35 AM   #4700
ChrisHager
ChrisHager's Avatar
It wouldn't hurt... If the rest of the steering is in good shape and you have a shimmy, that bushing might be causing it.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 07-13-2012, 10:40 AM   #4701
snobrdrkid07
I have also been emailing the JKS tech and I've also sent them the videos that I posted and am waiting to here what they say as well.
Did I make it clear that the shimmy/little death wobble feeling at 50 Ish is constant? Not just when I hit a bump?
I'm getting an alignment check and tires re-balanced and see what that does too. That amount of moment is just too much. So I guess ill anti up and get the bushings.
-Michael-
Unread 07-13-2012, 10:49 AM   #4702
ChrisHager
ChrisHager's Avatar
Hmmm. Since it's constant, I'm thinking that's an alignment/balance issue. I'd wait to order the bushings until after you can test out the new changes.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 07-13-2012, 10:51 AM   #4703
snobrdrkid07
Okay will do, I have an time slot at 2 pm to get tires balanced and the alignment check. So I will see what that does. I will also post the alignment specs when I get them. Compcrasher86 also said the same thing because it was a constant thing. Even a tire out of balance can make it feel like it is going to DW?
-Michael-
Unread 07-13-2012, 10:58 AM   #4704
ChrisHager
ChrisHager's Avatar
It'll make the steering wheel/vehicle vibrate...
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 07-13-2012, 10:59 AM   #4705
snobrdrkid07
Yeah, its doing that. So hopefully we can get some resolution today.
-Michael-
Unread 07-13-2012, 01:10 PM   #4706
snobrdrkid07
At Merchants Tire now, they are putting the rear tires on the front, balancing all 4 tires and checking out the alignment. While I am currently waiting JKS responded back to me via email after they looked at the videos.
Here is what they said.
"Michael,
The amount your bushings are flexing is completely normal and acceptable for you trackbar. I have actually owned a WJ for a while and had a small vibration similar to the one you’re describing.
What I had found is that the tires were balanced improperly. The WJ uses the lugnuts to center the tire/wheel on the hub. Most tire and wheel shops you a hubcentric balancing machine (balances off of wheel hub). This throws off the wheel balance and caused me to have a shutter when cornering at higher speeds. I was able to find a ship to do a road force balance (blance off of the lugnut holes). And that cured my issue.
Not saying that is your problem, just know it was for me. I can tell you that your bushings are performing as intended.
JKS"
I was very happy with JKS tech support. They have been very helpful and supportive.
-Michael-
Unread 07-13-2012, 01:24 PM   #4707
Larryftmfw
Good to hear, keep us posted
Sent from my iPhone using JeepForum because I can!
Larryftmfw is offline   Reply With Quote Quick reply to this message
Unread 07-13-2012, 01:29 PM   #4708
snobrdrkid07
Will do man. I may try to just put some more torque on the frame side bolt if need be.
-Michael-
Unread 07-13-2012, 01:39 PM   #4709
Larryftmfw
I doubt that'll do much good
Unread 07-13-2012, 01:41 PM   #4710
Dusk53
Thats what I had to do. I had some movement, just cranked down the bolt a bit more and it took some of the slop out, however its not 100% gone.
http://www.jeepforum.com/forum/f197/dusks-wj-build-1272851/ - Mah build
East Carolina University
Dusk53 is offline   Reply With Quote Quick reply to this message
ome hd , OME lift kit , snobrdrkid , wj
