Snobrdrkid's WJ Build Thread - Page 312 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
Jeep Wrangler Bushwacker Flat Fender Flare Sale at BaselinIntroducing MONSTALINERô UV Permanent DIY Roll On Bed LineIncome tax season is upon us. We got what u need
Unread 07-12-2012, 11:33 AM   #4666
snobrdrkid07
snobrdrkid07's Avatar
Well I'm left with a few options here. I'm still getting those little shaky beginning of DW feeling is the 50 ish MPH range. I was thinking about getting adjustable lower control arms to get a ton more caster.
Or, just going back to my stock springs and shocks. I just can't deal with DW on a vehicle that I have to drive every day and commute 5 hours back and forth with to college. I just am not sure what to do.
I don't know guys. :/
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is online now   Reply With Quote Quick reply to this message
Unread 07-12-2012, 12:35 PM   #4667
Larryftmfw
Have You considered maybe a bent rim is causing it?
Sent from my iPhone using JeepForum because I can!
Larryftmfw is offline   Reply With Quote Quick reply to this message
Unread 07-12-2012, 12:37 PM   #4668
snobrdrkid07
Wouldn't have that been apparent before lifting it?
-Michael-
Unread 07-12-2012, 12:40 PM   #4669
Larryftmfw
Maybe the lift is amplifying it? Or it got damaged during the install?
Unread 07-12-2012, 12:47 PM   #4670
snobrdrkid07
Maybe. I guess its possible. I just don't want to keep driving on it anymore. Afraid that its only going to make things worse.
I've been thinking to going back to stock front springs with 3/4 inch spaces and trade my front bilsteins for ones for a smaller lift. That should put me at 18.75 inches in the front. Then keep my rear OME HD with no spaces and that should give me about 19.75-20.0 inches in the rear. I should be able to keep my rear 5100s I have now, they are made for a 1 to 2 inch lift.
-Michael-
Unread 07-12-2012, 03:19 PM   #4671
Larryftmfw
Finally got the tre off! Took 2 whacks from the fork! Lol and damn my old o2 sensor was black as heck
Unread 07-12-2012, 03:24 PM   #4672
99WJdan
I know the feeling about being afraid to drive your vehicle. Its not a good feeling when you drop a lot of money into something and then find out it may have caused more problems. Before you do anything, try a few things.
Disconnect the front driveshaft. From my own experience, that was a big problem solver for vibrations. Take it off and see if it still vibrates then go from there.
Get your tires balanced. Mosts shops only charge 20-30 bucks. A unbalanced tire makes driving at highway speeds a nightmare.
Check your tires air pressure. My tires leak air a good bit. When they're low, it drives like crap. When they're overfilled, it drives like crap. Don't know about where you live but its been hot here recently, causing air in the tire to expand = higher psi and higher psi causes to death wobble.
99' WJ 4.7, 3.5" lift, Bilsteins, JKS goodies, 32" Guard Dogs on 16x7 4" BS Soft 8s
Build- http://www.jeepforum.com/forum/f197/99wjdans-build-thread-1304554/
99WJdan is offline   Reply With Quote Quick reply to this message
Unread 07-12-2012, 03:33 PM   #4673
ChrisHager
ChrisHager's Avatar
Hahaha! Well I overlooked that but I bet that's why my death wobble 'appeared'. When I replaced my JKS bushings with the KOR bushings, I also rotated my tires. When I did so, I filled them up to 32 lbs for the upcoming long drive (usually I run at 29, or so I thought). Turns out, they were all at 25-26 lbs. I have no recollection of ever purposely filling them to that level. Either way, tire pressure wont CAUSE death wobble but extra air in the tires will help reveal existing DW.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
His: 2009 Expedition
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is online now   Reply With Quote Quick reply to this message
Unread 07-12-2012, 05:34 PM   #4674
snobrdrkid07
Tomorrow I will x2 check tire pressure and pull the front d.s. and see what happens.
If that does nothing, ill have the tires rebalanced and see what happens.
If that does not work.... then maybe ill try the KOR bushings. I KNOW the JKS bar has play in it.
Edit: I run my tires at 34 PSI, too much?
-Michael-
Unread 07-12-2012, 05:35 PM   #4675
alwaysHI
2003 WJ
What have you checked so far? Tre's, ball joints, bushings of the control arms, track bar?
Bronson = 21 yrs. old
BUILT, NOT BOUGHT - WORKED HARD FOR, NOT KISSED MOMMY/DADDYS A** FOR!
Build Thread - http://www.jeepforum.com/forum/f197/alwayshi-build-thread-1256466/ - SOLD
alwaysHI is offline   Reply With Quote Quick reply to this message
Unread 07-12-2012, 05:37 PM   #4676
snobrdrkid07
Tie rods are brand new, ball joints looked good, need to x2 check ball joints. Bushings on control arms looked good. Didn't see any play.
Again track bar has play in the bushings.
-Michael-
Unread 07-12-2012, 05:52 PM   #4677
alwaysHI
2003 WJ
Address your track bar first and double check the ball joints. There is suppose to be no play in the track bar
Unread 07-12-2012, 05:53 PM   #4678
snobrdrkid07
I have no way of fixing it.
-Michael-
Unread 07-12-2012, 06:00 PM   #4679
alwaysHI
2003 WJ
Why do you say that?
Unread 07-12-2012, 06:02 PM   #4680
snobrdrkid07
Either the JKS bushings are just too soft and I guess I can try KOR stuff. Maybe I can try torquing them down more?
Or my bolt holes are wallowed out and Id have to get someone to attempt to fix that. I didn't notice it but who knows.
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
