Snobrdrkid's WJ Build Thread - Page 311 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 07-11-2012, 03:17 PM   #4651
snobrdrkid07
snobrdrkid07's Avatar
Ohhhh, I do not know. What would a yes or no mean?
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is online now   Reply With Quote Quick reply to this message
Unread 07-11-2012, 03:26 PM   #4652
99WJdan
A yes can be multiple things. CV joints, worn tires, suspension components, ect. Thats what mine is doing. As soon as I let off the gas, the shaking in the steering wheel decreases dramatically. I replaced CV joints back in October so I don't think they are going out again (although I do have a click/pop noise when turning/braking sometimes, not sure where that is coming from). Only suspension components that I have not replaced are ball joints. And my tires are extremely worn. Seams like the more worn the tires get, the more it shakes so for me, I'm replacing the tires and getting it aligned to see if that helps.
99' WJ 4.7, 3.5" lift, Bilsteins, JKS goodies, 32" Guard Dogs on 16x7 4" BS Soft 8s
Build- http://www.jeepforum.com/forum/f197/99wjdans-build-thread-1304554/
99WJdan is offline   Reply With Quote Quick reply to this message
Unread 07-11-2012, 03:32 PM   #4653
snobrdrkid07
I'm still wondering if my front drive shaft could be a culprit, didn't think of CV shafts. But the drive shaft would be a more constant vibe. Mine currently seem irregular at times. Not sure of the ball joints, but it wasn't causing an issues before. The tire balance was not an issues before the lift so it should not be an issue after the lift?
-Michael-
Unread 07-11-2012, 03:38 PM   #4654
99WJdan
Do you have the cv-cv type driveshaft? Replaced mine with one from Carolina Driveshaft, double cardan. It helped a good bit with wheel vibrations. Believe it or not, there was actually a time I was driving back to college going 70-75mph with no vibrations or noises.
Unread 07-11-2012, 03:41 PM   #4655
snobrdrkid07
I've got the single u-joint at the axle and a rzeppa trash at the t-case. I did here a significant pop from what sounded like the front d.s. when I was wheeling on the beach.
Bringing this over from Chris's thread that I posted.
This is what I got going for me right now.
- All new tie rods
- new tie rod sleeves
- new track bar and bushings (new track bar didn't seem to get rid of vibes)
- tires were balanced before the lift (no issues)
- JUST got it aligned. And nothing should have messed with toe.
- Ss is still tight
What left is:
- ball joints
- drive shaft
- c.v. joint.
-Michael-
Unread 07-11-2012, 03:44 PM   #4656
99WJdan
You have it easy then without converting the diff to a ujoint flange. Is the boot torn?
Unread 07-11-2012, 03:49 PM   #4657
snobrdrkid07
Yeah. That will help if I have to switch. Pulling the front d.s. will be an easy yes/no on "did that fix the vibes?" But I really don't think that will be it, won't be that easy hah
-Michael-
Unread 07-11-2012, 05:06 PM   #4658
snobrdrkid07
I'm riding in my friends lifted 4runner and its all in check. But the same feeling I'm feeling in my jeep is happening in his 4runner. Making me think that I MIGHT be over thinking this.
Then again I over some bumps its rock solid and others it will give a little wobble still.
-Michael-
Unread 07-11-2012, 07:36 PM   #4659
Larryftmfw
I for the life of me can't get this stupid tre that connects to the pitman arm
Sent from my iPhone using JeepForum because I can!
Larryftmfw is offline   Reply With Quote Quick reply to this message
Unread 07-12-2012, 06:24 AM   #4660
snobrdrkid07
What's wrong?
-Michael-
Unread 07-12-2012, 07:00 AM   #4661
snobrdrkid07
Also, that'd be a no on the vibes going away when letting off the gas and coasting. They are still there. Butter zone seams to be around 50 to about 60. I may just need more caster?
-Michael-
Unread 07-12-2012, 07:38 AM   #4662
Larryftmfw
What's wrong?
It's stuck lol, after 178,000 miles it's no wonder. I also noticed the boots for my other ones are cracked and all..
Unread 07-12-2012, 08:43 AM   #4663
snobrdrkid07
Yeah I guess that will do it. Were you able to get it off?
-Michael-
Unread 07-12-2012, 08:57 AM   #4664
Larryftmfw
Not yet
Unread 07-12-2012, 10:08 AM   #4665
snobrdrkid07
Originally Posted by Larryftmfw
Not yet
Oops. :/
-Michael-
ome hd , OME lift kit , snobrdrkid , wj
