Snobrdrkid's WJ Build Thread - Page 310 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINERô UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 07-11-2012, 10:44 AM   #4636
snobrdrkid07
snobrdrkid07's Avatar
Now that the front is much tighter with the new track bar. The rear feels like total trash (because it is) with the a-arm being toasted. Next priority.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is online now   Reply With Quote Quick reply to this message
Unread 07-11-2012, 11:11 AM   #4637
Larryftmfw
So does mine, it clunk so much it's annoying
Sent from my iPhone using JeepForum because I can!
Larryftmfw is offline   Reply With Quote Quick reply to this message
Unread 07-11-2012, 01:08 PM   #4638
snobrdrkid07
WTH, how often does this jam nut come lose?
-Michael-
Unread 07-11-2012, 01:19 PM   #4639
billzcat1
Chicken in a Turkey Suit
2003 WJ
Not very often. Get it nice and snug.
billzcat1 is offline   Reply With Quote Quick reply to this message
Unread 07-11-2012, 01:25 PM   #4640
snobrdrkid07
Update. Jam nut was tight, should be after I got it veryyy tight last night. Must be a Jeep thing, because now when I turn the wheel back and forth. I still here what I always have a little clunk going back and forth. I don't know what happened to the other sound I was hearing that was out of the ordinary, weird.
-Michael-
Unread 07-11-2012, 01:33 PM   #4641
Larryftmfw
Did the sleeves in the track bar fit the bolts snug? My mount for the track bar on the body side is so messed up, the hole has wallerd out from the loose track bar so I need a shop to weld it
Unread 07-11-2012, 01:38 PM   #4642
snobrdrkid07
Yeah the bolts and bolt holes were all good. I didn't see anything that'd cause concern. No places were it would have been bowed out or anything like that.
-Michael-
Unread 07-11-2012, 01:42 PM   #4643
ChrisHager
ChrisHager's Avatar
I wrote an initial review of the KOR bushings HERE in my build thread. I think the bushings are nice but they are revealing that I have some other issues somewhere. Because the JKS bushings were much softer, I'm guessing they were dampening some shimmy...
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
His: 2009 Expedition
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline   Reply With Quote Quick reply to this message
Unread 07-11-2012, 01:56 PM   #4644
billzcat1
2003 WJ
Check the steering box and intermediate shaft. The intermediate shaft in particular.
Unread 07-11-2012, 02:08 PM   #4645
Larryftmfw
What in particular should he be Checking
Unread 07-11-2012, 02:14 PM   #4646
billzcat1
2003 WJ
For play between components. The intermediate shaft is just two pieces of square tubing, one fit inside the other. With non-serviceable u-joints on both ends - these are all likely culprits when everything else is new.
Unread 07-11-2012, 02:30 PM   #4647
Larryftmfw
How easy are these to replace?
Unread 07-11-2012, 02:55 PM   #4648
Larryftmfw
I started pulling my spark plugs and they don't look bad
Unread 07-11-2012, 03:02 PM   #4649
snobrdrkid07
Billz - I will add the intermediate shaft to the list of things to check over.
The jam nut is tight, I know the tie rods are tight, the only thing left is the track bar bushings have some play in them. Chris had just said that the JKS bushings were absorbing some of a shimmy for his case. Then when Chris put in KOR bushings he had more wheel shimmy. So I will also wait to see what he says for his shimmy.
But for me I wonder what could be causing vibes at 45+ mph. The steering wheel wont move the steering wheel back and forth (maybe a TINY bit) to give you an idea of how little these vibes are, you can just feel them throughout the Jeep. It feels like DW but it won't get to full out DW, again thankfully. I do not know what else to do to track down those vibes. It concerns me because it feels like the vibes are coming from the axle (like they would for DW) and putting tons of stress on the components. etc. I am not sure what to do.
-Michael-
Unread 07-11-2012, 03:16 PM   #4650
99WJdan
Get to a good speed where the vibrations are noticeable then let off the gas. Does the vibrations go away or become less dramatic?
99' WJ 4.7, 3.5" lift, Bilsteins, JKS goodies, 32" Guard Dogs on 16x7 4" BS Soft 8s
Build- http://www.jeepforum.com/forum/f197/99wjdans-build-thread-1304554/
99WJdan is offline   Reply With Quote Quick reply to this message
ome hd , OME lift kit , snobrdrkid , wj
