Snobrdrkid's WJ Build Thread - Page 309 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
ANOTHER Rockridge4wd Creation!! Spare Tire Carrier Delete The Jeep Forum Discount is ON!The Original 3/8" Ruffstuff Diff Cover!
Unread 07-10-2012, 08:43 PM   #4621
Larryftmfw
Originally Posted by snobrdrkid07
U joint looks good on the axle and the C.V. joint is okay. Hasn't blow up yet. Could be tire out of balance, but is also started after the lift...
Maybe your camber is off alittle, how bad are the vibes? From my research it seems with lifts ds vibes are very common when lifting our jeeps
Sent from my iPhone using JeepForum because I can!
Larryftmfw is offline   Reply With Quote Quick reply to this message
Unread 07-10-2012, 08:44 PM   #4622
snobrdrkid07
Mr. WJ
snobrdrkid07's Avatar
Is camber adjustable/fixable? Any more detail? Yeah my style front d.s. doesn't like lift.
~ 04 WJ 4.0 | Selec-Trac 242 | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Custom Front D.S. | Stillen Rotors/Metal Matrix Pads | Tow Package w/ 3.73's | Projectors w/ 55w HID H1 5000K Lows | Sylvania Ultra 9005 Fogs | Moog HD Steering | Kenwood eXcelon Radio | Memphis Speakers | Alpine Amps | Alpine Subs | Moog STB SS | Superchips Flashpaq | Auxiliary Transmission Cooler | Rock Lights | Light Bars ~
~ Snobrdrkid's "Build" Thread ~ YouTube Channel ~ Fuelly ~WJ 4.0 Transmission Cooler Info ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | 2" Spacer Lift | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
For Sale:
Front XJ/TJ 2" Budget Boost. PM for details.
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 07-10-2012, 08:51 PM   #4623
Larryftmfw
With my lift it is, I'm not sure how you would with stock control arms
Unread 07-10-2012, 08:58 PM   #4624
snobrdrkid07
Mr. WJ
Camber is the angle of the tires vertically. I don't know how that is adjustable. Caster is adjustable w/ your lift.
Maybe I need more caster?
-Michael-
For Sale:
Unread 07-10-2012, 09:06 PM   #4625
Larryftmfw
Lol caster is what I meant : P
Unread 07-10-2012, 09:09 PM   #4626
snobrdrkid07
Mr. WJ
Wonder if lack of caster can cause vibes?
-Michael-
For Sale:
Unread 07-10-2012, 09:19 PM   #4627
Larryftmfw
I think so! I know when the alignment shop screwed mine up the vibes were terrible
Unread 07-10-2012, 09:39 PM   #4628
snobrdrkid07
Mr. WJ
Wonder if it was caused by your front drive shaft though? You had said you had/having issues with that.
-Michael-
For Sale:
Unread 07-10-2012, 09:45 PM   #4629
Larryftmfw
Yea my u joints got demolished lol
Unread 07-10-2012, 09:46 PM   #4630
snobrdrkid07
Mr. WJ
Yeah... that can also be an issue. I will start by just driving it and see what happens. I may pull the front d.s. because that is not to hard. If that does not fix, I will then get all the tires rebalanced.
-Michael-
For Sale:
Unread 07-10-2012, 09:48 PM   #4631
Larryftmfw
You can just remove the ds and see if the vibes go away.
Unread 07-10-2012, 09:52 PM   #4632
snobrdrkid07
Mr. WJ
Yup. Ill give it a try haha.
-Michael-
For Sale:
Unread 07-10-2012, 09:56 PM   #4633
Larryftmfw
It the vibes stop you'll know what's wrong.
Unread 07-10-2012, 09:57 PM   #4634
snobrdrkid07
Mr. WJ
Exactly. But don't know how to fix that one other then keep the d.s. out
Edit: you know what. I was also told that my rear a arm being crap and lose can cause vibrations too
-Michael-
For Sale:
Unread 07-10-2012, 09:59 PM   #4635
Larryftmfw
Mine is still out lol I need to put those new u joints in!
ome hd , OME lift kit , snobrdrkid , wj
