Snobrdrkid's WJ Build Thread - Page 308 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
Ruffstuff Axle Simple Swap Kit!Nitro Gear Packages Now Available at Rockridge 4wdJEEP Gear Change Packages From ROCKRIDGE 4WD. We Are DIFF
Unread 07-10-2012, 07:25 PM   #4606
snobrdrkid07
Mr. WJ
snobrdrkid07's Avatar
It fits fine. Got it pretty tuned. 9 threads on the jam nut was right about on the money. Shoot its better then what it was center wise.
Sadly...... there is still a tiny bit of play on the JKS poly bushings when torqued to 80 foot pounds. From the looks, much much less then the stock track bar had play wise. Hitting some bumps it I feel it in the steering wheel and a little shaky but better. Its all better.
I'm going to contact JKS about the poly bushings and see what they say.
~ 04 WJ 4.0 | Selec-Trac 242 | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Custom Front D.S. | Stillen Rotors/Metal Matrix Pads | Tow Package w/ 3.73's | Projectors w/ 55w HID H1 5000K Lows | Sylvania Ultra 9005 Fogs | Moog HD Steering | Kenwood eXcelon Radio | Memphis Speakers | Alpine Amps | Alpine Subs | Moog STB SS | Superchips Flashpaq | Auxiliary Transmission Cooler | Rock Lights | Light Bars ~
~ Snobrdrkid's "Build" Thread ~ YouTube Channel ~ Fuelly ~WJ 4.0 Transmission Cooler Info ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | 2" Spacer Lift | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
For Sale:
Front XJ/TJ 2" Budget Boost. PM for details.
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 07-10-2012, 07:28 PM   #4607
snobrdrkid07
Mr. WJ
I also did a full lock break test. Holy crap. My friend who was in the Jeep with me, who is a big car person too. This is what he said, "holy f****** sh** man I was not expecting that at all!" "That was ridiculous!"
-Michael-
For Sale:
Unread 07-10-2012, 07:59 PM   #4608
99WJdan
Yeah theres a small amount of play in my bushings too. I even cranked them down with a impact.
Whats the full lock brake test?
99' WJ 4.7, 3.5" lift, Bilsteins, JKS goodies, 32" Guard Dogs on 16x7 4" BS Soft 8s
Build- http://www.jeepforum.com/forum/f197/99wjdans-build-thread-1304554/
99WJdan is offline   Reply With Quote Quick reply to this message
Unread 07-10-2012, 08:03 PM   #4609
snobrdrkid07
Mr. WJ
I'm not sure what I am going to do as of now other then contacting JKS.
Rephrase. Slamming the brakes as hard as I can test and see what happens. Like a panic stop. Was able to lock the tires up on rough asphalt. I'm impressed so far. They are still breaking in too.
-Michael-
For Sale:
Unread 07-10-2012, 08:10 PM   #4610
99WJdan
Oh haha. Gotcha. Im interested to see what jks says about the bushings. Mine are not moving a good bit, but just enough to be visible. The play in the bushings and the steering gear box is whats giving me vibrations in the steering wheel I think the only solution is the kor bushings, and from what I heard, they are worth it.
Unread 07-10-2012, 08:12 PM   #4611
Larryftmfw
I can't get my brakes to lock ever, iv tried, maybe your abs isn't 100%? And there will always be some play with the bushings, there alittle soft to absorb the energy created when you hit bumps and all.
Sent from my iPhone using JeepForum because I can!
Larryftmfw is offline   Reply With Quote Quick reply to this message
Unread 07-10-2012, 08:28 PM   #4612
snobrdrkid07
Mr. WJ
Yeah, ill give them a call or email tomorrow and ill post up what they say.
Chris just installed the KOR bushings into his JKS and will give them a workout tomorrow. He will probably post back here and let us know too.
To my knowledge the brakes are supposed to lock up and kick on ABS to prevent lock up.
I thought they were supposed to be TIGHT.
-Michael-
For Sale:
Unread 07-10-2012, 08:34 PM   #4613
Larryftmfw
Tight to a certain extent, get someone to turn the wheel and take a video of the play and post it!
Unread 07-10-2012, 08:52 PM   #4614
snobrdrkid07
Mr. WJ
I should have done a video but I didn't think of it at the time. Ill do that, soon, hopefully.
-Michael-
For Sale:
Unread 07-10-2012, 09:23 PM   #4615
Larryftmfw
Lol get it done! : P tomorrow I get new plugs and than get to put in that tre! I'm excited! I might replace that other upstream 02 sensor! I think once I get my steering fixed it's time for a aftermarket exhaust!
Unread 07-10-2012, 09:30 PM   #4616
snobrdrkid07
Mr. WJ
Hahaha okay okay, ill get a video soon.
It feels really good to get stuff done to the jeep haha.
-Michael-
For Sale:
Unread 07-10-2012, 09:33 PM   #4617
Larryftmfw
Yes it does!
Unread 07-10-2012, 09:38 PM   #4618
snobrdrkid07
Mr. WJ
Yup.
Next is figuring out why I have some slight vibes (still with the new track bar) in the jeep. Not sure if tires, or track bar or what. Possibly front d.s.?
-Michael-
For Sale:
Unread 07-10-2012, 09:40 PM   #4619
Larryftmfw
Yup.
What's the condition of your u joints? Also maybe your tries need to be re balanced? There's so many possibilities but you've covered a lot with replacing the tre's so that helps
Unread 07-10-2012, 09:42 PM   #4620
snobrdrkid07
Mr. WJ
U joint looks good on the axle and the C.V. joint is okay. Hasn't blow up yet. Could be tire out of balance, but is also started after the lift...
-Michael-
For Sale:
ome hd , OME lift kit , snobrdrkid , wj
