Snobrdrkid's WJ Build Thread - Page 307 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 07-10-2012, 03:07 PM   #4591
Larryftmfw
Talk about heavy duty!!!!
Sent from my iPhone using JeepForum because I can!
Larryftmfw is offline   Reply With Quote Quick reply to this message
Unread 07-10-2012, 03:16 PM   #4592
snobrdrkid07
snobrdrkid07's Avatar
Chris - Yup, sounds good. 9 full threads with the jam nut tight. That should get her pretty dang close. Oh, yeah haha, threads on the axle side thanks for all the help and tips! Ill keep y'all posted tonight. I might take it in for an alignment at some point too.
Larry - oh yeah man, Moog is awesome stuff!
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 07-10-2012, 03:19 PM   #4593
Larryftmfw
I can wait to order all new stuff! My a arm bushings in the rear I think are bad : / crap!!!!!
Unread 07-10-2012, 03:21 PM   #4594
snobrdrkid07
For you since you are lifted sky high. I'd recommend the IRO adjustable a-arm for you. That'd be the best way to go for you.
For me. Since I'm at about 2.5 lift in the rear. I think ill just go with a whole new mopar arm and mopar ball joint all installed for me for 300 bucks. By the time I do the IRO arm for me it'll be near 400 bucks.
-Michael-
Unread 07-10-2012, 03:43 PM   #4595
Larryftmfw
Wow that's expensive! Lol I'll look into the adj one thanks!
Unread 07-10-2012, 03:51 PM   #4596
snobrdrkid07
Yup, it sucks, but the IRO arm is a great arm for lifts. Mopar arm will work for me. It should still be able to handle 2.5 inches of lift.
-Michael-
Unread 07-10-2012, 04:01 PM   #4597
techRob
IRO a-arm is $300 and works for 2.5". why would you waste money on another OEM a-arm only to install the IRO later?
techRob is offline   Reply With Quote Quick reply to this message
Unread 07-10-2012, 04:04 PM   #4598
snobrdrkid07
Because I can get the OEM a arm with a new ball joint installed and done for 300.
It'd cost me 300 + 50 shipping + 50 install for the IRO arm for me.
I'm not sure what ill do yet, if I do install the OEM one, I won't do the IRO one down the road.
-Michael-
Unread 07-10-2012, 04:09 PM   #4599
Larryftmfw
I might just go with bushing for now since I have the a-arm spacer that came with my lift
Unread 07-10-2012, 04:09 PM   #4600
ChrisHager
ChrisHager's Avatar
You could just throw on some rear long arms and skip doing it in stages...
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
His: 2009 Expedition
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline   Reply With Quote Quick reply to this message
Unread 07-10-2012, 04:12 PM   #4601
techRob
why not install it yourself? that's half the fun.
Unread 07-10-2012, 04:17 PM   #4602
snobrdrkid07
Don't get the Omix-Ada bushings. Get mopar bushings.
Going to need some more lift to do long arms. I want to keep it at 2.5 inches for now. Maybe one day do 6.5 inch of 35's and 4.56 gears haha
Way to lazy to do the rear a-arm, that thing is a bit** or at least can be. I don't have the tools for it either. Or a way to get it out if its stuck. Its worth it for 50 bucks man. Haha
-Michael-
Unread 07-10-2012, 05:31 PM   #4603
snobrdrkid07
So what's the deal with the bolt on the frame side? I can't find a metric or standard size socket to fit. Its like rounded off??? Wth
-Michael-
Unread 07-10-2012, 06:08 PM   #4604
snobrdrkid07
Figure it out. Lol. That was a dummy move.
JKS is in and torqued to ~75 ft pounds.
-Michael-
Unread 07-10-2012, 06:27 PM   #4605
Larryftmfw
How's it fit? I would love rear long arms since the kit for it replaces that pos a arm set up! But I don't have the $1,000 lying around lol.
ome hd , OME lift kit , snobrdrkid , wj
