Snobrdrkid's WJ Build Thread - Page 305 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Snobrdrkid's WJ Build Thread
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 07-08-2012, 12:47 PM   #4561
Larryftmfw
Originally Posted by snobrdrkid07
Have you had issues with your JKS? All of this mess about the sh** bushings is why I didnt put it on in the first place. I seriously just want to throw the thing away. I am going to put it on and see what happens. If there is slop, one of two things will happen. Ill get the KOR bushings, or get an IRO track bar.
I liked the jks but sold it to keep my iro trac bar
Sent from my iPhone using JeepForum because I can!
Larryftmfw is offline   Reply With Quote Quick reply to this message
Unread 07-08-2012, 01:09 PM   #4562
snobrdrkid07
snobrdrkid07's Avatar
If the JKS doesnt work. I am going IRO. Not before leaving the JKS company some words of mine.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 07-08-2012, 01:15 PM   #4563
Larryftmfw
I'm not to happy either, I torqued and used lock tight on the hardware for my quick disconnects and after 2 weeks it all fell apart, the clips broke too. It's going to cost me about 40$ to get the new hardware I need
Unread 07-08-2012, 01:16 PM   #4564
snobrdrkid07
Were those the JKS Quick disco's?
-Michael-
Unread 07-08-2012, 01:45 PM   #4565
Larryftmfw
They were
Unread 07-08-2012, 02:13 PM   #4566
snobrdrkid07
Okay. I don't know what to do about it. Ill just give the JKS a try and see what happens.
-Michael-
Unread 07-08-2012, 05:00 PM   #4567
snobrdrkid07
Originally Posted by ChrisHager
I just got around to counting threads and measuring the track bar. With the jam nut tightened, I have 9 full threads showing from the bottom of the track bar. Also, I'm at 32 & 5/8" from eye to eye. That should get you pretty close!
57 pages ago on mobile. Bringing it back to the front for reference soon.
Chris, did you order KOR bushings?
-Michael-
Unread 07-08-2012, 08:47 PM   #4568
snobrdrkid07
Well, the JKS bar was a no go for tonight. Was able to get the axle side bolt out. But could not get the frame side to budge. I need a cheater bar for my ratchet as I could not get my torque wrench up there because of the pitman arm. Ideas?
-Michael-
Unread 07-08-2012, 08:48 PM   #4569
alwaysHI
2003 WJ
I got my torque wrench up there but put it above the pitman arm and pulled down
Bronson = 21 yrs. old
BUILT, NOT BOUGHT - WORKED HARD FOR, NOT KISSED MOMMY/DADDYS A** FOR!
Build Thread - http://www.jeepforum.com/forum/f197/alwayshi-build-thread-1256466/ - SOLD
alwaysHI is offline   Reply With Quote Quick reply to this message
Unread 07-08-2012, 08:50 PM   #4570
snobrdrkid07
Problem was that I couldn't get in there because I was running an 18 mm deep well socket to a 3/8 to 1/2 adapter then to the torque wrench. I don't have a 18 mm deep well 1/2 socket.
-Michael-
Unread 07-08-2012, 09:03 PM   #4571
alwaysHI
2003 WJ
Ahh that's a different problem. Go borrow one from one of your friends if they got, if not, it's time to invest in one
Unread 07-08-2012, 09:15 PM   #4572
snobrdrkid07
Yeah that was the issue. I think it would have fit if the reducer was out of the equation. Just another added frustration with lifting.
I went out and drove it around the block after putting that axle side bolt in, felt even shakier then before... great. Also I moved the steering wheel while the axle side TB bolt was out, and now the steering wheel is off center when I put the stock bar back. I did not know that would happen?
Oh, a note on the axle side bolt, it is two different diameters. Near the head of the bolt it is a little thicker and closer to the the threads, a little smaller in diameter. I stuck it in the JKS sleeve and could tell that that was contributing to the movement in the sleeve. Or maybe because it was not tight? But I thought that to be a interesting thing to point out.
-Michael-
Unread 07-08-2012, 09:21 PM   #4573
alwaysHI
2003 WJ
When you moved the steering wheel you probably shifted the axle a smudge throwing it out of alignment slightly
Unread 07-08-2012, 09:22 PM   #4574
snobrdrkid07
But I thought that the same length TB wouldn't do that? I was expecting a change if I had put a different length TB in (aka the JKS). But, I thought even if it did shift, the stock TB would bring it back to where it was?
-Michael-
Unread 07-08-2012, 09:46 PM   #4575
Larryftmfw
Hmm strange maybe your bushings shifted?
ome hd , OME lift kit , snobrdrkid , wj
